<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5core Ink battery duration]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am planning to use the M5Core Ink as a temperature sensor, but the device runs out of battery after about 12hrs or so even using m5.shutdown . (my goals would be 6 months+ of lifespan)</p>
<p dir="auto">To get a standard example, I used the M5core Ink NTP project (<a href="https://github.com/hpsaturn/m5coreink-ntp-clock" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/hpsaturn/m5coreink-ntp-clock</a>) that seems well known to compare with others.</p>
<p dir="auto">I am charging the battery for 6 hours before running on battery.<br />
With the default 1 minute shutdown and using RTC to wake the device up, the battery still does not last more than 12 hours. The device is only staying up a couple seconds to getRTC, and should go back in deepsleep through shutdown. I tried longer shutdown (5min), but that did not increase the battery life even though I could see that clock was refreshed only every 5 minutes.</p>
<p dir="auto">Using <a href="https://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-battery-life" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-battery-life</a> for battery duration, the battery being 390mAh and device using 0.0025mA (according to <a href="https://www.gwendesign.ch/kb/m5stack/m5coreink/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.gwendesign.ch/kb/m5stack/m5coreink/</a>) in shutdown, I should expect months at least.</p>
<p dir="auto">Has anyone data to compare or recommendations?</p>
<p dir="auto">Thank you</p>
]]></description><link>https://community.m5stack.com/topic/4116/m5core-ink-battery-duration</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 05:07:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4116.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Mar 2022 18:41:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5core Ink battery duration on Fri, 25 Mar 2022 12:25:41 GMT]]></title><description><![CDATA[<p dir="auto">My battery duration seems longer: the program I ran Tuesday is still running "more or less". By "more or less" I mean that sometimes I find the M5 with a black screen, and I have to press the POWER ON button to wake it up. I shouldn't need to do that, so this strange. But at least with the counter displayed on the screen, I know my program ran for 72 hours (indeed more or less 3 days).</p>
<p dir="auto">Difference with yours:</p>
<li>I do not connect to a Wifi / Internet (which usually consumes battery quite a lot)</li>
]]></description><link>https://community.m5stack.com/post/17021</link><guid isPermaLink="true">https://community.m5stack.com/post/17021</guid><dc:creator><![CDATA[aafortinet]]></dc:creator><pubDate>Fri, 25 Mar 2022 12:25:41 GMT</pubDate></item><item><title><![CDATA[Reply to M5core Ink battery duration on Tue, 22 Mar 2022 17:18:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/14973">@eddie2070</a> ok - got the answer for <code>shutdown()</code>: it only works when powered from battery. So, I've created a small test program that just displays an image + counter, then shuts down for 1 hour. I'm going to see how long it lasts...</p>
]]></description><link>https://community.m5stack.com/post/16989</link><guid isPermaLink="true">https://community.m5stack.com/post/16989</guid><dc:creator><![CDATA[aafortinet]]></dc:creator><pubDate>Tue, 22 Mar 2022 17:18:59 GMT</pubDate></item><item><title><![CDATA[Reply to M5core Ink battery duration on Tue, 22 Mar 2022 12:42:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/14973">@eddie2070</a> said in <a href="/post/16893">M5core Ink battery duration</a>:</p>
<p dir="auto">With the default 1 minute shutdown</p>
<p dir="auto">Is the <code>M5.shutdown()</code> command working for you? Is it really sleeping for 1 minute? In my case, whatever delay I specify it sleeps for ~5 seconds no more!</p>
<p dir="auto">If you have the same issue, that could explain why you have battery duration issues ;-)</p>
]]></description><link>https://community.m5stack.com/post/16979</link><guid isPermaLink="true">https://community.m5stack.com/post/16979</guid><dc:creator><![CDATA[aafortinet]]></dc:creator><pubDate>Tue, 22 Mar 2022 12:42:50 GMT</pubDate></item><item><title><![CDATA[Reply to M5core Ink battery duration on Mon, 14 Mar 2022 15:38:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/14973">@eddie2070</a> interesting. Once you've collected the temperature, what are you doing with it? Just displaying it? or are you sending it via WiFi?<br />
I don't  have a temperature sensor, but I'm going to try on my side with a ultrasonic sensor and see how long it works.</p>
]]></description><link>https://community.m5stack.com/post/16926</link><guid isPermaLink="true">https://community.m5stack.com/post/16926</guid><dc:creator><![CDATA[aafortinet]]></dc:creator><pubDate>Mon, 14 Mar 2022 15:38:04 GMT</pubDate></item></channel></rss>
