<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[solved] ESPNow Programm works fine in RUN-Mode but not in DOWNLAD-Mode]]></title><description><![CDATA[<p dir="auto">I write a Programm with Blockly with uses ESPNow. It works fine if i use the RUN-Mode. But if I load it down to the Device (M5Stck C) the ESP-Part don't work. Why that?</p>
]]></description><link>https://community.m5stack.com/topic/2671/solved-espnow-programm-works-fine-in-run-mode-but-not-in-downlad-mode</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 04:41:17 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2671.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Dec 2020 21:39:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [solved] ESPNow Programm works fine in RUN-Mode but not in DOWNLAD-Mode on Mon, 04 Jan 2021 15:45:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter" aria-label="Profile: peter">@<bdi>peter</bdi></a><br />
I have found the problem:<br />
In RUN mode, the block "Set Communucation Channel" is not executed. The units work on the default channel 6. I had selected channel 1, as it is emptier for me. After downloading into the device, however, the channel block was executed and the device ran on channel 1. That is why the devices did not find each other. After I changed the script to channel 6, it works as it should.</p>
<p dir="auto">Translated with <a href="http://www.DeepL.com/Translator" target="_blank" rel="noopener noreferrer nofollow ugc">www.DeepL.com/Translator</a> (free version)</p>
]]></description><link>https://community.m5stack.com/post/11537</link><guid isPermaLink="true">https://community.m5stack.com/post/11537</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Mon, 04 Jan 2021 15:45:22 GMT</pubDate></item></channel></rss>
