<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SOLVED: UIFlow cannot currently connect to any M5Stack devices]]></title><description><![CDATA[<p dir="auto">I have the problem that I cannot currently connect to any of my devices with UIFlow from <a href="http://flow.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">flow.m5stack.com</a><br />
For example core2 and atom devices can connect to the cloud server as usual and show a green connection.<br />
When I try to connect to a device from my browser, it just says that the connection failed, maybe your device is offline..... All of the API keys I am using are correct. I've recently updated most of my devices to version 1.7.8. and everything was working until today.</p>
<p dir="auto">Everything works perfectly fine locally via USB.</p>
]]></description><link>https://community.m5stack.com/topic/3361/solved-uiflow-cannot-currently-connect-to-any-m5stack-devices</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 20:24:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3361.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Jun 2021 11:52:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Tue, 28 Nov 2023 05:59:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> I was originally having issues with the other servers too, but it looks like it's working now.<br />
Thank you!</p>
]]></description><link>https://community.m5stack.com/post/22916</link><guid isPermaLink="true">https://community.m5stack.com/post/22916</guid><dc:creator><![CDATA[Sodar]]></dc:creator><pubDate>Tue, 28 Nov 2023 05:59:16 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Sun, 26 Nov 2023 11:59:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sodar" aria-label="Profile: sodar">@<bdi>sodar</bdi></a> have you tried changing the servers in M5Burner?<br />
There are quite a few people trying to access the same server which means someone will be refused a connection and then there is the Great Firewall of China which sometimes causes problems.</p>
]]></description><link>https://community.m5stack.com/post/22900</link><guid isPermaLink="true">https://community.m5stack.com/post/22900</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 26 Nov 2023 11:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Sun, 26 Nov 2023 08:56:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gdallask" aria-label="Profile: gdallask">@<bdi>gdallask</bdi></a> Same thing is happening to me right now :(</p>
]]></description><link>https://community.m5stack.com/post/22897</link><guid isPermaLink="true">https://community.m5stack.com/post/22897</guid><dc:creator><![CDATA[Sodar]]></dc:creator><pubDate>Sun, 26 Nov 2023 08:56:02 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Wed, 17 May 2023 14:42:29 GMT]]></title><description><![CDATA[<p dir="auto">It seems to be happening again.  Problem connecting from UK.  This is beginning to discourage me from investing further in this system.</p>
]]></description><link>https://community.m5stack.com/post/20874</link><guid isPermaLink="true">https://community.m5stack.com/post/20874</guid><dc:creator><![CDATA[gDallasK]]></dc:creator><pubDate>Wed, 17 May 2023 14:42:29 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Sat, 27 Nov 2021 19:30:28 GMT]]></title><description><![CDATA[<p dir="auto">Server is in China and prone to drop outs.</p>
]]></description><link>https://community.m5stack.com/post/15636</link><guid isPermaLink="true">https://community.m5stack.com/post/15636</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 27 Nov 2021 19:30:28 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Sat, 27 Nov 2021 17:48:53 GMT]]></title><description><![CDATA[<p dir="auto">Is this happening again? Everything was going along well, but now ... even though my device shows as connected to the Cloud, and even though the API key checks out fine, every attempt to download code gives me the "failed" message. It was working earlier, but now I've gone through it again, and again, and again. Burned the latest version to the device. Tried both desktop and online versions. Can't connect.</p>
]]></description><link>https://community.m5stack.com/post/15634</link><guid isPermaLink="true">https://community.m5stack.com/post/15634</guid><dc:creator><![CDATA[Devilstower]]></dc:creator><pubDate>Sat, 27 Nov 2021 17:48:53 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Sun, 13 Jun 2021 10:06:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> It was "unconnectable" for about 24 hours, which was extremely annoying. The thing was that the devices could connect to the server and showed green connections. But the UIFlow server couldn't connect back to the devices.<br />
I didn't change anything at my end and now everything is working as before.<br />
I was trying to test the OLED Unit because of a brightness problem and that new unit is not yet supported in the desktop (offline) UIFlow IDE, so I had to be online and connected to try things out.</p>
]]></description><link>https://community.m5stack.com/post/14096</link><guid isPermaLink="true">https://community.m5stack.com/post/14096</guid><dc:creator><![CDATA[veryalien]]></dc:creator><pubDate>Sun, 13 Jun 2021 10:06:58 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Sun, 13 Jun 2021 08:50:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">works for me - tested with an M5Atom Matrix and an M5StickC Plus (both running UIFlow version 1.7.8).</p>
<p dir="auto">Maybe a temporal or regional issue?</p>
]]></description><link>https://community.m5stack.com/post/14094</link><guid isPermaLink="true">https://community.m5stack.com/post/14094</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 13 Jun 2021 08:50:21 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Sun, 13 Jun 2021 08:45:11 GMT]]></title><description><![CDATA[<p dir="auto">It seems to be working again, my browser now gets a connection to my device. So it was a server-side problem, nothing to do with our m5stack devices, firmware or API keys.</p>
]]></description><link>https://community.m5stack.com/post/14093</link><guid isPermaLink="true">https://community.m5stack.com/post/14093</guid><dc:creator><![CDATA[veryalien]]></dc:creator><pubDate>Sun, 13 Jun 2021 08:45:11 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Sat, 12 Jun 2021 23:56:04 GMT]]></title><description><![CDATA[<p dir="auto">Same issue here - M5Stickc and Atom - all devices connect to Wifi but cannot connect to M5Flow via browser.<br />
Latest FIrmware and 1.7.8 UIFlow.</p>
]]></description><link>https://community.m5stack.com/post/14090</link><guid isPermaLink="true">https://community.m5stack.com/post/14090</guid><dc:creator><![CDATA[Russell]]></dc:creator><pubDate>Sat, 12 Jun 2021 23:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to SOLVED: UIFlow cannot currently connect to any M5Stack devices on Sat, 12 Jun 2021 14:44:45 GMT]]></title><description><![CDATA[<p dir="auto">I also have the same problem on m5stickC and m5stickC plus today.  Everything was working fine two days ago when I last used it, and I did not change anything (same firmware 1.7.8, etc), but it just does not connect.  I also tried changing the server between China and Singapore, but it did not make a difference.  Any help would be greatly appreciated.</p>
]]></description><link>https://community.m5stack.com/post/14085</link><guid isPermaLink="true">https://community.m5stack.com/post/14085</guid><dc:creator><![CDATA[chrismoraes]]></dc:creator><pubDate>Sat, 12 Jun 2021 14:44:45 GMT</pubDate></item></channel></rss>
