<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow 1.9.2]]></title><description><![CDATA[<h3>v1.9.2</h3>
<h4>new features:</h4>
<li>ZH-CN:
<li>MODULE CATMIOT 支持</li>
<li>UNIT MIC 支持</li>
</li>
<li>EN:
<li>MODULE CATMIOT support</li>
<li>UNIT MIC support</li>
</li>
]]></description><link>https://community.m5stack.com/topic/4059/uiflow-1-9-2</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 20:35:04 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4059.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Feb 2022 09:45:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow 1.9.2 on Thu, 03 Mar 2022 09:37:12 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3966">@IAMLIUBO</a></p>
<p dir="auto">the MQTT block fails when trying to connect to HIVEMQ broker using SSL. I found that for a successful connection an additional parameter <code>server_hostname</code> in the <code>ssl_params</code> is required. Please see this <a href="https://community.m5stack.com/topic/4090/core2-hivemq/15">post</a>.</p>
]]></description><link>https://community.m5stack.com/post/16820</link><guid isPermaLink="true">https://community.m5stack.com/post/16820</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 03 Mar 2022 09:37:12 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.9.2 on Sat, 26 Feb 2022 10:33:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3966">@IAMLIUBO</a> Another issue with EZData:<br />
<img src="/assets/uploads/files/1645871573187-screenshot-2022-02-26-at-10.17.55-resized.png" alt="0_1645871572075_Screenshot 2022-02-26 at 10.17.55.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">When using this code, the EZData creates a list but then the Get Value from Topic block fails to retrieve any data or telemetry.</p>
]]></description><link>https://community.m5stack.com/post/16782</link><guid isPermaLink="true">https://community.m5stack.com/post/16782</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 26 Feb 2022 10:33:53 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.9.2 on Thu, 24 Feb 2022 18:42:34 GMT]]></title><description><![CDATA[<p dir="auto">EZData transits once or twice and then stops using the following example.<br />
<img src="/assets/uploads/files/1645728148918-ezdata_save_value_topic_example-resized.png" alt="0_1645728148440_EZDATA_Save_Value_topic_example.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/16764</link><guid isPermaLink="true">https://community.m5stack.com/post/16764</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 24 Feb 2022 18:42:34 GMT</pubDate></item></channel></rss>
