<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC-Plus USB&#x2F;Driver Issues (able to flash but not read&#x2F;write to device via USB)]]></title><description><![CDATA[<p dir="auto">Just got my first M5Stack device but unfortunately, I'm not able to use USB functionality on my M5StickC. I have updated the FTDI driver to the most recent driver. I am able to get it to burn by manually selecting the correct COM port in M5Burner (wont automatically find com port per user guide). But I am still unable to read/write the device file structure through USB/VS Code/Arduino IDE's.</p>
<p dir="auto">I have followed instructions set by M5Stack/FTDI to a tee, but am still unable to get the M5StickC to work in USB mode properly. I have reset the device multiple times, re-installed drivers, re-flashed, but unfortunately nothing is working.</p>
<p dir="auto">In VSCODE when I select my M5stack it doesnt show the file structure, but if I click "COM" in the lower left corner and "reset" the device it works. So from what I gather it is able to write to the device but not read the device.</p>
<p dir="auto">Any help is greatly appreciated! This is a very cool device, and cloud read/write works, but I need USB functionality to work to be able to use VS Code.</p>
<p dir="auto">I have attached screenshots below to help see whats going on. Thank you for any help! Been a bit frustrating! for me</p>
<p dir="auto"><img src="https://imgur.com/qlo2FOU" alt="M5StickC Port Settings 1" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://imgur.com/UDHjwsF" alt="M5StickC Port Settings 2" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://imgur.com/AsD7dXy" alt="M5StickC Serial Converter Port Settings 1" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://imgur.com/DLwmK7c" alt="M5StickC Serial Converter Port Settings 2" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://imgur.com/aTqzVlC" alt="VS Code add device" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://imgur.com/XXepU46" alt="How VS Code looks after COM device is added - note that there is no file structure populated for the M5StickC device" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/4799/m5stickc-plus-usb-driver-issues-able-to-flash-but-not-read-write-to-device-via-usb</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Mar 2026 13:54:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4799.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Nov 2022 18:18:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC-Plus USB&#x2F;Driver Issues (able to flash but not read&#x2F;write to device via USB) on Sun, 13 Nov 2022 21:47:25 GMT]]></title><description><![CDATA[<p dir="auto">was able to get this resolved be removing/re-installing the drivers a bunch of times. Appreciate the assist!</p>
]]></description><link>https://community.m5stack.com/post/19291</link><guid isPermaLink="true">https://community.m5stack.com/post/19291</guid><dc:creator><![CDATA[theaeropath]]></dc:creator><pubDate>Sun, 13 Nov 2022 21:47:25 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC-Plus USB&#x2F;Driver Issues (able to flash but not read&#x2F;write to device via USB) on Sun, 13 Nov 2022 02:39:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> Those devices are other control boxes for my CPU/Desk Lighting. Ive tried the removing and re-installing drivers a couple times now</p>
]]></description><link>https://community.m5stack.com/post/19283</link><guid isPermaLink="true">https://community.m5stack.com/post/19283</guid><dc:creator><![CDATA[theaeropath]]></dc:creator><pubDate>Sun, 13 Nov 2022 02:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC-Plus USB&#x2F;Driver Issues (able to flash but not read&#x2F;write to device via USB) on Sat, 12 Nov 2022 19:56:04 GMT]]></title><description><![CDATA[<p dir="auto">Have you got 3 devices connected at the same time? If not you need to remove the drivers and reinstall<br />
, there should only be one port</p>
]]></description><link>https://community.m5stack.com/post/19278</link><guid isPermaLink="true">https://community.m5stack.com/post/19278</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 12 Nov 2022 19:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC-Plus USB&#x2F;Driver Issues (able to flash but not read&#x2F;write to device via USB) on Sat, 12 Nov 2022 18:57:27 GMT]]></title><description><![CDATA[<p dir="auto">Doesnt looks like the screenshots posted. Here's an imgur link to the snips: <a href="https://imgur.com/a/qprcseo" target="_blank" rel="noopener noreferrer nofollow ugc">https://imgur.com/a/qprcseo</a></p>
]]></description><link>https://community.m5stack.com/post/19277</link><guid isPermaLink="true">https://community.m5stack.com/post/19277</guid><dc:creator><![CDATA[theaeropath]]></dc:creator><pubDate>Sat, 12 Nov 2022 18:57:27 GMT</pubDate></item></channel></rss>
