<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Timer X Camera AWS s3 settup]]></title><description><![CDATA[<p dir="auto">Hello I just bought a Timer X Camera and set up a AWS s3 bucket. Whenever i burn the firmware onto the camera after going through the steps nothing happens. When i check the serial port it shows that the camera is connecting to the WIFI but no images are being sent to the bucket. (And the serial is going to fast i cant really tell where it hangs).</p>
<p dir="auto">If anyone had any comments on if it still works or the bucket has to be set up a certain way id much appreciate it.</p>
<p dir="auto">Thanks,<br />
W</p>
]]></description><link>https://community.m5stack.com/topic/4441/timer-x-camera-aws-s3-settup</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 11:32:43 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4441.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Jul 2022 05:48:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Timer X Camera AWS s3 settup on Thu, 10 Oct 2024 13:04:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/isamalatby" aria-label="Profile: isamalatby">@<bdi>isamalatby</bdi></a> What you need is likely to prefix "AWS4" to your secret access key - "AWS4&lt;SECRET ASCCESS KEY&gt;". Additionally, your url must be of the format "&lt;API URL&gt;/&lt;BUCKET NAME&gt;".</p>
<p dir="auto"><a href="https://github.com/m5stack/M5_Camera_Examples/blob/main/idf/AWS-S3-PUT/main/AWS-S3-PUT.c#L59" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5_Camera_Examples/blob/main/idf/AWS-S3-PUT/main/AWS-S3-PUT.c#L59</a></p>
<p dir="auto">Good luck.</p>
]]></description><link>https://community.m5stack.com/post/26680</link><guid isPermaLink="true">https://community.m5stack.com/post/26680</guid><dc:creator><![CDATA[M5User-60283]]></dc:creator><pubDate>Thu, 10 Oct 2024 13:04:28 GMT</pubDate></item><item><title><![CDATA[Reply to Timer X Camera AWS s3 settup on Fri, 29 Jul 2022 03:36:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello again<br />
The solution in the link below<br />
<a href="https://qiita.com/hayate_h/items/8d157f657924d51e5d62" target="_blank" rel="noopener noreferrer nofollow ugc">https://qiita.com/hayate_h/items/8d157f657924d51e5d62</a><br />
it's chines website, try to use google translation to change the language and it works with me finally</p>
]]></description><link>https://community.m5stack.com/post/18102</link><guid isPermaLink="true">https://community.m5stack.com/post/18102</guid><dc:creator><![CDATA[isamalatby]]></dc:creator><pubDate>Fri, 29 Jul 2022 03:36:04 GMT</pubDate></item><item><title><![CDATA[Reply to Timer X Camera AWS s3 settup on Fri, 29 Jul 2022 02:41:35 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">The same thing happened to me, I emailed the support team about this problem and they said there is a bug in the example and they will try to fix it soon, nothing happened so far, appreciate if anyone can help</p>
]]></description><link>https://community.m5stack.com/post/18101</link><guid isPermaLink="true">https://community.m5stack.com/post/18101</guid><dc:creator><![CDATA[isamalatby]]></dc:creator><pubDate>Fri, 29 Jul 2022 02:41:35 GMT</pubDate></item></channel></rss>
