<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5ez 2.0: testers wanted...]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I am looking for a few people to test the new 2.0 version of <a href="http://forum.m5stack.com/topic/262/m5ez-a-complete-interface-builder-system-for-the-m5stack-as-an-arduino-library-extremely-easy-to-use/52" target="_blank" rel="noopener noreferrer nofollow ugc">M5ez</a>. The testing period would be fairly short since I plan to release in 3-4 days after ironing out the last things and making the documentation match the changes in commands and include the new features.</p>
<p dir="auto">This would include telling me in some detail what you think and of any bugs/inconsistencies you find.</p>
<p dir="auto">Any takers?</p>
<p dir="auto">Rop</p>
]]></description><link>https://community.m5stack.com/topic/348/m5ez-2-0-testers-wanted</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 09:11:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/348.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Oct 2018 08:27:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Thu, 25 Oct 2018 10:29:01 GMT]]></title><description><![CDATA[<p dir="auto">Having fun with m5ez</p>
<p dir="auto"><img src="/assets/uploads/files/1540462766896-img_0144-resized.jpg" alt="0_1540462728485_IMG_0144.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Now i am a copy and paste my own code .... coder....<br />
Copied my slider and made a mechanism that selects and sets each slider.<br />
Next and previous makes you jump between each slider, left and right sets the value , ok  publishes the value and  up gets you back to the main menu.</p>
<p dir="auto">I still have issues to get my values in to m5ez object like the header, text works fine but int is still a issue. Tried to convert them to chars, but failed....<br />
So much to learn at once.</p>
]]></description><link>https://community.m5stack.com/post/1838</link><guid isPermaLink="true">https://community.m5stack.com/post/1838</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Thu, 25 Oct 2018 10:29:01 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Wed, 24 Oct 2018 04:41:57 GMT]]></title><description><![CDATA[<p dir="auto">You could also add just an image to your mez screen.like this. But it has to be on a sd card.</p>
<p dir="auto">M5.Lcd.drawJpgFile(SD, "/c50x50_light_icon_off.jpg",20, 75, 50, 50);</p>
<p dir="auto">Below is my experiment to make  my own dynamic slider to get familiar with the arduino ide and m5ez<br />
The end goal is to read the value from mqtt and set the slider to the known value of the dimmer and set it</p>
<pre><code>int bar_position = 25 ; // START POSTITION ( TO DO : READ THIS VALUE FROM MQTT AND SET IT )
<p dir="auto">Drop the line above in top of the m5ez  to set the start position of the bar. Paste the below code in de the m5ez demo add to the main menu.</p>
<pre><code>void menu_brightness_slider(){
  int Bar_step_amount = 10;  // bar is devided in XX steps ( for on/of set to 1 )
  int Bar_lenght = 275; // Length of the slider bar
  int Bar_height = 28;  // Height of the slider bar
  int Bar_steps = Bar_lenght / Bar_step_amount;
  int Top_hLine_Start_X = 22; // X postion on screen from the left side
  int Top_hLine_Start_Y = 150; // Y-postition on screen from the top
  int Top_hLine_End_X = Bar_lenght + Top_hLine_Start_X ; // X End line postion on screen from the left side
  int Top_hLine_End_Y = Top_hLine_Start_Y;
  int Bot_hLine_Start_X = Top_hLine_Start_X;
  int Bot_hLine_Start_Y = Top_hLine_Start_Y + Bar_height ;
  int Bot_hLine_End_X = Top_hLine_Start_X + Bar_lenght ;
  int Bot_hLine_End_Y = Bar_height + Top_hLine_End_Y ;
  int Start_Point = Top_hLine_Start_X;
  int End_Point = Top_hLine_Start_X + Bar_lenght;
  int But_Radius = 10; // size of the slider indicator
  int mid_button = Top_hLine_Start_Y + ( Bar_height/2 );
  int bar_start_position = Top_hLine_Start_X + ( But_Radius ) ;
  int bar_end_position = Top_hLine_End_X - ( But_Radius ) ;
  ezProgressBar bl ("Keukenlamp dimmer", " brightness " , "left# #ok#up#right# ");
