<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raspberry pi Model 4 + M5stack Unit v2 M12]]></title><description><![CDATA[<p dir="auto">Hi ,<br />
I'm having a problem while connecting my m5stack unit v2 to my raspberry pi via usb , i can access to the wweb server and everything works fine but the internet for the raspberry pi shuts down instantly and can't run anything except the web server. I really need help<br />
Thank you</p>
]]></description><link>https://community.m5stack.com/topic/4228/raspberry-pi-model-4-m5stack-unit-v2-m12</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 23:18:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4228.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 Apr 2022 14:15:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Raspberry pi Model 4 + M5stack Unit v2 M12 on Wed, 02 Apr 2025 05:20:28 GMT]]></title><description><![CDATA[<p dir="auto">For improved performance, use a <strong><a href="https://robocraze.com/products/raspberry-pi-4-model-b-4gb-ram" target="_blank" rel="noopener noreferrer nofollow ugc">Raspberry Pi 4 (4GB)</a></strong>, which <strong><a href="https://robocraze.com/" target="_blank" rel="noopener noreferrer nofollow ugc">Robocraze</a></strong> sells. They are the authorized seller of Raspberry Pi Boards in India. For the last two months, I have been using this configuration without any problems. Conflicts over power or networks may be the source of your issue. Have you looked into if the M5Stack Unit V2 is using the USB excessively? Consider using a separate power source for the M5Stack or a powered USB hub.</p>
]]></description><link>https://community.m5stack.com/post/28804</link><guid isPermaLink="true">https://community.m5stack.com/post/28804</guid><dc:creator><![CDATA[sanjaay]]></dc:creator><pubDate>Wed, 02 Apr 2025 05:20:28 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry pi Model 4 + M5stack Unit v2 M12 on Sat, 23 Apr 2022 06:24:06 GMT]]></title><description><![CDATA[<p dir="auto">Ahh, you have a 5GHZ router only. thats a pain.<br />
That explains it.<br />
You need (as far as I understand) a second wifi receiver (usb dongle) plugged into the PI set to 2.4Ghz and leave the PI's internal set to 5GHZ and set up a bridge/host/router. I'm not sure how to do this as I don't know about enough about the PI (only just got one!)</p>
]]></description><link>https://community.m5stack.com/post/17274</link><guid isPermaLink="true">https://community.m5stack.com/post/17274</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 23 Apr 2022 06:24:06 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry pi Model 4 + M5stack Unit v2 M12 on Sat, 23 Apr 2022 06:18:34 GMT]]></title><description><![CDATA[<p dir="auto">That's what the alternative i should use, unfortunately don't have access to internet router to change it to 2.4ghz tried with mobile hotspot but couldn't as the ip is not fixe the m5stack connects but i couldn't access through SSH.</p>
]]></description><link>https://community.m5stack.com/post/17272</link><guid isPermaLink="true">https://community.m5stack.com/post/17272</guid><dc:creator><![CDATA[Junior]]></dc:creator><pubDate>Sat, 23 Apr 2022 06:18:34 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry pi Model 4 + M5stack Unit v2 M12 on Sat, 23 Apr 2022 06:11:03 GMT]]></title><description><![CDATA[<p dir="auto">This sounds more like an RPI issue, Have you checked in the RPI forums?<br />
I've not seen this issue as I connect to the M5Stack Core2 over the Web and not the USB using an RP4.</p>
]]></description><link>https://community.m5stack.com/post/17267</link><guid isPermaLink="true">https://community.m5stack.com/post/17267</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 23 Apr 2022 06:11:03 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry pi Model 4 + M5stack Unit v2 M12 on Sat, 23 Apr 2022 05:59:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi ,<br />
I use The original Raspberry Pi 4 USB-C Power Supply UK Plug, I think there is some network confluence  when the M5stack is connected resulting on shutting the internet on the pi. Can't find documentation or topics about this problem.</p>
]]></description><link>https://community.m5stack.com/post/17266</link><guid isPermaLink="true">https://community.m5stack.com/post/17266</guid><dc:creator><![CDATA[Junior]]></dc:creator><pubDate>Sat, 23 Apr 2022 05:59:53 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry pi Model 4 + M5stack Unit v2 M12 on Fri, 22 Apr 2022 05:18:10 GMT]]></title><description><![CDATA[<p dir="auto">Have you got a correct PSU powering the Pi4?<br />
The Pi4 is a hungry beast compared to previous versions and I managed to kill several SDCards before discovering the PSU was to blame.</p>
]]></description><link>https://community.m5stack.com/post/17251</link><guid isPermaLink="true">https://community.m5stack.com/post/17251</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 22 Apr 2022 05:18:10 GMT</pubDate></item></channel></rss>
