<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Burner does not work in MacOX 12.3.]]></title><description><![CDATA[<p dir="auto">Hi, everyone!<br />
M5Burner does not work in MacOX 12.3. I checked it to work in 12.2. I heard 12.3 deletes python module. I tried to install python2 to run M5 Burner. But it does not work. I would like to use UI Flow. So, M5burner need to install UI Flow.   Do you have any idea?</p>
oyouji</p>
]]></description><link>https://community.m5stack.com/topic/4140/m5burner-does-not-work-in-macox-12-3</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 22:18:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4140.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Mar 2022 04:00:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Tue, 05 Jul 2022 15:58:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/22443">@yu_with_a_mission</a> said in <a href="/post/17916">M5Burner does not work in MacOX 12.3.</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/19217">@yopita</a><br />
I tried you way and get another error,<br />
"File"/Applications/M5Burner.app/Contents/Resources/packages/tools/serial/tools/list_ports_osx.py", line 32, in &lt;module&gt;<br />
kIOMasterPortDefault = ctypes.c_void_p.in_dll(iokit, "kIOMasterPortDefault")<br />
ValueError: dlsym(RTLD_DEFAULT, kIOMasterPortDefault): symbol not found</p>
<p dir="auto">=================<br />
Burn Failed<br />
================="<br />
How can I solve?</p>
<p dir="auto">System:<br />
MacOS Monterey 12.4<br />
Device:<br />
M5StickCPlus</p>
<p dir="auto">There is an Issue Montery.<br />
Have you installed Xcode from the App Store?<br />
Have you instilled the latest Python 3 from the python site?<br />
Have you installed the drivers?<br />
Have you set the PATH variable correctly?<br />
Have you copied the M5Burner V3 to the Applications folder?<br />
Have you erased the controller first before writing the correct firmware?</p>
]]></description><link>https://community.m5stack.com/post/17921</link><guid isPermaLink="true">https://community.m5stack.com/post/17921</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 05 Jul 2022 15:58:57 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Tue, 05 Jul 2022 10:19:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/19217">@yopita</a><br />
Burn Failed<br />
Device:<br />
M5StickCPlus</p>
]]></description><link>https://community.m5stack.com/post/17916</link><guid isPermaLink="true">https://community.m5stack.com/post/17916</guid><dc:creator><![CDATA[yu_with_a_mission]]></dc:creator><pubDate>Tue, 05 Jul 2022 10:19:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Fri, 27 May 2022 13:34:40 GMT]]></title><description><![CDATA[<p dir="auto">hello,<br />
I could resolve the problem by changing the part of putting a symbokic link like below.</p>
<p dir="auto"><strong>sudo ln -s /opt/homebrew/bin/python3 /usr/local/bin/python</strong></p>
<p dir="auto">The install path of python3 with homebrew is changed to /opt/homebrew/bin directory as the default in M1 mac.</p>
MacOS Monterey 12.3.1 (Macbook Pro 2021 M1 Pro Max)</p>
<p dir="auto">Device<br />
M5Stack Fire</p>
]]></description><link>https://community.m5stack.com/post/17591</link><guid isPermaLink="true">https://community.m5stack.com/post/17591</guid><dc:creator><![CDATA[mashimolab]]></dc:creator><pubDate>Fri, 27 May 2022 13:34:40 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Tue, 03 May 2022 23:04:13 GMT]]></title><description><![CDATA[<p dir="auto">I updated today to macOS Monterey V 12.3.1 and everything is fine with M5Burner MacOS x64 v3.0</p>
]]></description><link>https://community.m5stack.com/post/17384</link><guid isPermaLink="true">https://community.m5stack.com/post/17384</guid><dc:creator><![CDATA[plusulli]]></dc:creator><pubDate>Tue, 03 May 2022 23:04:13 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Mon, 25 Apr 2022 16:02:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/19511">@rickkaye</a> Take a look in "Security and preferences" to see if the driver has been blocked.</p>