      while (true) {
            String b = ez.buttons.poll();
              //Draw lamp images and load them from sd root
              M5.Lcd.drawJpgFile(SD, "/c50x50_light_icon_on.jpg",255, 77, 50, 50);
              // conversion to 0 -- 100 to set dimmer
              int dimmer_value = (( bar_position / Bar_steps ) * 10 );
              Serial.println( dimmer_value );
              // slider indicator draw
              M5.Lcd.fillCircle((  bar_position ) , mid_button, But_Radius, 0xffff); // draw a white dot based on the _bar_y value
              M5.Lcd.fillCircle(( bar_position - Bar_steps ), mid_button, But_Radius, 0x0000); // draw a blck dot based on the _bar_y value
              M5.Lcd.fillCircle(( bar_position + Bar_steps ) , mid_button, But_Radius, 0x0000); // draw a blck dot based on the _bar_y value
              // Draw the rectangle for the slider
              M5.Lcd.drawLine(Top_hLine_Start_X, Top_hLine_Start_Y, Top_hLine_End_X, Top_hLine_End_Y, 0xffff); //Draw a line from the point X0 and Y0 to the point X1 and Y1 with a color from 0 to 65535
              //M5.Lcd.drawLine((Top_hLine_Start_X - 1), (Top_hLine_Start_Y  + 2), Top_hLine_End_X - 1 , Top_hLine_End_Y + 2 , 0x0ff0); //shade line
              M5.Lcd.drawLine(Bot_hLine_Start_X, Bot_hLine_Start_Y, Bot_hLine_End_X, Bot_hLine_End_Y, 0xffff); //Draw a second hor line and draw 2 vertical lines between them in the next two lines of code
              M5.Lcd.drawLine(Top_hLine_Start_X, Top_hLine_Start_Y, Bot_hLine_Start_X, Bot_hLine_Start_Y, 0xffff); //Left vert drawn line based on top and bot line
              M5.Lcd.drawLine(Top_hLine_End_X, Top_hLine_Start_Y, Bot_hLine_End_X, Bot_hLine_End_Y, 0xffff);//Right vert drawn line based on top and bot line
              /////////////////// Steps right
             if (b == "right" &amp;&amp; bar_position &lt;= Bar_lenght ){
                ( bar_position += Bar_steps );
                Serial.println ( bar_position );
              ////////////////// Steps left
              if (b == "left" &amp;&amp; bar_position &gt; Bar_steps) {
                bar_position -= ( Bar_steps );
              if (b == "on") {
              bar_position = Bar_lenght + 25 ;
              if (b == "off"){ bar_position = Top_hLine_Start_X  ;
              if (b == "ok") break;  // Jump out of loop and goto part that posts values to mqtt
              if (b == "up") loop();  // Jump out of loop and goto main menu
// Ok was pressed, and now we calculate the dimmer value, prepare the payload and send it
// Prepare a JSON payload string
  String payload = "";
  payload += "{";
  payload += "\"command\": \"switchlight\", \"idx\": 143, \"switchcmd\": \"Set Level\", \"level\":";
  payload += dimmer_value;
  payload += "}";
  // Send payload
  char attributes[100];
  payload.toCharArray( attributes, 100 );
  client.publish( "domoticz/in", attributes );
  Serial.println( attributes );
  menu_brightness_slider();// Loop and restart slider
<p dir="auto">Not as dynamic as i wished, but its a start  and with some parameter adjustments the slider bar can be converted to any size and even one that looks like a on and off switch, with only 2 positions.<br />
Why not just draw a rectangle instead of 4 lines ? Well the lines could be replaced by bitmaps, so the slider button will run between bitmaps instead of over ( stacked bitmaps give me a kind of interlaced images and looks odd )</p>
<p dir="auto">in this example i convert the slider bar to a scale of 0 - 100 and post in to my domoticz setup thru mqtt ( json formated )<br />
The mqtt  part of the code is missing, but thats nothing more than adding the library in the arduino ide and set the parameters.<br />
Next step will be separate the mqtt part and run that on a different core, so connection won't stall over time.</p>
