<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Not M5Stack product but &#x27;family&#x27; ESP32-S3-Box MSFS2020 GPSout GPRMC and GPGGA data to &#x27;esp-box&#x27;]]></title><description><![CDATA[<p dir="auto">The Espressif ESP32-S3-Box is a product that looks like some M5Stack products. I own quite a bunch of M5Stack products. When the Espressif ESP32-S3-Box (V  2.5) came out, I bought it. It was my intention to port my ongoing MSFS2020 GPSout project to the 'esp-box' (the (nick)name that Espressif uses for this device). It was until last weekend when through @Neradoc and @hathach, the maintainer of Adafruit tinyuf2 bootloader repo, on my request, had added the 'esp-box' to the list of boards compatible for the tinyuf2 bootloader. From that moment I was able to build a tinyuf2 bootloader firmware for the 'esp-box'. When that was done, I was able to copy the latest version of CircuitPython (V8.0.0-beta.2) to the device. Finally I was able to port my project to the 'esp-box'.</p>
<p dir="auto">That is why I created this post here so you can read about the existance of my project. See my repo on <a href="https://github.com/PaulskPt/ESP32-S3-Box_MSFS2020_GPSout_GPRMC_and_GPGGA" target="_blank" rel="noopener noreferrer nofollow ugc">Github</a>.<br />
<img src="https://i.imgur.com/gEfmUeC.png" alt="GPS data on esp-box" class=" img-fluid img-markdown" /></p>
<p dir="auto">Below some REPL output:</p>
<pre><code>soft reboot
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
]0;🐍Wi-Fi: off | code.py | 8.0.0-beta.2\
loop(): my_machine= "ESP32-S3-Box-2.5 with ESP32S3"
MSFS2020 GPS GPRMC data reception decoder script by @PaulskPt.
Number of loops in this run: 99
Start of loop 1
ck_uart(): nr of bytes=  120
ck_uart(): rcvd data: bytearray(b'$GPRMC,215807.00,A,5837.7935,N,13810.7771,W,164.0,319.8,161022,18.2,E*72\r\n$GPGGA,215807.00,5837.7935,N,13810.7771,W,1,05\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
ck_uart(): nr of bytes=  33
ck_uart(): rcvd data: bytearray(b',0.0,4266.7,M,0.0,M,0.0,0000*51\r\n810.7771,W,164.0,319.8,161022,18.2,E*72\r\n$GPGGA,215807.00,5837.7935,N,13810.7771,W,1,05\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
ck_uart(): nr of bytes=  153
ck_uart(): rcvd data: bytearray(b'$GPRMC,215811.00,A,5837.9408,N,13811.0171,W,164.0,319.6,161022,18.2,E*76\r\n$GPGGA,215811.00,5837.9408,N,13811.0171,W,1,05,0.0,4266.7,M,0.0,M,0.0,0000*5B\r\n\x00\x00\x00\x00\x00\x00\x00')
ck_uart(): * at -11, $GPRMC at 0, $GPGGA at 74, n4 =114
loop(): characters rcvd:  153
loop(): split_types() result = True
is_ac_stopped():  value of gs = 164.0, len(gs) = 5
is_ac_stopped():  value of v_gs = 164
loop(): handling msg nr: 01
lcd_pr_msgs(): Duration rx -&gt; lcd: 241 mSecs
loop(): gc.mem_free()= 8148128
Waiting for serial com line to become available...
End of loop  1
<p dir="auto">Note: because the 'terminalio.font' doesn't have a glyph for the 'degrees' character I used the caret '^' instead,<br />
until I have added a font that can display the degrees character.</p>
<p dir="auto">For some other microcontroller i have ports of the same project on Github.</p>
]]></description><link>https://community.m5stack.com/topic/4731/not-m5stack-product-but-family-esp32-s3-box-msfs2020-gpsout-gprmc-and-gpgga-data-to-esp-box</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 03:05:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4731.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Oct 2022 16:57:40 GMT</pubDate><ttl>60</ttl></channel></rss>
