<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using Dual Button Unit and OP 90 Unit?]]></title><description><![CDATA[<p dir="auto">I wanted to use an OP-90 and a Dual Button Units together. I connected them to Port B on a M5 Fire through a 3 - 1 hub. I realized that they both use pin 36. Is there a way to change that? How can I use them together, many thanks!</p>
]]></description><link>https://community.m5stack.com/topic/4378/using-dual-button-unit-and-op-90-unit</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 14:51:44 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4378.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jun 2022 05:37:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using Dual Button Unit and OP 90 Unit? on Mon, 20 Jun 2022 22:26:22 GMT]]></title><description><![CDATA[<p dir="auto">Thank you, you are brilliant. It is not the answer I was looking for, but thanks for explaining. I hope the world has more people like you who are willing to help a beginner. I want to be creative with technology, but don't want to be a engineer.</p>
]]></description><link>https://community.m5stack.com/post/17775</link><guid isPermaLink="true">https://community.m5stack.com/post/17775</guid><dc:creator><![CDATA[ghettokon]]></dc:creator><pubDate>Mon, 20 Jun 2022 22:26:22 GMT</pubDate></item><item><title><![CDATA[Reply to Using Dual Button Unit and OP 90 Unit? on Mon, 20 Jun 2022 22:24:34 GMT]]></title><description><![CDATA[<p dir="auto">Okay, based on the documentation, 1-3 hub is a hardware extender which does not change units' addresses, only extend them. If the input units share the same addresses, they will interfere each other. The solution is to use a pBhub instead.</p>
]]></description><link>https://community.m5stack.com/post/17774</link><guid isPermaLink="true">https://community.m5stack.com/post/17774</guid><dc:creator><![CDATA[ghettokon]]></dc:creator><pubDate>Mon, 20 Jun 2022 22:24:34 GMT</pubDate></item><item><title><![CDATA[Reply to Using Dual Button Unit and OP 90 Unit? on Mon, 20 Jun 2022 22:04:55 GMT]]></title><description><![CDATA[<p dir="auto">I realized Mini Button unit, OP 90 and 180 unit, Dual Button Unit examples are all using pin 36. Does that mean I can't use them together as separate inputs? There must be a way!</p>
]]></description><link>https://community.m5stack.com/post/17773</link><guid isPermaLink="true">https://community.m5stack.com/post/17773</guid><dc:creator><![CDATA[ghettokon]]></dc:creator><pubDate>Mon, 20 Jun 2022 22:04:55 GMT</pubDate></item></channel></rss>