]]></description><link>https://community.m5stack.com/post/1793</link><guid isPermaLink="true">https://community.m5stack.com/post/1793</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Wed, 24 Oct 2018 04:41:57 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sun, 21 Oct 2018 20:48:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Single image screens can be done with a one item menu. I was thinking of also adding the possibility of providing an image to <code>ez.msgBox</code>, but probably the 1-item menu approach is more flexible because it allows for a caption.</p>
]]></description><link>https://community.m5stack.com/post/1790</link><guid isPermaLink="true">https://community.m5stack.com/post/1790</guid><dc:creator><![CDATA[Rop]]></dc:creator><pubDate>Sun, 21 Oct 2018 20:48:34 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sun, 21 Oct 2018 14:49:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rop" aria-label="Profile: rop">@<bdi>rop</bdi></a><br />
I was messing with the image menu trying to create an image screen.</p>
]]></description><link>https://community.m5stack.com/post/1786</link><guid isPermaLink="true">https://community.m5stack.com/post/1786</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 21 Oct 2018 14:49:28 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sun, 21 Oct 2018 14:33:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> You're absolutely right: the feature to be able to change the captions of text menus while the menu is active had introduced this error on some image menu displays. Fixed in version 2.0.1 which I just released.   :)</p>
]]></description><link>https://community.m5stack.com/post/1785</link><guid isPermaLink="true">https://community.m5stack.com/post/1785</guid><dc:creator><![CDATA[Rop]]></dc:creator><pubDate>Sun, 21 Oct 2018 14:33:55 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sun, 21 Oct 2018 13:23:44 GMT]]></title><description><![CDATA[<p dir="auto">Strang bug appears in this code</p>
<p dir="auto">#include &lt;M5ez.h&gt;<br />
#include &lt;ezTime.h&gt;<br />
#include "images.h"<br />
#define MAIN_DECLARED<br />
void setup() {<br />
#include &lt;themes/default.h&gt;<br />
#include &lt;themes/dark.h&gt;<br />
ezt::setDebug(INFO);<br />
ez.begin();<br />
}<br />
void loop() {<br />
ezMenu images;<br />
images.imgBackground(TFT_BLACK);<br />
images.imgFromTop(40);<br />
images.imgCaptionColor(TFT_WHITE);<br />
images.addItem(sysinfo_jpg, "Photo Turntable", sysInfo);<br />
images.run();<br />
<p dir="auto">The title "Photo Turntable" get printed on the top and the bottom of the screen.<br />
(sorry no picture)</p>
]]></description><link>https://community.m5stack.com/post/1784</link><guid isPermaLink="true">https://community.m5stack.com/post/1784</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 21 Oct 2018 13:23:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sun, 21 Oct 2018 07:32:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/r_255" aria-label="Profile: r_255">@<bdi>r_255</bdi></a> Cool!   :)</p>
]]></description><link>https://community.m5stack.com/post/1782</link><guid isPermaLink="true">https://community.m5stack.com/post/1782</guid><dc:creator><![CDATA[Rop]]></dc:creator><pubDate>Sun, 21 Oct 2018 07:32:54 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sun, 21 Oct 2018 07:04:52 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1540105054090-img_0135-resized.jpg" alt="0_1540105015957_IMG_0135.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Well slowly i am getting somewhere</p>
]]></description><link>https://community.m5stack.com/post/1781</link><guid isPermaLink="true">https://community.m5stack.com/post/1781</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Sun, 21 Oct 2018 07:04:52 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Thu, 18 Oct 2018 17:34:44 GMT]]></title><description><![CDATA[<pre><code>void menu_brightness_slider(){
  ezProgressBar bl ("Keukenlamp dimmer", "Set brightness", "left#off#ok#up#right#on");
            while (true) {
              if (b == "right" &amp;&amp; brightness &lt;= 90) brightness += 10;
              if (!brightness) brightness = 100;
              if (b == "left" &amp;&amp; brightness &gt; 11) brightness -= 10;
              if (b == "left" &amp;&amp; brightness &lt; 11) brightness = 0.01;
