<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Question about GROVE sensors and m5stack core2]]></title><description><![CDATA[<p dir="auto">I tried to connect several GROVE sensors (i.e. GSR) directly to APORT of core2,<br />
but it doesn't works since they are not i2c devices.<br />
When I connect grove sensor to ADC, which connected to APORT and power the grove sensor via separate 5V connection, it seems work properly.</p>
<p dir="auto">Non-i2c sensors are NOT directly compatible to APORT, right?</p>
<p dir="auto">I am looking for more simple way to connect multiple GROVE sensors (non i2c) to core2.</p>
]]></description><link>https://community.m5stack.com/topic/2940/question-about-grove-sensors-and-m5stack-core2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 05:06:11 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2940.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Feb 2021 15:44:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Question about GROVE sensors and m5stack core2 on Sat, 13 Feb 2021 13:01:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ipsych" aria-label="Profile: ipsych">@<bdi>ipsych</bdi></a> Port A is a digital/I2C port however there is no garentie that the firmware will have the drivers for the hardware.<br />
UART and analog sensors are not compatable with PORTA<br />
Are you using Arduino or Micropython over REPL?</p>
]]></description><link>https://community.m5stack.com/post/12481</link><guid isPermaLink="true">https://community.m5stack.com/post/12481</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 13 Feb 2021 13:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to Question about GROVE sensors and m5stack core2 on Fri, 12 Feb 2021 05:13:14 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, but I don't use the gui, but commandline-based working.<br />
Do the sensors like<br />
<a href="https://wiki.seeedstudio.com/Grove-GSR_Sensor/" target="_blank" rel="noopener noreferrer nofollow ugc">https://wiki.seeedstudio.com/Grove-GSR_Sensor/</a><br />
would supported for APORT?</p>
]]></description><link>https://community.m5stack.com/post/12459</link><guid isPermaLink="true">https://community.m5stack.com/post/12459</guid><dc:creator><![CDATA[iPsych]]></dc:creator><pubDate>Fri, 12 Feb 2021 05:13:14 GMT</pubDate></item><item><title><![CDATA[Reply to Question about GROVE sensors and m5stack core2 on Fri, 12 Feb 2021 00:05:14 GMT]]></title><description><![CDATA[<p dir="auto">ipsych in UIFlow 1.7.1 is a Problem with the Core 2 and the grove port, a update to UIFlow 1.7.2 will solve the problem <a href="https://community.m5stack.com/topic/2672/uiflow-1-7-1">https://community.m5stack.com/topic/2672/uiflow-1-7-1</a></p>
]]></description><link>https://community.m5stack.com/post/12457</link><guid isPermaLink="true">https://community.m5stack.com/post/12457</guid><dc:creator><![CDATA[Gaviota]]></dc:creator><pubDate>Fri, 12 Feb 2021 00:05:14 GMT</pubDate></item></channel></rss>
