<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error compiling for ArduinoIoTCloud with M5StickCPlus]]></title><description><![CDATA[<p dir="auto">I have been using Arduino IoT Cloud successfully with an M5Atom for a while, creating Things with cloud variables controlled by Dashboards, such as using a button on a Dashboard change the color of the LED.  I tried doing something similar with an M5StickCPlus with a simple sketch using the template provided by IoT Cloud to change the color of the LCD display:</p>
<pre><code>#include "arduino_secrets.h"
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/e393cc1c-d5b7-48bb-8a27-521dxxxxxxx
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  bool button;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include "M5StickCPlus.h"
  M5.begin();
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  ArduinoCloud.update();
  // Your code here
  Since Button is READ_WRITE variable, onButtonChange() is
  executed every time a new value is received from IoT Cloud.
void onButtonChange()  {
  // Add your code here to act upon Button change
  if (button)
    M5.Lcd.fillScreen(RED);
  else
    M5.Lcd.fillScreen(BLUE);
<p dir="auto">When I compile this, I get the following error:</p>
<pre><code>c:\Users\xxx\Documents\Arduino\libraries\M5StickCPlus\src/utility/In_eSPI.h:952:52: error: macro "setAttribute" passed 2 arguments, but takes just 1
			     void setAttribute(uint8_t id = 0, uint8_t a = 0);
<p dir="auto">The problem is that <code>ArduinoIoTCloud.h</code> includes a file <code>property/Property.h</code> that defines three macros, including <code>setAttribute</code></p>
<pre><code>#define appendAttributesToCloud() appendAttributesToCloudReal(CborEncoder *encoder)
#define appendAttribute(x) appendAttributeReal(x, getAttributeName(#x, '.'), encoder)
#define setAttribute(x) setAttributeReal(x, getAttributeName(#x, '.'))
<p dir="auto">Unfortunately, there is a class member function called <code>setAttribute</code> in the library file <code>M5StickCPlus/src/utility/In_eSPI.h</code></p>
<pre><code>// Set or get an arbitrary library attribute or configuration option
    uint8_t getAttribute(uint8_t id = 0);
<p dir="auto">Because the macro from the ArduinoIoTCloud library is included globally, it ends up getting used in place of the correct function (which has 2 arguments).</p>
<p dir="auto">Whose "fault" is this and what should be the fix?  In general, I think it's not good form to include a global macro in a library, especially one with a name like <code>setAttribute</code> that could easily match something in user code that includes that library.  So I decided to change my local copy of the ArduinoIoTCloud library and replace the macro name with <code>AIOTC_setAttribute</code> (as well as prefixing the other two macros with <code>AIOTC_</code>), and then modify all of the files in <code>property/types</code> that use this macro to match.</p>
<p dir="auto">Hopefully someone finds this helpful.  I'm going to post this over on the Arduino forum as well, as I think these global macros should be replaced by something safer.</p>
]]></description><link>https://community.m5stack.com/topic/4802/error-compiling-for-arduinoiotcloud-with-m5stickcplus</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 15:13:01 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4802.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Nov 2022 17:15:54 GMT</pubDate><ttl>60</ttl></channel></rss>