              bl.value((float)(brightness));
              if (b == "off")brightness = 0.01;
              if (b == "on")brightness = 100;
  payload += "{";
  payload += brightness;
  payload += "}";
  // Send payload
<p dir="auto">This works !  :O)</p>
<p dir="auto"><img src="/assets/uploads/files/1539883810139-m5dimmer-resized.jpg" alt="0_1539883795078_m5dimmer.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Now a long press set on or off or back to menu</p>
]]></description><link>https://community.m5stack.com/post/1755</link><guid isPermaLink="true">https://community.m5stack.com/post/1755</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Thu, 18 Oct 2018 17:34:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Thu, 18 Oct 2018 07:54:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/r_255" aria-label="Profile: r_255">@<bdi>r_255</bdi></a> I don't know about this mqtt implementation, but in general, one would use <code>_brightness.toInt()</code> or <code>_brightness.toFloat()</code> to turn variable <code>_brightness</code> from a String into a number. Hope that helps.</p>
]]></description><link>https://community.m5stack.com/post/1753</link><guid isPermaLink="true">https://community.m5stack.com/post/1753</guid><dc:creator><![CDATA[Rop]]></dc:creator><pubDate>Thu, 18 Oct 2018 07:54:10 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Thu, 18 Oct 2018 07:13:48 GMT]]></title><description><![CDATA[<p dir="auto">Hey Rop,</p>
<p dir="auto">I agree, and what you see is just a image from my design program. To get a estimate on how it looks in total on the m5. In the working model i use your header and buttons.</p>
<p dir="auto">i did just adjust the dark theme a bit and in between my image shows.</p>
<p dir="auto">Just playing with your work and see where the limits are. So far my programming is what limits me.</p>
<p dir="auto">Stuck on how to get the _brigtness value into my mqtt.<br />
Tried almost everything i can think of, did look into other code<br />
did look how variables are used, but this syntax is over my head. This publishes _Brightness as text but not as value.<br />
So close and still far away... It frustrates me over the past 2 days now.</p>
<p dir="auto">client.publish("domoticz/in", "{"command": "switchlight", "idx": 143, "switchcmd": "Set Level", "level": _brightness; }");</p>
<p dir="auto">It's just the basic skills i am missing, but in general i can understand what is happening.</p>
<p dir="auto">I agree on usability like in rgbw, but left or right and next option will set the previous isnt that hard. Less pushes makes things more use able, thats something that is my experience.</p>
<p dir="auto">a double push to go a level up/cancel might be more easy to understand for end users of the interface. While a enter or a level down is a single push of the middle button.</p>
<p dir="auto">Again, thanks for all your hard work ! and i do hope that the community contributes a bit more as in sharing experiences and code. So we dont expect 3.0 but there is still hope for v2.99  ;o)</p>
<p dir="auto">cheers<br />
Robin</p>
]]></description><link>https://community.m5stack.com/post/1752</link><guid isPermaLink="true">https://community.m5stack.com/post/1752</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Thu, 18 Oct 2018 07:13:48 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Wed, 17 Oct 2018 17:08:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/r_255" aria-label="Profile: r_255">@<bdi>r_255</bdi></a> I would not go that route and write code that draws the image. And I would use the M5ez buttons on the display. If you want multiple sliders (for RGBW etc), you <strong>will</strong> end up wanting the long/short press functions to switch sliders and operate the sliders without too many presses. Your images have made me think about how to make things more generic and configurable...</p>
