<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AWS IoT SDK support]]></title><description><![CDATA[<p dir="auto">Is there any way to install AWS IoT SDK to be able to use core2 as a greengrass client device?<br />
<a href="https://docs.aws.amazon.com//greengrass/v2/developerguide/client-devices-tutorial.html#connect-client-devices-tutorial" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.aws.amazon.com//greengrass/v2/developerguide/client-devices-tutorial.html#connect-client-devices-tutorial</a></p>
]]></description><link>https://community.m5stack.com/topic/4511/aws-iot-sdk-support</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 22:54:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4511.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Aug 2022 04:32:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AWS IoT SDK support on Sun, 14 Aug 2022 23:06:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> I’m afraid but I’m not the author of that post. But, I agree that it’s a well written one. Regarding device shadow, this is what I meant:<br />
<img src="/assets/uploads/files/1660510875123-54276020-0df4-4c24-a194-83fe63676b6e.png" alt="local shadow.png" class=" img-fluid img-markdown" /></p>
<li><a href="https://docs.aws.amazon.com/greengrass/v2/developerguide/interact-with-shadows.html" target="_blank" rel="noopener noreferrer nofollow ugc">Interact with device shadows</a></li>
]]></description><link>https://community.m5stack.com/post/18336</link><guid isPermaLink="true">https://community.m5stack.com/post/18336</guid><dc:creator><![CDATA[kulmam92]]></dc:creator><pubDate>Sun, 14 Aug 2022 23:06:16 GMT</pubDate></item><item><title><![CDATA[Reply to AWS IoT SDK support on Sun, 14 Aug 2022 16:52:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/23020">@kulmam92</a> love the humour you put in your post and it looks great so far.<br />
Cpt.James.Purcell (my split personality) just subscribed to rosietherobot</p>
]]></description><link>https://community.m5stack.com/post/18330</link><guid isPermaLink="true">https://community.m5stack.com/post/18330</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 14 Aug 2022 16:52:11 GMT</pubDate></item><item><title><![CDATA[Reply to AWS IoT SDK support on Sun, 14 Aug 2022 16:44:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/23020">@kulmam92</a> from what I gather DeviceShadow/Device Twin and device defender work between the GGgateway and AWS IOT server.</p>
]]></description><link>https://community.m5stack.com/post/18329</link><guid isPermaLink="true">https://community.m5stack.com/post/18329</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 14 Aug 2022 16:44:30 GMT</pubDate></item><item><title><![CDATA[Reply to AWS IoT SDK support on Sun, 14 Aug 2022 15:06:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> Thank you for your effort and update. The flow that I have in mind is:</p>
<p dir="auto">Core2(Greengrass client using aws IoT device SDK) -&gt; RaspberryPi(Greengrass) -&gt; AWS IoT Core</p>
<p dir="auto">The reason that I want to use this is to demonstrate the features of the AWS Greengrass like:</p>
<li>ML at the edge: core2 send image to RaspberryPi(Greengrass) and run ML like object detection.</li>
<li>device shadow</li>
<li>device defender</li>
<p dir="auto">You may send message to RsapberryPi(Greengrass) via mqttclient like below but you can’t use device shadow or device defender.</p>
<p dir="auto"><a href="https://www.rosietheredrobot.com/2019/03/green-green-grass-of-home.html?m=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.rosietheredrobot.com/2019/03/green-green-grass-of-home.html?m=1</a></p>
<p dir="auto">I hope this give you a clear picture of what I’m trying to do.</p>
]]></description><link>https://community.m5stack.com/post/18327</link><guid isPermaLink="true">https://community.m5stack.com/post/18327</guid><dc:creator><![CDATA[kulmam92]]></dc:creator><pubDate>Sun, 14 Aug 2022 15:06:33 GMT</pubDate></item><item><title><![CDATA[Reply to AWS IoT SDK support on Sun, 14 Aug 2022 08:55:12 GMT]]></title><description><![CDATA[<p dir="auto">Ok so from what I can work out (two days fighting to log into AWS!)<br />
