<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Object has no attribute - Error]]></title><description><![CDATA[<p dir="auto">It's very simple. The steps I do:</p>
<li>Add unit (+) in UIFlow</li>
<li>Add DIGI-CLOCK, default setting (Port A)<br />
2b. OK</li>
<li>Open tap 'Units (1)' (under 'Hardwares') &gt; Digi Clock</li>
<li>Get block 'digi_clock_0 init 12c address (0x30).</li>
<li>Run</li>
<p dir="auto">Error: File "&lt;string&gt;", line 8, in &lt;module&gt;<br />
AttributeError: 'module' object has no attribute 'DIGI_CLOCK'</p>
<ol start="6">
<li>Add other blocks; does not matter</li>
<li>Grab another controller; makes no difference (also error).</li>
<p dir="auto">Controlling directly with I2C is possible:<br />
(remove unit)<br />
Tap 'Hardwares', I2C Master:<br />
Block 1: i2c0 Master portA freq 400000<br />
Block 2: i2c0 Set slave addr 0x30<br />
Block 3: i2c0 Write reg 0x4 one byte 0xFF<br />
Display result: 8. (and no error!)</p>
<p dir="auto">Who can help me or has an addition?</p>
]]></description><link>https://community.m5stack.com/topic/4853/object-has-no-attribute-error</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 19:41:13 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4853.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Nov 2022 21:07:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Object has no attribute - Error on Mon, 12 Dec 2022 19:10:47 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/riddsprojects" aria-label="Profile: RIDDSprojects">@<bdi>RIDDSprojects</bdi></a></p>
<p dir="auto">you are very welcome. I am glad to read it works for you now. And thank you for reporting back.</p>
<p dir="auto">Best of luck with your projects.</p>
]]></description><link>https://community.m5stack.com/post/19535</link><guid isPermaLink="true">https://community.m5stack.com/post/19535</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 12 Dec 2022 19:10:47 GMT</pubDate></item><item><title><![CDATA[Reply to Object has no attribute - Error on Mon, 12 Dec 2022 18:47:25 GMT]]></title><description><![CDATA[<p dir="auto">Dear Felix,<br />
You helped me a lot! I had already looked several times for a firmware update, but it got stuck at v1.9.8. Thanks for your tip to use M5Burner Version 3 - I used M5Burner Version 2.5.1 myself. Confusing, but now clear! With, now v1.11.0, it works well!<br />
Thank you! Also for your very quick response.</p>
]]></description><link>https://community.m5stack.com/post/19534</link><guid isPermaLink="true">https://community.m5stack.com/post/19534</guid><dc:creator><![CDATA[RIDDSprojects]]></dc:creator><pubDate>Mon, 12 Dec 2022 18:47:25 GMT</pubDate></item><item><title><![CDATA[Reply to Object has no attribute - Error on Thu, 01 Dec 2022 00:10:53 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/riddsprojects" aria-label="Profile: RIDDSprojects">@<bdi>RIDDSprojects</bdi></a></p>
<p dir="auto">is your M5Stack running the latest UiFlow firmware (v1.10.9)? You can install it with <a href="https://docs.m5stack.com/en/download" target="_blank" rel="noopener noreferrer nofollow ugc">M5Burner</a> v3.0.</p>
]]></description><link>https://community.m5stack.com/post/19420</link><guid isPermaLink="true">https://community.m5stack.com/post/19420</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 01 Dec 2022 00:10:53 GMT</pubDate></item></channel></rss>