]]></description><link>https://community.m5stack.com/post/1746</link><guid isPermaLink="true">https://community.m5stack.com/post/1746</guid><dc:creator><![CDATA[Rop]]></dc:creator><pubDate>Wed, 17 Oct 2018 17:08:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Wed, 17 Oct 2018 04:57:36 GMT]]></title><description><![CDATA[<p dir="auto">Happy with v2.0<br />
The slider works fine now !</p>
<p dir="auto">While looking into your code to find the brightness slider i realized you did a shit load of work in a short period ... Amazing!<br />
Big thank you!</p>
<p dir="auto"><img src="/assets/uploads/files/1539752029952-dimmer_00.jpg" alt="0_1539752015056_dimmer_00.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Also made  one based on the image menu and let the slider jump in steps of 20 and simply change the image<br />
Still having a hard time with the programming, but slowly i am getting some where.</p>
]]></description><link>https://community.m5stack.com/post/1743</link><guid isPermaLink="true">https://community.m5stack.com/post/1743</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Wed, 17 Oct 2018 04:57:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Tue, 16 Oct 2018 11:25:01 GMT]]></title><description><![CDATA[<p dir="auto">I totally missed that link, cheers!</p>
]]></description><link>https://community.m5stack.com/post/1740</link><guid isPermaLink="true">https://community.m5stack.com/post/1740</guid><dc:creator><![CDATA[prickle]]></dc:creator><pubDate>Tue, 16 Oct 2018 11:25:01 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Mon, 15 Oct 2018 13:37:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/prickle" aria-label="Profile: prickle">@<bdi>prickle</bdi></a><br />
You have to load <a class="plugin-mentions-user plugin-mentions-a" href="/user/rop" aria-label="Profile: Rop">@<bdi>Rop</bdi></a>’s ezTime Arduino library.<br />
Instructions are actually in the upgrade notes but I didn’t read those either.</p>
]]></description><link>https://community.m5stack.com/post/1731</link><guid isPermaLink="true">https://community.m5stack.com/post/1731</guid><dc:creator><![CDATA[bobolink]]></dc:creator><pubDate>Mon, 15 Oct 2018 13:37:08 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Mon, 15 Oct 2018 09:27:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys, new user here. Tried M5ez installing from Manage Libraries, went to compile M5ez-demo, got the following error.</p>
<p dir="auto">Arduino: 1.8.7 (Windows 7), TD: 1.44, Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"</p>
<p dir="auto">C:\Users\prickle\Documents\Quadcopter\Arduino\libraries\M5ez\src/M5ez.h:28:49: fatal error: ezTime.h: No such file or directory</p>
<p dir="auto">compilation terminated.</p>
]]></description><link>https://community.m5stack.com/post/1730</link><guid isPermaLink="true">https://community.m5stack.com/post/1730</guid><dc:creator><![CDATA[prickle]]></dc:creator><pubDate>Mon, 15 Oct 2018 09:27:59 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sun, 07 Oct 2018 10:50:06 GMT]]></title><description><![CDATA[<p dir="auto">Everything you see is just work in progress and hand drawn in vectors( sunday morning frustrations ). Ill make a bundle with stuffbut sofar its just all in one screen and vector. Would be great to make it a community effort and make it into a demo file that is included with M5ez.</p>
<p dir="auto">Not sure about what the end point is, can we scale sliders. re position them.</p>
<p dir="auto">I did re use most of my old gfx for a ipad interface<br />
and that is downloadable here</p>
<p dir="auto"><a href="http://files.domoticaforum.eu/index.php?cam=/Graphics" target="_blank" rel="noopener noreferrer nofollow ugc">http://files.domoticaforum.eu/index.php?cam=/Graphics</a></p>
]]></description><link>https://community.m5stack.com/post/1679</link><guid isPermaLink="true">https://community.m5stack.com/post/1679</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Sun, 07 Oct 2018 10:50:06 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sun, 07 Oct 2018 09:47:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/r_255" aria-label="Profile: r_255">@<bdi>r_255</bdi></a> Very, very nice !!! Can we get your theme and icons somewhere ? Thanks</p>
