<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Home Server Environmental monitoring]]></title><description><![CDATA[<p dir="auto">I've been out of programming for about 30+years, and never really into IoT, buy not after seeing what SSP32's can do, thanks to DavesGarage a YouTube Channel, I like to start a project I had in mind for a little while no, but of course I no idea where to start.</p>
<p dir="auto">I like to setup up environmental monitoring my home server room, I been using a red alert setup, however, it's quite underwhelming and seems flaky as best, so i like to make a suitable replacing, I like to monitor</p>
<li>3 Independent power (on/off and voltage)</li>
<li>Outside/Inside Temperature and humidity</li>
<li>3 ESXI Servers (Heartbeat)</li>
<li>Several IPs can be pinged.</li>
<li>Door Open/Closed (read switch already in place)</li>
<li>like to use the light tower if possible the rest is disposable,</li>
<li><a href="https://avtech.com/Products/Accessories/Light_Tower_Audio.htm" target="_blank" rel="noopener noreferrer nofollow ugc">https://avtech.com/Products/Accessories/Light_Tower_Audio.htm</a></li>
<li>Ethernet network connectivity.</li>
<li>Battery backup just in case.</li>
<li>with Information compiled to a json file</li>
<li>I like basic stats shown on a 10"+ LCD with the server room</li>
<p dir="auto">I would appreciate any pointer, be gentle it my first time :)</p>
]]></description><link>https://community.m5stack.com/topic/4402/home-server-environmental-monitoring</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 04:19:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4402.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Jun 2022 11:35:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Home Server Environmental monitoring on Mon, 08 Jul 2024 08:04:32 GMT]]></title><description><![CDATA[<p dir="auto">That sounds like a great project, peter2cfu! Building an environmental monitor with an M5Stack is a perfect way to get started with IoT.  The light tower sounds like a cool addition for a quick visual status check.  There are some great tutorials out there for M5Stack and ESP32 that should help you get going with the sensors and coding.  Good luck</p>
]]></description><link>https://community.m5stack.com/post/25778</link><guid isPermaLink="true">https://community.m5stack.com/post/25778</guid><dc:creator><![CDATA[mattarnold700]]></dc:creator><pubDate>Mon, 08 Jul 2024 08:04:32 GMT</pubDate></item></channel></rss>
