<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Paper &amp; Lora]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">A question from a beginner... does a M5Paper could be connected to module like Lora Module :<br />
<a href="https://shop.m5stack.com/products/lora-module-868mhz?_pos=2&amp;_sid=950ff4cfa&amp;_ss=r" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/products/lora-module-868mhz?_pos=2&amp;_sid=950ff4cfa&amp;_ss=r</a></p>
<p dir="auto">Regards</p>
<p dir="auto">Stan</p>
]]></description><link>https://community.m5stack.com/topic/3236/m5paper-lora</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 05:32:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3236.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 27 Apr 2021 18:26:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Paper &amp; Lora on Mon, 03 May 2021 07:09:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/8886">@stantheman</a><br />
You don't need to check anything, just configure spi for lower speed.<br />
There is not much sense in using fast spi clock with LoRa module, 1 MHz is probably enough.</p>
<p dir="auto">BTW, there are some LoRa modules which operates over <strong>serial port</strong> (UART) which are quite easy to use (like <a href="https://www.ebay.com/itm/193873864678?_trkparms=ispr%3D1&amp;hash=item2d23c867e6:g:3kQAAOSw199gF6tI&amp;amdata=enc%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkfKe2vUidqHRg3XM2X2xOVLRjIRszVgxf0VcjDXuED%252FbtkE1tNBYLSvPJ4AKptv5hxPxw8rm5nD6GOtWcZrnrh6KCwdwHVdt0ScBifJb%252FAuqKHEXCU2uUxzV45fRXzN58Hrn1jIo%252FKn9ymdspaOB4PPWTSDXEtJzU2eTHzb11qJqichFoOZ%252BZMD4SXA4I6excRPIaAHwvh%252FIENkNfTFgAMYLEve2VbENOTEIxv0maoJ%252BJJa0ObdYaxnRf8tqaz50LFJz02sVSc9kFG6gS2gEm7gNwjLDFDyUZvlFNt1RnkNkUfMqdv2keuxKTWivFgMZzu8nBb%252Ff7NmU9NeqK0f9APfDrvGlJTPGfNuKe2tsFOj8NYdwC4EDAYxEmvwDJa%252Fwd4iASzcChM3dv1Jg3xF8a9y%252FIDcyn1k3qE3MUvMX%252F46y1UlhgncuqPcIftrxr6J6OJV%252BF50tccowfJV%252FXEb6Idl8a6fKPHfh8HGQKoBl%252FnNrkOk7bRCrGfITiGKRtc7JNOanFPcln2OYO2qyN05Hdcq3FZXCw%252BYIzNkRCM02YRUyuLMFtMHXLAzcFykClZPpmQHkPiq%252FI%252BNsizzomlUykQW9j1M%252Bki85Qme38RUajJ%252BGQaud6am5WvhYfNdk4MOznlmkYDG6KcztV9WbMKBdy4x5lRzR6vDZEestZv60lEYRPkgyCmxJ45lMXfghuBiLpRvYEfjzSaIIDVtb06IMttN6O1pyZcynX3sW62ESGAEfULK5Bep59nKfw9CUgQLdFDo86PjVeEOfSibZZMDwvIA%253D%253D%7Ccksum%3A193873864678b992cbbbcf014aa5bc948baf541347ff%7Campid%3APL_CLK%7Cclp%3A2334524" target="_blank" rel="noopener noreferrer nofollow ugc">this one</a> or <a href="https://www.ebay.com/itm/193996855783?hash=item2d2b1d19e7:g:cPEAAOSw~5VgXaNI" target="_blank" rel="noopener noreferrer nofollow ugc">this one</a>).</p>
<p dir="auto"><a href="https://www.seeedstudio.com/LoRa-E5-Wireless-Module-p-4745.html" target="_blank" rel="noopener noreferrer nofollow ugc">LoRa-E5 (STM32WLE5JC) Module</a> is also very interesting and supports LoRaWAN too.</p>
]]></description><link>https://community.m5stack.com/post/13699</link><guid isPermaLink="true">https://community.m5stack.com/post/13699</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Mon, 03 May 2021 07:09:24 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper &amp; Lora on Sun, 02 May 2021 14:42:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Felmue, thanks Loboris,</p>
<p dir="auto">What I understand is that I need to check first that SPI bus speeds above 40 MHz will not be used in my whole project. My project is to build a numerical swich panel for my sailboat (about 20 instruments to manage) , and also manage power consumption/production from solar panels, engine etc...</p>
<p dir="auto">Stanislas</p>
]]></description><link>https://community.m5stack.com/post/13698</link><guid isPermaLink="true">https://community.m5stack.com/post/13698</guid><dc:creator><![CDATA[stantheman]]></dc:creator><pubDate>Sun, 02 May 2021 14:42:43 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper &amp; Lora on Sun, 02 May 2021 10:07:36 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/55">@loboris</a></p>
<p dir="auto">I stand corrected. You are right. Thank you for pointing that out.</p>
<p dir="auto">The GPIOs of the second SPI connection I've mentioned above (18, 19 and 23) are only relevant if one needs SPI bus speeds above 40 MHz apparently. If the SPI bus speed is 40 MHz (or below) almost any GPIO can be used for SPI as you pointed out.</p>
]]></description><link>https://community.m5stack.com/post/13697</link><guid isPermaLink="true">https://community.m5stack.com/post/13697</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 02 May 2021 10:07:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper &amp; Lora on Sun, 02 May 2021 09:21:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a><br />
You can configure SPI to work with (almost) any GPIO on ESP32.</p>
]]></description><link>https://community.m5stack.com/post/13695</link><guid isPermaLink="true">https://community.m5stack.com/post/13695</guid><dc:creator><![CDATA[loboris]]></dc:creator><pubDate>Sun, 02 May 2021 09:21:27 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper &amp; Lora on Wed, 28 Apr 2021 10:10:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/8886">@stantheman</a></p>
<p dir="auto">I don't think it is possible. The LoRa module uses SPI to communicate. M5Paper internally uses SPI already, but those GPIOs (14, 12 and 13) are not accessible.</p>
<p dir="auto">According to ESP32 documentation there is a second SPI connection available, but the respective GPIOs (18, 19 and 23) are not all available / accessible on M5Paper.</p>
<p dir="auto">I am sorry, but I think you are out of luck.</p>
]]></description><link>https://community.m5stack.com/post/13643</link><guid isPermaLink="true">https://community.m5stack.com/post/13643</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 28 Apr 2021 10:10:03 GMT</pubDate></item></channel></rss>
