<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Fire questions...]]></title><description><![CDATA[<p dir="auto">Just got my M5Stack Fire.</p>
<li>
<p dir="auto">First off, if I use the Arduino IDE, I see only the regular program space. (<code>Maximum is 1310720 bytes.</code>). Should this have way more flash? How do we use it?</p>
</li>
<li>
<p dir="auto">Also, the M5Stack-CORE-ESP32 board setting came with Tools/Partition scheme where you could select "Normal, "No OTA" or "Minimal SPIFFS", all are gone. I know I can manually edit the boards,txt file to fix this, but is there any reason this is the way it is?</p>
</li>
<li>
<p dir="auto">One of the M5ez users says one of his LEDs wakes up blue when using M5ez: I do not see this myself. Are there different versions of the Fire?</p>
</li>
]]></description><link>https://community.m5stack.com/topic/363/m5stack-fire-questions</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 19:54:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/363.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Oct 2018 15:26:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Fire questions... on Sun, 14 Oct 2018 08:03:08 GMT]]></title><description><![CDATA[<p dir="auto">I want to add</p>
<li>Upload a complete M5Stack Fire schematic of the current revision. There is none in the docs.</li>
]]></description><link>https://community.m5stack.com/post/1719</link><guid isPermaLink="true">https://community.m5stack.com/post/1719</guid><dc:creator><![CDATA[PlayTheGame]]></dc:creator><pubDate>Sun, 14 Oct 2018 08:03:08 GMT</pubDate></item></channel></rss>