Any device works as a Grass client using MQTT or HTTP<br />
No devices at present work as a Greengrass hub until CM4's become available enough to start production of the M5CM4 Hub.<br />
You can use an RPI4 or equiv as the Greengrass hub or just use mosquitto service on the RPI4 or equivalent linux device.</p>
]]></description><link>https://community.m5stack.com/post/18321</link><guid isPermaLink="true">https://community.m5stack.com/post/18321</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 14 Aug 2022 08:55:12 GMT</pubDate></item><item><title><![CDATA[Reply to AWS IoT SDK support on Fri, 12 Aug 2022 15:10:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> FYI, the below are the closest attempts that I was able to find.</p>
<li><a href="https://stackoverflow.com/questions/64157384/embed-aws-iot-device-sdk-to-micropython-as-user-c-module" target="_blank" rel="noopener noreferrer nofollow ugc">Embed aws iot device sdk to Micropython as user C module - stackoverflow question</a></li>
<li><a href="https://blog.espressif.com/support-for-lts-release-of-aws-iot-device-sdk-for-embedded-c-on-esp32-8eeeea28b79b" target="_blank" rel="noopener noreferrer nofollow ugc">Releasing LTS of AWS IoT Device SDK for Embedded C on ESP32</a></li>
]]></description><link>https://community.m5stack.com/post/18305</link><guid isPermaLink="true">https://community.m5stack.com/post/18305</guid><dc:creator><![CDATA[kulmam92]]></dc:creator><pubDate>Fri, 12 Aug 2022 15:10:28 GMT</pubDate></item><item><title><![CDATA[Reply to AWS IoT SDK support on Fri, 12 Aug 2022 04:56:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/23020">@kulmam92</a> Sorry, up to my next dealing with the ATECC608b and security features of the Core2 AWS</p>
]]></description><link>https://community.m5stack.com/post/18298</link><guid isPermaLink="true">https://community.m5stack.com/post/18298</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 12 Aug 2022 04:56:24 GMT</pubDate></item><item><title><![CDATA[Reply to AWS IoT SDK support on Thu, 11 Aug 2022 21:54:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> Did you have a chance to test out if there's any way to do this?</p>
]]></description><link>https://community.m5stack.com/post/18294</link><guid isPermaLink="true">https://community.m5stack.com/post/18294</guid><dc:creator><![CDATA[kulmam92]]></dc:creator><pubDate>Thu, 11 Aug 2022 21:54:57 GMT</pubDate></item><item><title><![CDATA[Reply to AWS IoT SDK support on Tue, 09 Aug 2022 13:24:49 GMT]]></title><description><![CDATA[<p dir="auto">The sample(<a href="https://github.com/aws/aws-iot-device-sdk-python-v2/blob/main/samples/basic_discovery.py" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/aws/aws-iot-device-sdk-python-v2/blob/main/samples/basic_discovery.py</a>) uses below imports:</p>
<p dir="auto"><em>import time<br />
import json<br />
from concurrent.futures import Future<br />
from awscrt import io<br />
from awscrt.mqtt import QoS<br />
from awsiot.greengrass_discovery import DiscoveryClient<br />
from awsiot import mqtt_connection_builder</em></p>
<p dir="auto">If you run that script on core2, you will get an error because concurrent, awscrt, and awsiot don't exist in the core2. It will be great if I can make those available from core2.</p>
]]></description><link>https://community.m5stack.com/post/18256</link><guid isPermaLink="true">https://community.m5stack.com/post/18256</guid><dc:creator><![CDATA[kulmam92]]></dc:creator><pubDate>Tue, 09 Aug 2022 13:24:49 GMT</pubDate></item><item><title><![CDATA[Reply to AWS IoT SDK support on Tue, 09 Aug 2022 05:48:10 GMT]]></title><description><![CDATA[<p dir="auto">For micropython?<br />
If you are just using MQTT to send data to green grass as shown in that article then you can use the included AWS functions along with MQTT function in the current UIFLOW/Micropython firmware.</p>
]]></description><link>https://community.m5stack.com/post/18253</link><guid isPermaLink="true">https://community.m5stack.com/post/18253</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 09 Aug 2022 05:48:10 GMT</pubDate></item></channel></rss>