]]></description><link>https://community.m5stack.com/post/17290</link><guid isPermaLink="true">https://community.m5stack.com/post/17290</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 25 Apr 2022 16:02:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Mon, 25 Apr 2022 04:44:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/19511">@rickkaye</a> Try to turn M5stack off, then plug it in! Do not turn it  on by yourself.</p>
]]></description><link>https://community.m5stack.com/post/17289</link><guid isPermaLink="true">https://community.m5stack.com/post/17289</guid><dc:creator><![CDATA[oyouji]]></dc:creator><pubDate>Mon, 25 Apr 2022 04:44:39 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Sun, 24 Apr 2022 19:11:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/19413">@waqast</a> When I follow these instructions, wchusbmodem does not show up as an available port in M5Burner. I checked in /dev and it is not there. The only port that M5Burner offers to me is /dev/tty.Bluetooth-Incoming-Port. My hardware is 2017 iMac5k MacOS Monterey12.3.1, M5Stack Core. Can anyone help?</p>
]]></description><link>https://community.m5stack.com/post/17288</link><guid isPermaLink="true">https://community.m5stack.com/post/17288</guid><dc:creator><![CDATA[rickkaye]]></dc:creator><pubDate>Sun, 24 Apr 2022 19:11:38 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Sat, 23 Apr 2022 06:29:43 GMT]]></title><description><![CDATA[<p dir="auto">You need to set the path in BASH's environment setting (if bash is still used) google for setting Micropython Environmental Patch in OSX. I can't help because my OSX is several version behind and won't be updated until I can afford to by a new MAC.</p>
]]></description><link>https://community.m5stack.com/post/17276</link><guid isPermaLink="true">https://community.m5stack.com/post/17276</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 23 Apr 2022 06:29:43 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Thu, 21 Apr 2022 14:11:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/19413">@waqast</a></p>
<p dir="auto">I couldn't solve it.</p>
<p dir="auto">When I input this command</p>
<p dir="auto">$ sudo ln -s /usr/local/bin/python3 /usr/local/bin/python</p>
<p dir="auto">it comes out this message</p>
<p dir="auto">ln: /usr/local/bin/python: File exists</p>
<p dir="auto">Do someone know how to solve this?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/post/17240</link><guid isPermaLink="true">https://community.m5stack.com/post/17240</guid><dc:creator><![CDATA[westwoodhk]]></dc:creator><pubDate>Thu, 21 Apr 2022 14:11:53 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Tue, 19 Apr 2022 21:10:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/19217">@yopita</a><br />
<a href="https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139#issuecomment-1014816668" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Xinyuan-LilyGO/LilyGo-T-Call-SIM800/issues/139#issuecomment-1014816668</a></p>
<p dir="auto">It worked for me</p>
<p dir="auto"><strong>System:</strong><br />
MacOS Monterey 12.3.1 (Macbook Pro 2019 Intel)</p>
<p dir="auto"><strong>Device</strong><br />
M5Stack Core2</p>
<li>Install the driver CH9102_VCP_MacOS_v1.7 &gt; CH34xVCPDriver.pkg</li>
<li>Run the app CH34xVCPDriver in Applicatoins</li>
<li>GO TO Security on Settings and allow the app to run</li>
<li>Start Terminal App.</li>
<li>Install homebrew.<br />
Please refer to the installation on the page : <a href="https://brew.sh/" target="_blank" rel="noopener noreferrer nofollow ugc">https://brew.sh/</a></li>
<li>Install python3<br />
Please type the command.<br />
<em>$ brew install python3</em></li>
<li>Put a symbolic link<br />
<em>$ sudo ln -s /usr/local/bin/python3 /usr/local/bin/python</em></li>
<li>Start M5Burner on Terminal<br />
<em>$ /Applications/M5Burner.app/Contents/MacOS/electron-m5burner-v2-eletron</em></li>
<li>Select COM port <strong>wchusbmodem</strong></li>
]]></description><link>https://community.m5stack.com/post/17230</link><guid isPermaLink="true">https://community.m5stack.com/post/17230</guid><dc:creator><![CDATA[waqast]]></dc:creator><pubDate>Tue, 19 Apr 2022 21:10:38 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Thu, 14 Apr 2022 15:47:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/19217">@yopita</a> said in <a href="/post/17179">M5Burner does not work in MacOX 12.3.</a>:</p>
<p dir="auto">I had the same problem.<br />
I referred to joshrhyked's post, and I succeed burn with the following steps.</p>
