<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow 1.8.3]]></title><description><![CDATA[<p dir="auto">Ver 1.8.3  time: 2021.0827</p>
<h3>v1.8.3</h3>
<h4>new features:</h4>
<li>Add UNIT FADER support</li>
<li>Add Module stepmotor driver support</li>
<li>ESP-NOW support encrypt(LMK)</li>
<li>New Vfunciton for UNIT V2</li>
<h4>Bug fix:</h4>
<li>Fix NB-IoT MQTT downlink data parse error</li>
<li>Fix ATOM-DTU Modbus UART ID error</li>
]]></description><link>https://community.m5stack.com/topic/3544/uiflow-1-8-3</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 03:38:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3544.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Aug 2021 09:20:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow 1.8.3 on Tue, 31 Aug 2021 13:31:11 GMT]]></title><description><![CDATA[<p dir="auto">The range of ids of the Set id block in myCobot is wrong. It should be from 1 to 6, but from 2 to 7.</p>
]]></description><link>https://community.m5stack.com/post/14773</link><guid isPermaLink="true">https://community.m5stack.com/post/14773</guid><dc:creator><![CDATA[saitotetsuya]]></dc:creator><pubDate>Tue, 31 Aug 2021 13:31:11 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.8.3 on Mon, 30 Aug 2021 06:31:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plusulli" aria-label="Profile: plusulli">@<bdi>plusulli</bdi></a></p>
<p dir="auto">add this block after any draw.</p>
<p dir="auto"><img src="/assets/uploads/files/1630304660486-73219f06-91bc-48ac-8f1e-f1b2d2ef6353-44efba0b920b2bfd9c9209c1ab29b48.jpg" alt="0_1630304660563_73219f06-91bc-48ac-8f1e-f1b2d2ef6353-44efba0b920b2bfd9c9209c1ab29b48.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/14759</link><guid isPermaLink="true">https://community.m5stack.com/post/14759</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 30 Aug 2021 06:31:47 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.8.3 on Sat, 28 Aug 2021 15:39:44 GMT]]></title><description><![CDATA[<p dir="auto">with uiflow the OLED-unit shows nothing else than the M5Stack logo</p>
]]></description><link>https://community.m5stack.com/post/14749</link><guid isPermaLink="true">https://community.m5stack.com/post/14749</guid><dc:creator><![CDATA[plusulli]]></dc:creator><pubDate>Sat, 28 Aug 2021 15:39:44 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.8.3 on Sat, 28 Aug 2021 13:52:57 GMT]]></title><description><![CDATA[<p dir="auto">I am beginner of M5Stack. I bought both M5Go and Fire, together with lots of units. When I test the OLED unit, I found it always show M5 logo with "M5STACK".  i can 't fill with black or white. I can't draw rect. I can't draw line. I can't draw text. The only function works is "invert" but still only M5 logo with "M5STACK" is shown all the time. I tested it with both M5Go and Fire but same problem. Any help?</p>
]]></description><link>https://community.m5stack.com/post/14752</link><guid isPermaLink="true">https://community.m5stack.com/post/14752</guid><dc:creator><![CDATA[dominiclee]]></dc:creator><pubDate>Sat, 28 Aug 2021 13:52:57 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.8.3 on Sat, 28 Aug 2021 08:30:53 GMT]]></title><description><![CDATA[<p dir="auto">RGB leds won't work on M5Stamp if pins set to anything other that PORTA</p>
]]></description><link>https://community.m5stack.com/post/14747</link><guid isPermaLink="true">https://community.m5stack.com/post/14747</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 28 Aug 2021 08:30:53 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.8.3 on Fri, 27 Aug 2021 21:36:16 GMT]]></title><description><![CDATA[<p dir="auto">good job! when will the desktop IDE be upgraded?</p>
]]></description><link>https://community.m5stack.com/post/14745</link><guid isPermaLink="true">https://community.m5stack.com/post/14745</guid><dc:creator><![CDATA[mory]]></dc:creator><pubDate>Fri, 27 Aug 2021 21:36:16 GMT</pubDate></item></channel></rss>
