<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Lesson 19. LED BAR + MIC. LightMusic]]></title><description><![CDATA[<h2>The purpose of this lesson</h2>
<p dir="auto">Hi! Today we will learn how to light multi-color led panels (only in the fire M5), relying on the components of the frequency of the audio signal received from the built-in (only in M5 fire) microphone.</p>
<p dir="auto"><img src="https://pp.userapi.com/c848632/v848632099/a9b77/g_X4K5MCSG0.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 1</p>
<p dir="auto">This lesson will teach you how to connect and use third-party libraries to work with fast Fourier transform (FFT) and LEDs SK6818.</p>
<h2>Short help</h2>
<p dir="auto">Color music is an art form based on a person's ability to associate sound sensations with light perceptions; this phenomenon in neurology is called synesthesia. Light music as an art is a derivative of music and is an integral part of it. Its purpose is to reveal the essence of music through visual perception. The main purpose of light music as an art is to study the ability of a person to experience the sensations imposed by light images when accompanied by music.</p>
<p dir="auto">Music lovers have long noticed that musical instruments sound much louder and clearer in a well-lit room than in a darkened one. Therefore, when performing serious music, the light in the hall is usually not extinguished.</p>
<p dir="auto">For the first time the connection between hearing and vision was very convincingly shown by Russian physicist and Russian physiologist academician P. P. Lazarev.</p>
<p dir="auto">Details on Wiki: <a href="https://ru.wikipedia.org/wiki/%D0%A1%D0%B2%D0%B5%D1%82%D0%BE%D0%BC%D1%83%D0%B7%D1%8B%D0%BA%D0%B0" title="https://ru.wikipedia.org/wiki/Светомузыка" target="_blank" rel="noopener noreferrer nofollow ugc">https://ru.wikipedia.org/wiki/Светомузыка</a></p>
<p dir="auto"><strong>List of components for the lesson</strong></p>
<li>PC/MAC;</li>
<li>M5STACK FIRE;</li>
<li>USB-C cable from standard set.</li>
<h2>Let's start!</h2>
<h3>Step 1. The installation for the library with Led work bar</h3>
<p dir="auto">Go to the link <strong>library Led bar</strong> in the section <strong>Download</strong> and download an example of the library files (Fig. 2).</p>
<p dir="auto"><img src="https://pp.userapi.com/c848632/v848632099/a9bed/gg0WGm4Ocb4.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 2</p>
<p dir="auto">Next, extract the archive to a new folder <strong>sketch</strong> and delete the file <strong>demo1.ino</strong> (Fig. 3).</p>
<p dir="auto"><img src="https://pp.userapi.com/c850236/v850236619/6360a/aBQi_Mwq-dE.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 3</p>
<h3>Step 2. Installing the FFT library</h3>
<p dir="auto">Go to the link <strong>Arduino Library FFT</strong> in the section <strong>Download</strong> and download an example of the library files (Fig. 4).</p>
<p dir="auto"><img src="https://pp.userapi.com/c851016/v851016266/3d837/kL2jojv9TE4.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 4</p>
<p dir="auto">In the extracted contents folder and Then copied <strong>C:\Users\USER_NAME\Documents\Arduino\libraries</strong> new name <strong>arduinoFFT</strong> is <strong>arduinoFFT-master</strong> (Fig. 5).</p>
<p dir="auto"><img src="https://pp.userapi.com/c851016/v851016266/3d841/sySeWj6WcW4.jpg" alt="https://pp.userapi.com/c851016/v851016266/3d841/sySeWj6WcW4.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 5</p>
<p dir="auto">Great! With libraries all :)</p>
<h3>Step 3. Writing a sketch</h3>
<p dir="auto">Create a new sketch in the Arduino development environment and save it in the folder where the library files from step 1 are located (Fig. 6).</p>
<p dir="auto"><img src="https://pp.userapi.com/c851016/v851016670/3b30f/0_e5Sdhubsk.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 6</p>
<p dir="auto">Immediately connect the necessary libraries and create the necessary variables:</p>
#include "arduinoFFT.h"
#include "esp32_digital_led_lib.h"
arduinoFFT FFT = arduinoFFT();
#define SAMPLES 256 //Must be a power of 2
#define SAMPLING_FREQUENCY 10000 //Hz, must be 10000 or less due to ADC conversion time. Determines maximum frequency that can be analysed by the FFT.
