<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[COM.X 868 doesn&#x27;t response in Com Monitor]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm working with the M5Core v1.9.8, i also have the COM.LoRaWan Module(868Mhz v2.0 ) installed on my M5Go.<br />
The Purpose is to send Data from M5Go to the TTN. Therefore i used the manual from <a href="https://www.digikey.be/en/maker/projects/m5stack-com.lorawan-using-uiflow/9b8e36d7c6c54caf8e669886031580e5" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack COM.LoRaWAN Using UIFlow</a><br />
in the Com Monitor in M5Burner i only get the text i sent in the command bar below as result.<br />
The PIN configuration in the UART Block is default (17/16). The programm with the UART forwarding is running.<br />
Does anyone have some inputs for that issue?</p>
<p dir="auto">Thank you in advance<br />
Flo</p>
]]></description><link>https://community.m5stack.com/topic/4851/com-x-868-doesn-t-response-in-com-monitor</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 23:25:11 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4851.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Nov 2022 11:52:32 GMT</pubDate><ttl>60</ttl></channel></rss>
