<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Multiple COM.x modules together]]></title><description><![CDATA[<p dir="auto">I have an application that would need to collect data over RS485, one or two GPIOs, GPS and send it out over LTE.</p>
<p dir="auto">Is it correct that the M-Bus only supports two UARTS such that stacking COM.GPS, COM.LTE and COMMU together would not work?</p>
]]></description><link>https://community.m5stack.com/topic/3486/multiple-com-x-modules-together</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 06:21:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3486.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Jul 2021 22:07:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Multiple COM.x modules together on Fri, 03 Dec 2021 18:42:32 GMT]]></title><description><![CDATA[<p dir="auto">The UART in question, is that the M5STACK bus IC ? What part number is it ?</p>
]]></description><link>https://community.m5stack.com/post/15706</link><guid isPermaLink="true">https://community.m5stack.com/post/15706</guid><dc:creator><![CDATA[Radu]]></dc:creator><pubDate>Fri, 03 Dec 2021 18:42:32 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple COM.x modules together on Thu, 29 Jul 2021 18:07:29 GMT]]></title><description><![CDATA[<p dir="auto">Good to know about the GPS.  I was wondering about that.  Looks like it's as accurate as the COM.GPS module.<br />
This HAT uses the 7600G and has some specs:  <a href="https://www.seeedstudio.com/SIM7600G-H-4G-LTE-Module-HAT-for-Jetson-Nano-p-4495.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.seeedstudio.com/SIM7600G-H-4G-LTE-Module-HAT-for-Jetson-Nano-p-4495.html</a></p>
<p dir="auto">Thanks for your help!</p>
]]></description><link>https://community.m5stack.com/post/14538</link><guid isPermaLink="true">https://community.m5stack.com/post/14538</guid><dc:creator><![CDATA[mludlum]]></dc:creator><pubDate>Thu, 29 Jul 2021 18:07:29 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple COM.x modules together on Thu, 29 Jul 2021 07:51:42 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3286">@mludlum</a></p>
<p dir="auto">no, there is no dip switch for this line - so yes, I suppose clipping the pin might work.</p>
<p dir="auto">Please note: I don't have the COMMU module, so I cannot actually test this.</p>
<p dir="auto">But, I do have the COM.LTE module and I just remembered that the SIM7600G used in the COM.LTE module also has a GPS in it. M5Stack doesn't seem to advertise this fact nor do they supply a GPS antenna, but I've just tested it and the GPS works for me.</p>
<p dir="auto">So for your application you won't need an extra COM.GPS module. Which reduces the number of UARTs you'll need.</p>
]]></description><link>https://community.m5stack.com/post/14533</link><guid isPermaLink="true">https://community.m5stack.com/post/14533</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 29 Jul 2021 07:51:42 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple COM.x modules together on Wed, 28 Jul 2021 18:17:17 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the information.  If I didn't need CAN, there's no dip switch or API to disable it?  Could I just clip the pin 15 on the COMMU M-Bus header?</p>
]]></description><link>https://community.m5stack.com/post/14531</link><guid isPermaLink="true">https://community.m5stack.com/post/14531</guid><dc:creator><![CDATA[mludlum]]></dc:creator><pubDate>Wed, 28 Jul 2021 18:17:17 GMT</pubDate></item><item><title><![CDATA[Reply to Multiple COM.x modules together on Wed, 28 Jul 2021 05:36:32 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3286">@mludlum</a></p>
<p dir="auto">all COM.X modules allow to select from three pairs of UART pins.</p>
<p dir="auto">TX can be set to: 17, 0 or 13<br />
RX can be set to: 16, 5 or 15</p>
<p dir="auto">In the COMMU module GPIO 17 and 16 are used for RS485 which leaves GPIO 0/5 and 13/15 for the two COMX modules. Unfortunately the COMMU module also uses <a href="https://docs.m5stack.com/en/module/commu?id=pinmap" target="_blank" rel="noopener noreferrer nofollow ugc">GPIO 15 for CAN INT</a>.</p>
<p dir="auto">So, no, I don't think you can make COM.GPS, COM.LTE and COMMU all work together. At least not w/o hardware modification.</p>
]]></description><link>https://community.m5stack.com/post/14525</link><guid isPermaLink="true">https://community.m5stack.com/post/14525</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 28 Jul 2021 05:36:32 GMT</pubDate></item></channel></rss>
