<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[connect with usb to COM-NB-IOT-MODULESIM7020G fails]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I cant get  the USB port on sim7020g modem working. I just connect my PC with a terminal emulator.<br />
The board powers up (red led) and blinking blue NET LED.<br />
However I only get garbage characters on my terminal as if the speed was wrong.<br />
I have tried all speeds without success. Default is 115200 8N1.</p>
<p dir="auto">It generates 2 USB-devices as other modems like SARA R410 do.<br />
Should it be possible - any clues ?</p>
<p dir="auto">Olav</p>
]]></description><link>https://community.m5stack.com/topic/3841/connect-with-usb-to-com-nb-iot-modulesim7020g-fails</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 07:32:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3841.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 18 Dec 2021 14:48:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to connect with usb to COM-NB-IOT-MODULESIM7020G fails on Wed, 02 Feb 2022 18:33:58 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a>,<br />
I have now got the card powered by following your observations :<br />
connecting 5v to VIN, GND to GND, TX to RXD, RX to TXD<br />
I don't need to trigger PWK to get the modem operational.<br />
The modem don't connect to the network, but that's another problem..</p>
]]></description><link>https://community.m5stack.com/post/16488</link><guid isPermaLink="true">https://community.m5stack.com/post/16488</guid><dc:creator><![CDATA[olavk]]></dc:creator><pubDate>Wed, 02 Feb 2022 18:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to connect with usb to COM-NB-IOT-MODULESIM7020G fails on Tue, 21 Dec 2021 08:46:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/olavk" aria-label="Profile: olavk">@<bdi>olavk</bdi></a></p>
<p dir="auto">no, I don't think P/G is the on/off trigger. It seems to be connected to GND. I think PWK is the power key.</p>
<p dir="auto">Have a look at the COMX <a href="https://docs.m5stack.com/en/module/comx_nb-iot" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a>. You'll find this:</p>
<li>
<p dir="auto">P/G : is connected to GND</p>
</li>
<li>
<p dir="auto">GND : is connected to GND</p>
</li>
<li>
<p dir="auto">PWK : is connected to EN</p>
</li>
<li>
<p dir="auto">RXD : is connected to GPIO17, GPIO0 or GPIO17</p>
</li>
<li>
<p dir="auto">TXD : is connected to GPIO16, GPIO5 or GPIO15</p>
</li>
<li>
<p dir="auto">VIN : is connected to either 5.4 V or whatever is provided at the DC in</p>
</li>
<li>
<p dir="auto">VIN : dito</p>
</li>
<li>
<p dir="auto">VTTL : not connected</p>
</li>
<li>
<p dir="auto">VEXT : not connected</p>
</li>
<p dir="auto">How exactly this translates to an Arduino MKR Zero I cannot tell. I don't have one to try. Sorry.</p>
]]></description><link>https://community.m5stack.com/post/15903</link><guid isPermaLink="true">https://community.m5stack.com/post/15903</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 21 Dec 2021 08:46:03 GMT</pubDate></item><item><title><![CDATA[Reply to connect with usb to COM-NB-IOT-MODULESIM7020G fails on Sun, 19 Dec 2021 07:10:17 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> - Yes I mean the USB on the breakout board. The referred manual states : 'The SIM7020G contains a USB interface compliant with the USB1.1 specification as a peripheral'.<br />
And my intention was indeed to do debugging to see if the modem would connect to the network with my SIM before I start to connect it to my Arduino.</p>
<p dir="auto">Anyone that have a connection diagram for how to connect this breakout-board to an Arduino (MKR Zero),<br />
as I don't want to use the M5 Stack wrapping.</p>
<p dir="auto">So I have pins PWR, GND and P/G on one side and VIN VEXT and VTTL on the other side.<br />
Could I expect P/G to be the pin to trigger to power on/off ?</p>
]]></description><link>https://community.m5stack.com/post/15870</link><guid isPermaLink="true">https://community.m5stack.com/post/15870</guid><dc:creator><![CDATA[olavk]]></dc:creator><pubDate>Sun, 19 Dec 2021 07:10:17 GMT</pubDate></item><item><title><![CDATA[Reply to connect with usb to COM-NB-IOT-MODULESIM7020G fails on Sat, 18 Dec 2021 15:48:01 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/olavk" aria-label="Profile: olavk">@<bdi>olavk</bdi></a></p>
<p dir="auto">I assume you mean the USB port on the green board plugged into the COMX.NB-IoT module, correct?</p>
<p dir="auto">If yes, then according to the <a href="https://www.waveshare.com/wiki/File:SIM7020G_Hardware_Design_V1.00.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">SIM7020G Hardware Design Guide</a> - chapter: <em>1.4 Functional Overview</em> the USB port is meant for debugging. Maybe that means it cannot be used to issue AT commands?</p>
]]></description><link>https://community.m5stack.com/post/15861</link><guid isPermaLink="true">https://community.m5stack.com/post/15861</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 18 Dec 2021 15:48:01 GMT</pubDate></item></channel></rss>