<li>
<p dir="auto">Start Terminal App.</p>
</li>
<li>
<p dir="auto">Install homebrew.<br />
Please refer to the installation on the page.<br />
<a href="https://brew.sh/" target="_blank" rel="noopener noreferrer nofollow ugc">https://brew.sh/</a></p>
</li>
<li>
<p dir="auto">Install python3<br />
$ brew install python3</p>
</li>
<li>
<p dir="auto">Put a symbolic link<br />
</li>
<li>
<p dir="auto">Start M5Burner on Terminal<br />
$ /Applications/M5Burner.app/Contents/MacOS/electron-m5burner-v2-eletron</p>
</li>
<p dir="auto">best of luck to you!</p>
<p dir="auto">Step 4 is not correct but I see it worked for you.<br />
Open terminal and go to settings, you should be able to add  /usr/local/bin/python3 to the environmental setting or find the environmental file and add it it there.</p>
]]></description><link>https://community.m5stack.com/post/17180</link><guid isPermaLink="true">https://community.m5stack.com/post/17180</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 14 Apr 2022 15:47:56 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Thu, 14 Apr 2022 07:32:39 GMT]]></title><description><![CDATA[<p dir="auto">I had the same problem.<br />
<li>
</li>
<li>
</li>
<li>
</li>
<li>
</li>
<li>
</li>
]]></description><link>https://community.m5stack.com/post/17179</link><guid isPermaLink="true">https://community.m5stack.com/post/17179</guid><dc:creator><![CDATA[yopita]]></dc:creator><pubDate>Thu, 14 Apr 2022 07:32:39 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Thu, 07 Apr 2022 17:03:01 GMT]]></title><description><![CDATA[<p dir="auto">this is the error I get</p>
<p dir="auto">Uncaught Exception:<br />
Error: spawn python ENOENT<br />
at Process.ChildProcess._handle.onexit (internal/child_process.js:264:19)<br />
at onErrorNT (internal/child_process.js:456:16)<br />
at processTicksAndRejections (internal/process/task_queues.js:80:21)</p>
]]></description><link>https://community.m5stack.com/post/17126</link><guid isPermaLink="true">https://community.m5stack.com/post/17126</guid><dc:creator><![CDATA[lmartu68]]></dc:creator><pubDate>Thu, 07 Apr 2022 17:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Thu, 07 Apr 2022 16:59:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I tried re installing python 3 and running the executable from the command line but I get a Java error<br />
Has anyone got this to work?<br />
Its frustrating!</p>
]]></description><link>https://community.m5stack.com/post/17125</link><guid isPermaLink="true">https://community.m5stack.com/post/17125</guid><dc:creator><![CDATA[lmartu68]]></dc:creator><pubDate>Thu, 07 Apr 2022 16:59:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Fri, 25 Mar 2022 00:12:21 GMT]]></title><description><![CDATA[<p dir="auto">Same problem here. Program become non-responsive, requires Force Quit.</p>
]]></description><link>https://community.m5stack.com/post/17016</link><guid isPermaLink="true">https://community.m5stack.com/post/17016</guid><dc:creator><![CDATA[Boomvalt]]></dc:creator><pubDate>Fri, 25 Mar 2022 00:12:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Wed, 23 Mar 2022 13:35:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/18350">@oyouji</a> I found a workaround to get the M5Burner working. I installed pyenv with Homebrew and then installed python3 using pyenv. I then had to launch M5Burner from the command line so it had access to the newly installed python3. I did this buy running "/Applications/M5Burner.app/Contents/MacOS/electron-m5burner-v2-eletron".</p>
]]></description><link>https://community.m5stack.com/post/17000</link><guid isPermaLink="true">https://community.m5stack.com/post/17000</guid><dc:creator><![CDATA[joshrhykerd]]></dc:creator><pubDate>Wed, 23 Mar 2022 13:35:18 GMT</pubDate></item><item><title><![CDATA[Reply to M5Burner does not work in MacOX 12.3. on Tue, 22 Mar 2022 20:37:50 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm this issue. I am also unable to use the M5Burner on macOS Monterey 12.3.</p>
]]></description><link>https://community.m5stack.com/post/16994</link><guid isPermaLink="true">https://community.m5stack.com/post/16994</guid><dc:creator><![CDATA[joshrhykerd]]></dc:creator><pubDate>Tue, 22 Mar 2022 20:37:50 GMT</pubDate></item></channel></rss>
