<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using IR Remote sensor with PbHub]]></title><description><![CDATA[<p dir="auto">I have been exprimenting with using sensors on an M5Stack fire via a PaHub and a PbHub. Here is simple working example for a button module:<br />
*// Important! Set Tools-PSRAM to Disabled otherwise M5Stack display hangs.</p>
<p dir="auto">#include &lt;Wire.h&gt;<br />
#include "ClosedCube_TCA9548A.h"<br />
#include &lt;M5Stack.h&gt;<br />
#define PaHub_I2C_ADDRESS  0x70<br />
ClosedCube::Wired::TCA9548A tca9548a;<br />
#include "porthub.h"</p>
<p dir="auto">#define X_OFFSET 10<br />
#define Y_OFFSET 18</p>
<p dir="auto">PortHub porthub;<br />
uint8_t HUB_ADDR[6] = {HUB1_ADDR, HUB2_ADDR, HUB3_ADDR, HUB4_ADDR, HUB5_ADDR, HUB6_ADDR};</p>
<p dir="auto">M5.begin();<br />
M5.Power.begin();<br />
delay(50);<br />
Serial.begin(115200);           // Initialize serial communications with the PC<br />
Wire.begin();                   // Initialize I2C<br />
uint8_t returnCode = 0;<br />
uint8_t channel = 0;<br />
tca9548a.address(PaHub_I2C_ADDRESS);<br />
returnCode = tca9548a.selectChannel(channel);<br />
Serial.print("returnCode = ");<br />
Serial.println(returnCode);<br />
<a href="//Wire.beginTransmission" target="_blank" rel="noopener noreferrer nofollow ugc">//Wire.beginTransmission</a>(channel);<br />
//returnCode = Wire.endTransmission();</p>
<p dir="auto">M5.Lcd.clear(BLACK);<br />
M5.Lcd.setTextColor(YELLOW);<br />
M5.Lcd.setTextSize(2);<br />
M5.Lcd.setCursor(30, 0); M5.Lcd.println("Button/Hub example");<br />
Serial.println("Button/Hub example: ");<br />
M5.Lcd.setTextColor(WHITE);<br />
<p dir="auto">/*<br />
Description: Read the button status of BUTTON Unit and display it on the screen<br />
*/<br />
#include &lt;M5Stack.h&gt;</p>
<p dir="auto">int last_value_A = 0;<br />
int cur_value_A = 0;<br />
int last_value_B = 0;<br />
int cur_value_B = 0;</p>
cur_value_A = porthub.hub_d_read_value_A(HUB_ADDR[2]);// read the value of A-BUTTON<br />
cur_value_B = porthub.hub_d_read_value_B(HUB_ADDR[2]);// read the value of B-BUTTON</p>
<p dir="auto">M5.Lcd.setCursor(0, 25); M5.Lcd.print("Status A: ");<br />
M5.Lcd.setCursor(0, 45); M5.Lcd.print("Value A: ");<br />
M5.Lcd.setCursor(0, 65); M5.Lcd.print("Status B: ");<br />
M5.Lcd.setCursor(0, 85); M5.Lcd.print("Value B: ");<br />
if (cur_value_A != last_value_A) {<br />
Serial.print("A = ");<br />
Serial.print(cur_value_A);<br />
M5.Lcd.fillRect(110, 25, 100, 25, BLACK);<br />
M5.Lcd.fillRect(95, 45, 100, 25, BLACK);<br />
if (cur_value_A == 0) {<br />
M5.Lcd.setCursor(110, 25); M5.Lcd.print("pressed"); // display the status<br />
M5.Lcd.setCursor(95, 45); M5.Lcd.print("0");<br />
Serial.println("Button Status: pressed");<br />
Serial.println("       value:  0");<br />
}<br />
else {<br />
M5.Lcd.setCursor(110, 25); M5.Lcd.print("released"); // display the status<br />
M5.Lcd.setCursor(95, 45); M5.Lcd.print("1");<br />
Serial.println("Button Status: released");<br />
Serial.println("       value:  1");<br />
<pre><code>last_value_A = cur_value_A;
<p dir="auto">}</p>
<p dir="auto">if (cur_value_B != last_value_B) {<br />
Serial.print("B = ");<br />
Serial.print(cur_value_B);<br />
M5.Lcd.fillRect(110, 65, 100, 25, BLACK);<br />
M5.Lcd.fillRect(95, 85, 100, 25, BLACK);</p>
<pre><code>if (cur_value_B == 0) {
  M5.Lcd.setCursor(110, 65); M5.Lcd.print("pressed"); // display the status
  M5.Lcd.setCursor(95, 85); M5.Lcd.print("0");
else {
  M5.Lcd.setCursor(110, 65); M5.Lcd.print("released"); // display the status
  M5.Lcd.setCursor(95, 85); M5.Lcd.print("1");
last_value_B = cur_value_B;
<p dir="auto">}<br />
M5.update();<br />
}*</p>
<p dir="auto">I have got several simple M5Stack sensors working this way. I canor however get the IR Remote module to work even just via the PbHub. The problem is that when connected directly the sketch normally reads pin 36 by including "int IR_RECEIVE_PIN = 36;" in the sketch. But my problem is how to do this via the PbHub? I have tried "int IR_RECEIVE_PIN="porthub.hub_a_read_value(HUB_ADDR[i2):" and other commands from porthub.h but then the address is read only once.</p>
<p dir="auto">How can I use PbHub and porthub.h to acheive the same effect I get from connecting directly to pin 36?</p>
]]></description><link>https://community.m5stack.com/topic/3740/using-ir-remote-sensor-with-pbhub</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Mar 2026 08:14:20 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3740.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Nov 2021 20:22:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using IR Remote sensor with PbHub on Sun, 14 Nov 2021 13:22:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/6180">@Steve1</a></p>
<p dir="auto">sorry, at this point in time I am out of ideas. I don't have the IR remote sensor so I cannot test this myself. Hopefully somebody else can help you.</p>
]]></description><link>https://community.m5stack.com/post/15470</link><guid isPermaLink="true">https://community.m5stack.com/post/15470</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 14 Nov 2021 13:22:54 GMT</pubDate></item><item><title><![CDATA[Reply to Using IR Remote sensor with PbHub on Sun, 14 Nov 2021 12:53:11 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, but I still cannot read the Serial.read() from "porthub.hub_a_read_value(HUB_ADDR[2]);"</p>
]]></description><link>https://community.m5stack.com/post/15468</link><guid isPermaLink="true">https://community.m5stack.com/post/15468</guid><dc:creator><![CDATA[Steve1]]></dc:creator><pubDate>Sun, 14 Nov 2021 12:53:11 GMT</pubDate></item><item><title><![CDATA[Reply to Using IR Remote sensor with PbHub on Sun, 14 Nov 2021 07:47:25 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/6180">@Steve1</a></p>
<p dir="auto">try replacing this line</p>
<pre><code>cur_recv_value = digitalRead(ir_recv_pin);
<p dir="auto">with something like this:</p>
<pre><code>cur_recv_value = porthub.hub_a_read_value(HUB_ADDR[2]);
]]></description><link>https://community.m5stack.com/post/15466</link><guid isPermaLink="true">https://community.m5stack.com/post/15466</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 14 Nov 2021 07:47:25 GMT</pubDate></item></channel></rss>
