<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board!]]></title><description><![CDATA[<p dir="auto">Currently it seems that the Stamp ext IO2 can only be in one mode for all pins, set by the command: (for example)<br />
extio_io_mode_t mode = DIGITAL_OUTPUT_MODE;<br />
or<br />
extio.setAllPinMode(RGB_LED_MODE);<br />
Also like the RGB mode to support a string, not just one SK6812.<br />
Thanks for listening.<br />
Terry</p>
]]></description><link>https://community.m5stack.com/topic/4431/stamp-ext-io2-sku-s002-able-to-use-individual-pins-not-just-one-mode-for-the-whole-board</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 02:37:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4431.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Jul 2022 22:49:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Mon, 08 Aug 2022 05:10:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7508">@teastain</a></p>
<p dir="auto">your example looks fine to me. Nicely done.</p>
<p dir="auto">Regarding submission: you can create a pull-request for yourself, inside the M5Stack repository, which adds your example and M5Stack engineers eventually will check it out.</p>
]]></description><link>https://community.m5stack.com/post/18236</link><guid isPermaLink="true">https://community.m5stack.com/post/18236</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 08 Aug 2022 05:10:17 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Sun, 07 Aug 2022 23:03:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> Hi Felix, me again.<br />
Regarding the PaHub:<br />
I found the Official M5Stack PaHub example to be of little help to write a useful project with 2 sensors with the same I2C address. I made this example very minimalist using a M5Stack Core Basic controller.<br />
PaHub Example with 2 ENVII temperature sensors:<br />
I put it on GitHub <a href="https://github.com/teastainGit/Simple-PaHub-example" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/teastainGit/Simple-PaHub-example</a><br />
Would you have time to look it over and "Maybe" submit it to M5Stack? To be added to their example for PaHub?<br />
If not could you tell me how to submit it? I am asking you because you have a great reputation with them!!!<br />
Cheers! Terry</p>
]]></description><link>https://community.m5stack.com/post/18235</link><guid isPermaLink="true">https://community.m5stack.com/post/18235</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sun, 07 Aug 2022 23:03:20 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Wed, 13 Jul 2022 03:12:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> GOOD JOB!<br />
I downloaded the new library and made a mixed program with one pin Output and another RGB...<br />
Works perfectly. I studied your library...maybe next time I will try!<br />
Much thanks, Terry</p>
]]></description><link>https://community.m5stack.com/post/17980</link><guid isPermaLink="true">https://community.m5stack.com/post/17980</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 13 Jul 2022 03:12:28 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Mon, 11 Jul 2022 14:20:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7508">@teastain</a></p>
<p dir="auto">FYI: I stand corrected. My pull-request already has been approved. Nicely done M5Stack.</p>
]]></description><link>https://community.m5stack.com/post/17967</link><guid isPermaLink="true">https://community.m5stack.com/post/17967</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 11 Jul 2022 14:20:17 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Sun, 10 Jul 2022 04:34:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7508">@teastain</a></p>
<p dir="auto">Hi! <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7508">@teastain</a><br />
I'm sorry.<br />
I didn't understand the question.<br />
Therefore, the post has been deleted.</p>
]]></description><link>https://community.m5stack.com/post/17958</link><guid isPermaLink="true">https://community.m5stack.com/post/17958</guid><dc:creator><![CDATA[macsbug]]></dc:creator><pubDate>Sun, 10 Jul 2022 04:34:17 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Sat, 09 Jul 2022 18:02:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7508">@teastain</a></p>
<p dir="auto">yes, it works for me. I've tested it with pin 2 as RGB output, pin 5 as digital output and the rest as digital inputs.</p>
<pre><code>    extio.setAllPinMode(DIGITAL_INPUT_MODE);
    extio.setPinMode(2, RGB_LED_MODE);
    extio.setPinMode(5, DIGITAL_OUTPUT_MODE);
<p dir="auto">P.S. be prepared that approval could take some time. In the past some of my pull-requests took almost a full year to be approved by M5Stack.</p>
]]></description><link>https://community.m5stack.com/post/17957</link><guid isPermaLink="true">https://community.m5stack.com/post/17957</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 09 Jul 2022 18:02:17 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Sat, 09 Jul 2022 17:52:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> Thanks Felix, I'll try it once The Powers That Be approve !!!<br />
Does it work for you?<br />
Thanks Terry</p>
]]></description><link>https://community.m5stack.com/post/17956</link><guid isPermaLink="true">https://community.m5stack.com/post/17956</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sat, 09 Jul 2022 17:52:30 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Sat, 09 Jul 2022 17:46:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi! <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/111">@macsbug</a> thanks for responding, I usually use the Adafruit library because it Works! Easily! Logically!<br />
Actually I'm referring to the Stamp io2 ext module which is accessed via I2C.<br />
The resident controller is an STM, the Stamp has to send the request through I2C and be executed by the STM !<br />
Terry</p>
]]></description><link>https://community.m5stack.com/post/17955</link><guid isPermaLink="true">https://community.m5stack.com/post/17955</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Sat, 09 Jul 2022 17:46:21 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Fri, 08 Jul 2022 12:41:49 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7508">@teastain</a></p>
<p dir="auto">I've just created a <a href="https://github.com/m5stack/M5Unit-EXTIO2/pull/1" target="_blank" rel="noopener noreferrer nofollow ugc">pull-request</a> in the github repository which adds a function to set the mode of a single pin.</p>
]]></description><link>https://community.m5stack.com/post/17949</link><guid isPermaLink="true">https://community.m5stack.com/post/17949</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 08 Jul 2022 12:41:49 GMT</pubDate></item><item><title><![CDATA[Reply to Stamp ext IO2 (SKU:S002) able to use individual pins, not just one mode for the whole board! on Fri, 08 Jul 2022 09:02:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7508">@teastain</a> thanks, it’s sat on my bench waiting to be tested but been busy with writing up other documents</p>
]]></description><link>https://community.m5stack.com/post/17948</link><guid isPermaLink="true">https://community.m5stack.com/post/17948</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 08 Jul 2022 09:02:27 GMT</pubDate></item></channel></rss>