#define amplitude 50
unsigned int sampling_period_us;
unsigned long microseconds;
byte peak[] = {0,0,0,0,0,0,0};
double vReal[SAMPLES];
double vImag[SAMPLES];
unsigned long newTime, oldTime;
strand_t m_sLeds = {.rmtChannel = 0, .gpioNum = 15, .ledType = LED_WS2812B_V3, .brightLimit = 32, .numPixels = 10, .pixels = nullptr, ._stateVars = nullptr};
<p dir="auto">For simplified access to the LED BAR, I suggest using the following function <strong>void ledBar (int R, int G, int B, int M)</strong>. Where <strong>int R</strong>, <strong>int G</strong>, <strong>int B</strong> - brightness of RED, GREEN and BLUE - respectively (from 0 to 255); <strong>int M</strong> - mode: from 0 to 9 - led number, 10 - all LEDs from the left panel, 11 - all LEDs from the right panel, 12 - all LEDs.</p>
<p dir="auto">The LEDs are arranged clockwise (Fig. 7).</p>
<p dir="auto"><img src="https://pp.userapi.com/c851016/v851016670/3b323/o1rDcZuddWk.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 7</p>
<p dir="auto"><img src="https://pp.userapi.com/c851016/v851016670/3b35d/qKDXIzdVAYY.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 7.1</p>
<pre><code>void ledBar(int R, int G, int B, int M) {
  if ((M &lt; 0) || (M &gt; 13)) return;
  if (M == 11) // right
    for (int i = 0; i &lt; 5; i++)
       m_sLeds.pixels[i] = pixelFromRGBW(R, G, B, 0);
  else if (M == 10) // left
    for (int i = 5; i &lt; 10; i++)
  else if (M == 12) // all
    for (int i = 0; i &lt; 10; i++)
  else
     m_sLeds.pixels[M] = pixelFromRGBW(R, G, B, 0);
  digitalLeds_updatePixels(&amp;m_sLeds);
<p dir="auto">Main part. Do not forget about <strong>void dacWrite(25, 0);</strong> that the speaker does not make strange sounds and cod.</p>
<pre><code>void setup(){
  M5.begin();
  pinMode(25, OUTPUT);
  pinMode(34, INPUT);
  sampling_period_us = round(1000000 * (1.0 / SAMPLING_FREQUENCY));
  pinMode(15, OUTPUT);
  digitalWrite (15, LOW);
  if (digitalLeds_initStrands(&amp;m_sLeds, 1)) {
    Serial.println("Can't init LED driver().");
  digitalLeds_resetPixels(&amp;m_sLeds);
<p dir="auto">Note that <strong>pinMode (34, INPUT)</strong> is the analog input to which the built-in microphone is connected (Fig. 8) through the amplifier, so set it to INPUT.</p>
<p dir="auto"><img src="https://pp.userapi.com/c851016/v851016670/3b375/Qa97V2tfKkk.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">Figure 8</p>
<pre><code>void loop() {
  for (int i = 0; i &lt; SAMPLES; i++) {
    newTime = micros() - oldTime;
    oldTime = newTime;
    vReal[i] = analogRead(34); // A conversion takes about 1mS on an ESP8266
    vImag[i] = 0;
    while (micros() &lt; (newTime + sampling_period_us));  // do nothing to wait
  FFT.Windowing(vReal, SAMPLES, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
  FFT.Compute(vReal, vImag, SAMPLES, FFT_FORWARD);
  FFT.ComplexToMagnitude(vReal, vImag, SAMPLES);
  dacWrite(25, 0);
  for (int i = 2; i &lt; (SAMPLES/2); i++){ // Don't use sample 0 and only first SAMPLES/2 are usable. Each array eleement represents a frequency and its value the amplitude.
    if (vReal[i] &gt; 200) { // Add a crude noise filter, 4 x amplitude or more
      if (i&lt;=5 )             displayBand(0,(int)vReal[i]/amplitude); // 125Hz
      if (i &gt;5   &amp;&amp; i&lt;=12 )  displayBand(1,(int)vReal[i]/amplitude); // 250Hz
      if (i &gt;12  &amp;&amp; i&lt;=32 )  displayBand(2,(int)vReal[i]/amplitude); // 500Hz
      if (i &gt;32  &amp;&amp; i&lt;=62 )  displayBand(3,(int)vReal[i]/amplitude); // 1000Hz
      if (i &gt;62  &amp;&amp; i&lt;=105 ) displayBand(4,(int)vReal[i]/amplitude); // 2000Hz
      if (i &gt;105 &amp;&amp; i&lt;=120 ) displayBand(5,(int)vReal[i]/amplitude); // 4000Hz
      if (i &gt;120 &amp;&amp; i&lt;=146 ) displayBand(6,(int)vReal[i]/amplitude); // 8000Hz
<p dir="auto">Light the LEDs will be using the function <strong>void displayBand (int band, int dsize)</strong>. Where <strong>band</strong> - frequency in the signal; <strong>dsize</strong> - number of frequency in the signal. You can safely experiment here and achieve the best flashes.</p>
<pre><code>void displayBand(int band, int dsize){
  if (band &gt; 1) dsize += 100;
  if (dsize &gt;= 150)
    ledBar(0, 0, 0, 12);
    if (band == 0)
      if (dsize &gt;= 300)
        ledBar(255, 0, 0, 0);
        ledBar(255, 0, 0, 1);
    else if (band == 1)
      if (dsize &gt;= 180)
        ledBar(255, 255, 0, 3);
        ledBar(255, 255, 0, 4);
    else if (band == 2)
      if (dsize &gt;= 170)
        ledBar(0, 255, 0, 5);
        ledBar(0, 255, 0, 6);
    else
      ledBar(0, 0, 255, 8);
      ledBar(0, 0, 255, 9);
<h3>Final step</h3>
<p dir="auto">That's all :)</p>
<h2>Downloads</h2>
<li>Library LED BAR (GitHub): <a href="https://github.com/MartyMacGyver/ESP32-Digital-RGB-LED-Drivers/tree/master/arduino-esp32/demo1" title="https://github.com/MartyMacGyver/ESP32-Digital-RGB-LED-Drivers/tree/master/arduino-esp32/demo1" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MartyMacGyver/ESP32-Digital-RGB-LED-Drivers/tree/master/arduino-esp32/demo1</a></li>
<li>Arduino FFT library (GitHub): <a href="https://github.com/kosme/arduinoFFT" title="https://github.com/kosme/arduinoFFT" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/kosme/arduinoFFT</a></li>
]]></description><link>https://community.m5stack.com/topic/402/lesson-19-led-bar-mic-lightmusic</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 19:23:19 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/402.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 07 Nov 2018 14:58:51 GMT</pubDate><ttl>60</ttl></channel></rss>
