<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Step Motor Driver maybe not connect - core2 and stepmotor driver module 13.2]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I have a core2 stacked with a Stepmotor driver module 13.2 and a m5go bottom2<img src="https://i.imgur.com/ZLFU43Z.jpg" alt="stack" class=" img-fluid img-markdown" />.<br />
I am using the stepmotor driver UI flow elements to program it:</p>
<p dir="auto"><img src="https://i.imgur.com/6ROh3z1.jpg" alt="code" class=" img-fluid img-markdown" /></p>
<p dir="auto">No matter what I try I always get this error message when loading the code, as if the module isn't connected:</p>
<p dir="auto"><img src="https://i.imgur.com/lQbvqUy.jpg" alt="error" class=" img-fluid img-markdown" /></p>
<p dir="auto">I know power is getting to the base because I can drive the LEDs, and the 12v power supply is a full 5a and does power the unit from the stepmotor base, so I can't figure out the error. Any help would be greatly appreciated!</p>
]]></description><link>https://community.m5stack.com/topic/4710/step-motor-driver-maybe-not-connect-core2-and-stepmotor-driver-module-13-2</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 14:11:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4710.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Oct 2022 16:15:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Step Motor Driver maybe not connect - core2 and stepmotor driver module 13.2 on Sun, 11 Dec 2022 04:37:28 GMT]]></title><description><![CDATA[<p dir="auto">Would love to know if there is a fix to have this work with the core2. I just purchased a core2 and the driver module, just found your post after many failed attempts with the same error you got.</p>
]]></description><link>https://community.m5stack.com/post/19510</link><guid isPermaLink="true">https://community.m5stack.com/post/19510</guid><dc:creator><![CDATA[ke0vny]]></dc:creator><pubDate>Sun, 11 Dec 2022 04:37:28 GMT</pubDate></item><item><title><![CDATA[Reply to Step Motor Driver maybe not connect - core2 and stepmotor driver module 13.2 on Sun, 16 Oct 2022 06:10:43 GMT]]></title><description><![CDATA[<p dir="auto">So I finally figured it out. Turns out the stepmotor driver module is NOT compatible with Core2. Upsetting because on the page on the M5Stack store it says: "StepMotor Driver is adapted to M5 core series..."  That's core SERIES, not just Core Basic.  Fortunately I had a Core Basic and could test it. Works just fine.</p>
<p dir="auto">Please let me know if I'm wrong about the Core2 compatibility. If it is let me know what I need to do to get it to work with Core2. Thanks.</p>
]]></description><link>https://community.m5stack.com/post/18982</link><guid isPermaLink="true">https://community.m5stack.com/post/18982</guid><dc:creator><![CDATA[Slartibartfast]]></dc:creator><pubDate>Sun, 16 Oct 2022 06:10:43 GMT</pubDate></item><item><title><![CDATA[Reply to Step Motor Driver maybe not connect - core2 and stepmotor driver module 13.2 on Sat, 15 Oct 2022 17:17:35 GMT]]></title><description><![CDATA[<p dir="auto">So different but similar behavior with a third Core2. Still looking for help on this.</p>
]]></description><link>https://community.m5stack.com/post/18978</link><guid isPermaLink="true">https://community.m5stack.com/post/18978</guid><dc:creator><![CDATA[Slartibartfast]]></dc:creator><pubDate>Sat, 15 Oct 2022 17:17:35 GMT</pubDate></item><item><title><![CDATA[Reply to Step Motor Driver maybe not connect - core2 and stepmotor driver module 13.2 on Sat, 15 Oct 2022 16:26:14 GMT]]></title><description><![CDATA[<p dir="auto">Also I should mention I have two of these modules and two core2's and all exhibit the same behavior.</p>
]]></description><link>https://community.m5stack.com/post/18977</link><guid isPermaLink="true">https://community.m5stack.com/post/18977</guid><dc:creator><![CDATA[Slartibartfast]]></dc:creator><pubDate>Sat, 15 Oct 2022 16:26:14 GMT</pubDate></item></channel></rss>
