<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[UI Flow] Update Faces Inputs]]></title><description><![CDATA[<p dir="auto">Right now the faces blocks on UI Flow are really basic, but there is not much you can do with them. We need blocks that do more.</p>
<p dir="auto">For example the other day I was attempting to make a To-Do list using the calculator face. I wanted a set list of things I had to do, but when I hit a number corresponding with a task, it would change the color of the text, and play a sound. I found this to be impossible, because you cannot make a if statement to test for a specific key being pressed on the face. I found the same problem with the keyboard face, there is no way to detect if a certain key is pressed.</p>
<p dir="auto">TL;DR We need more in depth blocks for the M5 Faces.</p>
]]></description><link>https://community.m5stack.com/topic/3398/ui-flow-update-faces-inputs</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 11:52:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3398.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Jun 2021 21:21:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [UI Flow] Update Faces Inputs on Fri, 25 Jun 2021 11:55:05 GMT]]></title><description><![CDATA[<p dir="auto">You can't  get the keyboard value results?? could you paste your code to here?</p>
]]></description><link>https://community.m5stack.com/post/14217</link><guid isPermaLink="true">https://community.m5stack.com/post/14217</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 25 Jun 2021 11:55:05 GMT</pubDate></item></channel></rss>
