<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Azure IoT Speaker play_cloud command broken]]></title><description><![CDATA[<p dir="auto">This Azure handler won't play cloud based wav files.  The play_local works fine though.  The error message shown when trying to play a WAV URL is below:</p>
<p dir="auto"><img src="/assets/uploads/files/1659469085769-59728f48-2c71-4aad-bfae-683b51f276d4-image.png" alt="0_1659469083946_59728f48-2c71-4aad-bfae-683b51f276d4-image.png" class=" img-fluid img-markdown" /></p>
<pre><code>Unhandled exception in thread started by &lt;bound_method&gt;
  File "libs/m5mqtt.py", line 101, in _msg_deal_task
  File "libs/m5mqtt.py", line 88, in update
  File "umqtt/robust.py", line 80, in check_msg
  File "umqtt/simple.py", line 271, in check_msg
  File "umqtt/simple.py", line 259, in wait_msg
  File "libs/m5mqtt.py", line 50, in _on_data
  File "IoTcloud/Azure.py", line 333, in direct_method_cb
  File "&lt;string&gt;", line 33, in azure_direct_Speaker_play_cloud
  File "hardware/speaker.py", line 135, in playCloudWAV
  File "hardware/speaker.py", line 82, in playWAV
ValueError: Data Format is not valid
]]></description><link>https://community.m5stack.com/topic/4498/azure-iot-speaker-play_cloud-command-broken</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 04:47:11 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4498.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Aug 2022 19:37:29 GMT</pubDate><ttl>60</ttl></channel></rss>
