<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[You guys put the wrong threads in M5-StickT, you put M6, not 1&#x2F;4&quot;-20]]></title><description><![CDATA[<p dir="auto">My M5-StickT came with the wrong threaded insert, it doesn't fit 1/4"-20, making it impossible to mount on top of a camera. The threads matched M6 screws.</p>
]]></description><link>https://community.m5stack.com/topic/4602/you-guys-put-the-wrong-threads-in-m5-stickt-you-put-m6-not-1-4-20</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 10:44:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4602.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Sep 2022 21:11:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to You guys put the wrong threads in M5-StickT, you put M6, not 1&#x2F;4&quot;-20 on Tue, 13 Sep 2022 03:44:15 GMT]]></title><description><![CDATA[<p dir="auto">And while you guys fix the nylon 3D printed case design, please also add holes for the infrared emitter.</p>
<p dir="auto">I see the IR emitter LED on the PCB but there's no holes on the case to let the light out.</p>
<p dir="auto">And if you are wondering, yes, I do need it.</p>
<p dir="auto">It would be helpful if you guys posted a file type better than STL so I can actually edit the 3D model myself. Like STEP or IGES.</p>
]]></description><link>https://community.m5stack.com/post/18592</link><guid isPermaLink="true">https://community.m5stack.com/post/18592</guid><dc:creator><![CDATA[frank26080115]]></dc:creator><pubDate>Tue, 13 Sep 2022 03:44:15 GMT</pubDate></item><item><title><![CDATA[Reply to You guys put the wrong threads in M5-StickT, you put M6, not 1&#x2F;4&quot;-20 on Mon, 12 Sep 2022 19:48:48 GMT]]></title><description><![CDATA[<p dir="auto">I opened it up, it's not a threaded insert, it's a plain M6 hex nut inside in a rectangular recess.</p>
<p dir="auto">Man this is annoying... a normal sized 1/4"-20 nut is like a hair too big (actually about 2mm too big) for the original rectangular recess, I have to bench grind it down to the right size before putting it back in.</p>
<p dir="auto">Can you guys (M5Stack staff) redesign the nylon case for the correct nut and send me a new case? Just the nylon 3D printed case is needed. I'm not asking for a $500 product exchange, just a new nylon 3D printed case.</p>
]]></description><link>https://community.m5stack.com/post/18591</link><guid isPermaLink="true">https://community.m5stack.com/post/18591</guid><dc:creator><![CDATA[frank26080115]]></dc:creator><pubDate>Mon, 12 Sep 2022 19:48:48 GMT</pubDate></item></channel></rss>