]]></description><link>https://community.m5stack.com/post/1678</link><guid isPermaLink="true">https://community.m5stack.com/post/1678</guid><dc:creator><![CDATA[jeanvdr]]></dc:creator><pubDate>Sun, 07 Oct 2018 09:47:07 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sun, 07 Oct 2018 09:14:49 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1538901428635-m5ez_gfx-resized.png" alt="0_1538901434940_M5ez_gfx.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1538903563077-m5ez_gfx_bw-resized.png" alt="0_1538903569611_M5ez_gfx_bw.png" class=" img-fluid img-markdown" /><br />
This is spinning in my head...  next to this dual core thingy. I guess this is what you get when i get frustrated from programming... lol</p>
]]></description><link>https://community.m5stack.com/post/1677</link><guid isPermaLink="true">https://community.m5stack.com/post/1677</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Sun, 07 Oct 2018 09:14:49 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Wed, 03 Oct 2018 20:37:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi Rop,<br />
I've got my m5stack since one week to make a remote interface for my home-automation system. So, I was naturally driven to m5ez, which was only laking multitasking (for mqtt) and a timeout LCD backlight management which like I read is part of v2.0. I'll be glad to be able to test it if possible. Thanks.<br />
Jean</p>
]]></description><link>https://community.m5stack.com/post/1666</link><guid isPermaLink="true">https://community.m5stack.com/post/1666</guid><dc:creator><![CDATA[jeanvdr]]></dc:creator><pubDate>Wed, 03 Oct 2018 20:37:14 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Wed, 03 Oct 2018 16:25:32 GMT]]></title><description><![CDATA[<p dir="auto">Its all yours.....  Adjustments is no problem, its all vector gfx.<br />
You can drop me a line at my <a href="http://hotmail.com" target="_blank" rel="noopener noreferrer nofollow ugc">hotmail.com</a> account for the changes, just add my forum nick in front.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://community.m5stack.com/post/1664</link><guid isPermaLink="true">https://community.m5stack.com/post/1664</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Wed, 03 Oct 2018 16:25:32 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Wed, 03 Oct 2018 14:06:29 GMT]]></title><description><![CDATA[<p dir="auto">Thanks... Looks great... Let me think about a few small changes if I may, and then I'd like to use that...But first let's get 2.0 out the door...</p>
]]></description><link>https://community.m5stack.com/post/1663</link><guid isPermaLink="true">https://community.m5stack.com/post/1663</guid><dc:creator><![CDATA[Rop]]></dc:creator><pubDate>Wed, 03 Oct 2018 14:06:29 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Sat, 06 Oct 2018 18:30:08 GMT]]></title><description><![CDATA[<p dir="auto">Hey Rop,</p>
<p dir="auto">Nice you are making progress!<br />
I would like to see if i can move the slider in a negative way, not sure if i am much of a help with my skills.<br />
But thats all up to you. Happy with all your efforts anyway.</p>
<p dir="auto"><img src="/assets/uploads/files/1538850570705-logo_m5ez_growing-resized.png" alt="0_1538850576464_logo_m5ez_growing.png" class=" img-fluid img-markdown" /><br />
Meanwhile i spend some time on doing what is more familiar to me.</p>
<p dir="auto">Hi @ Moelski</p>
]]></description><link>https://community.m5stack.com/post/1645</link><guid isPermaLink="true">https://community.m5stack.com/post/1645</guid><dc:creator><![CDATA[r_255]]></dc:creator><pubDate>Sat, 06 Oct 2018 18:30:08 GMT</pubDate></item><item><title><![CDATA[Reply to M5ez 2.0: testers wanted... on Mon, 01 Oct 2018 12:40:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rop" aria-label="Profile: Rop">@<bdi>Rop</bdi></a><br />
Sure</p>
]]></description><link>https://community.m5stack.com/post/1644</link><guid isPermaLink="true">https://community.m5stack.com/post/1644</guid><dc:creator><![CDATA[bobolink]]></dc:creator><pubDate>Mon, 01 Oct 2018 12:40:02 GMT</pubDate></item></channel></rss>
