<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIflow support for Relay module bases?]]></title><description><![CDATA[<p dir="auto">Is there any way to use the <a href="https://shop.m5stack.com/products/4-channel-relay-module-stm32" target="_blank" rel="noopener noreferrer nofollow ugc">M121 4-Channel Relay module</a> in UIFlow?</p>
<p dir="auto">Is it going to use the same UIFlow Unit as the <a href="https://shop.m5stack.com/products/4-relay-unit?variant=37124756668588" target="_blank" rel="noopener noreferrer nofollow ugc">U097 4-Relay unit</a> (that connects via Port A i2c)?</p>
<p dir="auto">The U097 has some added features (the LEDs, NO and NC) that the M121 does not.</p>
<p dir="auto">And if the M121 needs something different, how do I get that integrated with a UIFlow app?</p>
]]></description><link>https://community.m5stack.com/topic/4691/uiflow-support-for-relay-module-bases</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 10:46:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4691.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Oct 2022 23:21:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIflow support for Relay module bases? on Sun, 09 Oct 2022 05:28:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wkearney99" aria-label="Profile: wkearney99">@<bdi>wkearney99</bdi></a></p>
<p dir="auto">I don't see 4-Relay module in UIFlow (yet).</p>
<p dir="auto">No, I don't think you can use the UIFlow for 4-Relay unit since the I2C registers are different. 4-Relay module uses register 0x10 to control the relay vs. 4-Relay unit uses register 0x11 to control the relay and LED (register 0x10 is a control register).</p>
<p dir="auto">Documentation for <a href="https://github.com/m5stack/M5Module-4Relay-Internal-FW" target="_blank" rel="noopener noreferrer nofollow ugc">4-Relay module</a>. Documentation for <a href="https://docs.m5stack.com/en/unit/4relay" target="_blank" rel="noopener noreferrer nofollow ugc">4-Relay unit</a>.</p>
<p dir="auto">BTW: you could use the default I2C Master blocks (under Hardwares) to control the 4-Relay module.</p>
]]></description><link>https://community.m5stack.com/post/18912</link><guid isPermaLink="true">https://community.m5stack.com/post/18912</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 09 Oct 2022 05:28:04 GMT</pubDate></item></channel></rss>
