<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ATOMS3 code load failure]]></title><description><![CDATA[<p dir="auto">Trying to load arduino code for the first time from IDE. Updated all my library files. Fails with the following:<br />
WARNING: This chip doesn't appear to be a ESP32 (date codes 0x03700000:0x00000000). Probably it is unsupported by this version of esptool.<br />
Chip is ESP32-D0WDQ6 (revision 0)<br />
Features: WiFi, BT, Dual Core, Coding Scheme None<br />
WARNING: Detected crystal freq 0.00MHz is quite different to normalized freq 26MHz. Unsupported crystal in use?<br />
Crystal is 26MHz<br />
MAC: 00:00:00:00:00:00<br />
Uploading stub...<br />
Running stub...</p>
<p dir="auto">A fatal error occurred: Invalid head of packet (0x47)<br />
A fatal error occurred: Invalid head of packet (0x47)</p>
<p dir="auto">An error occurred while uploading the sketch</p>
<p dir="auto">I did hold down the reset button until the light turned green.</p>
]]></description><link>https://community.m5stack.com/topic/4923/atoms3-code-load-failure</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 10:40:43 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4923.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Dec 2022 18:28:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ATOMS3 code load failure on Thu, 08 Jun 2023 13:09:48 GMT]]></title><description><![CDATA[<p dir="auto">OK, I just had the same problem and .... is amazing, but the manufacturer Heltec has their libraries on this pcb wrong or at least obsolete. When you put as PCB a "Wireless stick lite" trying to program, but its version is the latest (v3) with an ESP32S3, it shows an error message. Solution, use the expressif PCB library instead of the Haltec library and select the correct board and the problem will be solved.</p>
]]></description><link>https://community.m5stack.com/post/21133</link><guid isPermaLink="true">https://community.m5stack.com/post/21133</guid><dc:creator><![CDATA[Roly_2222]]></dc:creator><pubDate>Thu, 08 Jun 2023 13:09:48 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 code load failure on Thu, 12 Jan 2023 21:17:48 GMT]]></title><description><![CDATA[<p dir="auto">Looks like updates dropping regularly, the M5 board file latest update 2.0.6 may add some support but broke other code so I am sitting at 2.0.5 right now. Could not get unified to work because of errors with IMU and GFX issues so I stopped trying that for now. Will test again next week.</p>
]]></description><link>https://community.m5stack.com/post/19852</link><guid isPermaLink="true">https://community.m5stack.com/post/19852</guid><dc:creator><![CDATA[dheco]]></dc:creator><pubDate>Thu, 12 Jan 2023 21:17:48 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 code load failure on Mon, 02 Jan 2023 20:12:56 GMT]]></title><description><![CDATA[<p dir="auto">Went thru and tried to convert to M5unified, now IMU and SD code does not compile..<br />
error: 'SD' was not declared in this scope<br />
SD.begin();<br />
^~<br />
error: 'class m5::M5Unified' has no member named 'IMU'<br />
M5.IMU.begin();</p>
]]></description><link>https://community.m5stack.com/post/19694</link><guid isPermaLink="true">https://community.m5stack.com/post/19694</guid><dc:creator><![CDATA[dheco]]></dc:creator><pubDate>Mon, 02 Jan 2023 20:12:56 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 code load failure on Mon, 02 Jan 2023 18:37:47 GMT]]></title><description><![CDATA[<p dir="auto">It's not that simple because the ESP32 S3 is not the same as the current chips used in M5Stack products.</p>
]]></description><link>https://community.m5stack.com/post/19693</link><guid isPermaLink="true">https://community.m5stack.com/post/19693</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 02 Jan 2023 18:37:47 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 code load failure on Sun, 01 Jan 2023 14:15:55 GMT]]></title><description><![CDATA[<p dir="auto">Looks like I need to use M5unified also?</p>
]]></description><link>https://community.m5stack.com/post/19690</link><guid isPermaLink="true">https://community.m5stack.com/post/19690</guid><dc:creator><![CDATA[dheco]]></dc:creator><pubDate>Sun, 01 Jan 2023 14:15:55 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 code load failure on Sun, 01 Jan 2023 11:38:49 GMT]]></title><description><![CDATA[<p dir="auto">There was a reply from M5Stack about this on Twitter.<br />
Apparently support is delayed because the programmer behind it is off sick at the moment.</p>
]]></description><link>https://community.m5stack.com/post/19689</link><guid isPermaLink="true">https://community.m5stack.com/post/19689</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 01 Jan 2023 11:38:49 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 code load failure on Sat, 31 Dec 2022 19:31:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Yes, I am running the latest 1.0.4.</p>
]]></description><link>https://community.m5stack.com/post/19686</link><guid isPermaLink="true">https://community.m5stack.com/post/19686</guid><dc:creator><![CDATA[dheco]]></dc:creator><pubDate>Sat, 31 Dec 2022 19:31:18 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 code load failure on Thu, 29 Dec 2022 16:30:01 GMT]]></title><description><![CDATA[<p dir="auto">Did you update ESPtool?</p>
]]></description><link>https://community.m5stack.com/post/19679</link><guid isPermaLink="true">https://community.m5stack.com/post/19679</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 29 Dec 2022 16:30:01 GMT</pubDate></item><item><title><![CDATA[Reply to ATOMS3 code load failure on Wed, 28 Dec 2022 19:15:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dheco" aria-label="Profile: dheco">@<bdi>dheco</bdi></a> Well, I have one on order...so I cannot yet try the Arduino IDE, but the chip is actually<br />
ESP32-S3FN8, not ESP32-D0WDQ6 as the esptool reported.<br />
So, hopefully someone in this community will tell us which Board to select.<br />
(AtomS3 is not yet listed in the Board Selection menu)</p>
]]></description><link>https://community.m5stack.com/post/19672</link><guid isPermaLink="true">https://community.m5stack.com/post/19672</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 28 Dec 2022 19:15:56 GMT</pubDate></item></channel></rss>
