<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Powering Atom Lite with 5V pins]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/2341/can-the-atom-accept-external-regulated-5v-power">Can the Atom accept external regulated 5V power?</a></p>
<p dir="auto">I tried to power the Atom Lite modules from 5V groove pin and failed miserably (if I connect same power supply to USB-C connector - everything works.</p>
<p dir="auto">Is there more detailed schematics how is the powerline connected?</p>
<p dir="auto"><img src="https://static-cdn.m5stack.com/resource/docs/static/assets/img/product_pics/core/minicore/atom/ATOM_LITE_SIMPLE_CIRCUT_20200514.webp" alt="Atom lite schema" class=" img-fluid img-markdown" /></p>
<p dir="auto">On this schema only 0.5A fuse is shown, but I have nothing else connected, so I shouldn't trigger that.</p>
]]></description><link>https://community.m5stack.com/topic/3239/powering-atom-lite-with-5v-pins</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 20:56:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3239.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Apr 2021 10:43:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Powering Atom Lite with 5V pins on Fri, 15 Mar 2024 11:52:09 GMT]]></title><description><![CDATA[<p dir="auto">To run devices like this from an external supply I'd recommend a little Buck regulator board such as the one Youmile does (<a href="https://www.amazon.co.uk/dp/B07TTH6C3J" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.co.uk/dp/B07TTH6C3J</a>). You can then set the output to fixed 5V and drive the input from anything - USB 5V from a breadboard, a 9V PP3, 12V or 24V car, truck or boat battery etc. - with no worries about blowing anything in the Atom.</p>
]]></description><link>https://community.m5stack.com/post/24405</link><guid isPermaLink="true">https://community.m5stack.com/post/24405</guid><dc:creator><![CDATA[Gallowglass]]></dc:creator><pubDate>Fri, 15 Mar 2024 11:52:09 GMT</pubDate></item><item><title><![CDATA[Reply to Powering Atom Lite with 5V pins on Sat, 01 May 2021 04:16:39 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys</p>
<p dir="auto">from the schematic there should be no difference whether you power M5Atom via 5V on the Groove connector or the 5 V pin in the back. Measuring for continuity between Groove and the respective pins in the back also shows they are connected 1:1 and are the same.</p>
<p dir="auto">Running a simple sketch on my M5Atom Matrix, which only connects WiFi and is showing that by changing the LEDs from red to green, I see that working ok with voltages from 2.8 V to 5.2 V.</p>
<p dir="auto">BTW: I am getting the same results with an M5Atom Lite.</p>
]]></description><link>https://community.m5stack.com/post/13678</link><guid isPermaLink="true">https://community.m5stack.com/post/13678</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 01 May 2021 04:16:39 GMT</pubDate></item><item><title><![CDATA[Reply to Powering Atom Lite with 5V pins on Thu, 29 Apr 2021 07:36:03 GMT]]></title><description><![CDATA[<p dir="auto">I have too experimented powering both Atom Lite and the Atom Matrix via the groove connector or via the headers pins and I noticed a weird thing. If the voltage is a little below 5V, for example 4.6 or 4.7 Volts it works fine. If the voltage is a little above 5V, for example 5.2V it power up but it never connect to internet.</p>
]]></description><link>https://community.m5stack.com/post/13663</link><guid isPermaLink="true">https://community.m5stack.com/post/13663</guid><dc:creator><![CDATA[Dario]]></dc:creator><pubDate>Thu, 29 Apr 2021 07:36:03 GMT</pubDate></item><item><title><![CDATA[Reply to Powering Atom Lite with 5V pins on Wed, 28 Apr 2021 20:13:36 GMT]]></title><description><![CDATA[<p dir="auto">I connect a Li-po battery (3.7V) directly to bottom pins GND, 5V and atom lite works. But usb2uart and neopixel led may not work or works incorrectly depends of battery voltage. In my case i need only esp32 to works.</p>
]]></description><link>https://community.m5stack.com/post/13660</link><guid isPermaLink="true">https://community.m5stack.com/post/13660</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Wed, 28 Apr 2021 20:13:36 GMT</pubDate></item><item><title><![CDATA[Reply to Powering Atom Lite with 5V pins on Wed, 28 Apr 2021 15:37:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/9060">@pacaj2am</a> You can power the Atom via the 5V in pin on the back of the atom.</p>
]]></description><link>https://community.m5stack.com/post/13657</link><guid isPermaLink="true">https://community.m5stack.com/post/13657</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 28 Apr 2021 15:37:26 GMT</pubDate></item></channel></rss>
