<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1.7.2 uiflow menu speed (core2)]]></title><description><![CDATA[<p dir="auto">Hi M5Stack,</p>
<p dir="auto">The Core2 uiflow 1.7.2  firmware has following problem:</p>
<p dir="auto">Description: The menu for ui flow on the m5core2 (the one to switch applications or go into setup) Its speed is too fast, making it imposible to make a selection on time.</p>
<p dir="auto">Version: 1.7.2</p>
<p dir="auto">Expected behavior: The time before uiflow starts running the selected mode should take longer so the user can make a selection.</p>
<p dir="auto">Tested Hardware: M5stack Core2 for AWS, with defaul base.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/3001/1-7-2-uiflow-menu-speed-core2</link><generator>RSS for Node</generator><lastBuildDate>Fri, 05 Jun 2026 22:24:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3001.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 25 Feb 2021 01:13:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1.7.2 uiflow menu speed (core2) on Thu, 25 Feb 2021 02:58:38 GMT]]></title><description><![CDATA[<p dir="auto">Adding investigation, this seems to happen only if you upload to the core2 an empty project.</p>
]]></description><link>https://community.m5stack.com/post/12663</link><guid isPermaLink="true">https://community.m5stack.com/post/12663</guid><dc:creator><![CDATA[BricoMS]]></dc:creator><pubDate>Thu, 25 Feb 2021 02:58:38 GMT</pubDate></item></channel></rss>
