<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[4-Relay Unit question]]></title><description><![CDATA[<p dir="auto">I just bought some 4-Relay Units (i2C) and I found that there are two operating modes; synchronous and asynchronous. The documentation does not describe the difference between these modes except to say, don't use asynchronous!</p>
<p dir="auto">from documentation  - UIFlow functions<br />
"Set LED and relay mode<br />
Synchronize<br />
LED and relay ON/OFF are synchronized.<br />
Asynchronous<br />
LED and relay ON/OFF are asynchronous."</p>
<li>Can anybody shed light on what they are referring to? Does this mean that in asynchronous mode you can select the LED and Relay separately?? Or does it refer to the settings of the individual relay values?</li>
<p dir="auto">from documentation - RELAY control Reg 0x11<br />
"Note:The relay can only be controlled in synchronous mode, if the relay is controlled in asynchronous mode, it will not work."<br />
2. If we are not supposed to use the asynchronous mode the why the heck do they let you select it???</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://community.m5stack.com/topic/4671/4-relay-unit-question</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 14:49:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4671.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Oct 2022 20:18:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 4-Relay Unit question on Tue, 04 Oct 2022 22:14:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> Thanks for you fast reply Felix!<br />
I will.</p>
]]></description><link>https://community.m5stack.com/post/18822</link><guid isPermaLink="true">https://community.m5stack.com/post/18822</guid><dc:creator><![CDATA[robjasey]]></dc:creator><pubDate>Tue, 04 Oct 2022 22:14:52 GMT</pubDate></item><item><title><![CDATA[Reply to 4-Relay Unit question on Tue, 04 Oct 2022 20:46:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/19418">@robjasey</a></p>
<p dir="auto">the description is misleading, I can use both modes and they do as I'd expect. Synchronous mode: relay and LED go together. Asynchronous mode: relay and LED can be controlled separately.</p>
<p dir="auto">Here is what I found using UIFlow 1.10.6 and the 4-Relay unit:<br />
Synchronous mode:</p>
<li>turn on relay works (LED turns on too)</li>
<li>turn off relay works (LED turns off too)</li>
<li>turn on LED does <strong>not</strong> work</li>
<li>turn off LED does <strong>not</strong> work</li>
<p dir="auto">Asynchronous mode:</p>
<li>turn on relay works (LED does not turn on)</li>
<li>turn off relay works (LED does not turn off)</li>
<li>turn on LED works</li>
<li>turn off LED works</li>
<p dir="auto">I suggest you just give it a try.</p>
]]></description><link>https://community.m5stack.com/post/18821</link><guid isPermaLink="true">https://community.m5stack.com/post/18821</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 04 Oct 2022 20:46:05 GMT</pubDate></item></channel></rss>
