<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I&#x27;ve tried using Serial1,2,3 or using HardwareSerial but I couldn&#x27;t get anything out of the GPS]]></title><description><![CDATA[<p dir="auto"><strong>bolded text</strong></p>
]]></description><link>https://community.m5stack.com/topic/2783/i-ve-tried-using-serial1-2-3-or-using-hardwareserial-but-i-couldn-t-get-anything-out-of-the-gps</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 20:02:30 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2783.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Jan 2021 19:24:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I&#x27;ve tried using Serial1,2,3 or using HardwareSerial but I couldn&#x27;t get anything out of the GPS on Tue, 19 Jan 2021 12:38:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5277">@shay</a></p>
<p dir="auto">sorry, my bad. I incorrectly assumed you'd be using an <a href="https://m5stack.com/collections/m5-base/products/m5go-battery-bottom2-for-core2-only" target="_blank" rel="noopener noreferrer nofollow ugc">M5GO2 bottom</a> with your M5Core2 which exposes ports B and C.</p>
<p dir="auto">You are correct, the only port directly available on M5Core2 is port A, which by default is used for I2C and not serial. So yes, I guess the easiest for you is to get an M5GO2 bottom.</p>
]]></description><link>https://community.m5stack.com/post/11863</link><guid isPermaLink="true">https://community.m5stack.com/post/11863</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 19 Jan 2021 12:38:03 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;ve tried using Serial1,2,3 or using HardwareSerial but I couldn&#x27;t get anything out of the GPS on Mon, 18 Jan 2021 22:10:00 GMT]]></title><description><![CDATA[<p dir="auto">Well it didn't really worked, but I think I'm getting confused here, my GPS module AT6558 says PORT C UART while it actually connects to PORT A on the Core2, is that ok, and if yes then why it still doesn't work?</p>
]]></description><link>https://community.m5stack.com/post/11862</link><guid isPermaLink="true">https://community.m5stack.com/post/11862</guid><dc:creator><![CDATA[shay]]></dc:creator><pubDate>Mon, 18 Jan 2021 22:10:00 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;ve tried using Serial1,2,3 or using HardwareSerial but I couldn&#x27;t get anything out of the GPS on Mon, 18 Jan 2021 19:29:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5277">@shay</a></p>
<p dir="auto">please check out my info <a href="https://community.m5stack.com/topic/2771/core2-portc-not-working/2">here</a>.</p>
<p dir="auto">Hope it helps!</p>
<p dir="auto">Cheers<br />
]]></description><link>https://community.m5stack.com/post/11859</link><guid isPermaLink="true">https://community.m5stack.com/post/11859</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 18 Jan 2021 19:29:16 GMT</pubDate></item><item><title><![CDATA[Reply to I&#x27;ve tried using Serial1,2,3 or using HardwareSerial but I couldn&#x27;t get anything out of the GPS on Mon, 18 Jan 2021 19:25:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5277">@shay</a> said in <a href="/post/11857">I've tried using Serial1,2,3 or using HardwareSerial but I couldn't get anything out of the GPS</a>:</p>
<p dir="auto">I'm new to this forum ... I thought the title will say that I couldn't get GPS AT6558 to work with Core 2</p>
]]></description><link>https://community.m5stack.com/post/11858</link><guid isPermaLink="true">https://community.m5stack.com/post/11858</guid><dc:creator><![CDATA[shay]]></dc:creator><pubDate>Mon, 18 Jan 2021 19:25:22 GMT</pubDate></item></channel></rss>
