<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Paper EPD power consumption]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">Just got my M5Paper these days and was playing with it, measuring the power consumption, figuring out the best way to approach writing a low power application for it. I really love the form factor and the capabilities. Figured out how to send esp32 in deep sleep and wake it via touch gestures (using doze mode).</p>
<p dir="auto">I disconnected the internal battery and connected a lab power supply (4.2V) and tested the calculator app (while idling - no touch events, no screen updates)</p>
<li>169 mA - with the default app</li>
<li>93 mA - with EPD power disabled</li>
<p dir="auto">My question is: why does the EPD consume so much power (<strong>almost half!</strong>) while the screen is idle? I was expecting it to be close to nothing.<br />
Do I have a defective unit? Or can this be optimized in the EPD driver?</p>
]]></description><link>https://community.m5stack.com/topic/2581/m5paper-epd-power-consumption</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 08:45:56 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2581.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Dec 2020 18:00:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Paper EPD power consumption on Wed, 27 Sep 2023 17:34:59 GMT]]></title><description><![CDATA[<p dir="auto">The E-Ink Paper Display (EPD) on the M5Paper consumes power even when the screen is idle due to its underlying technology. E-Ink displays are different from traditional LCD or OLED screens in that they only consume power when the content on the screen is changed. Once an image or text is displayed on an E-Ink screen, it doesn't require any power to maintain that state. However, changing the content on the screen, such as refreshing to display a new image or text, does consume power.</p>
<p dir="auto">In your case, when the EPD power is disabled, the display is essentially turned off, and it consumes very little to no power because it's not actively refreshing the content. When you enable the EPD power and the display is idle<a href="https://www.healthquestbilling.com/reporting-and-analytics-services/" target="_blank" rel="noopener noreferrer nofollow ugc">,</a> it's likely in a state where it's ready to receive new content and is therefore consuming some power in anticipation of a refresh.</p>
<p dir="auto">The power consumption you're observing is not necessarily a sign of a defective unit but rather a characteristic of E-Ink displays. If you want to optimize power consumption further for your low-power application, you might consider:</p>
<p dir="auto">Reducing Refresh Rate: Minimize the frequency of screen refreshes. E-Ink displays are typically used in applications where the content doesn't change frequently. You can adjust the refresh rate to be as infrequent as possible to save power.</p>
<p dir="auto">Full Screen Updates: Instead of partial screen updates, use full screen updates when you need to change the content. Partial updates can be more power-intensive.</p>
<p dir="auto">Deep Sleep: Continue using the deep sleep mode of the ESP32 when the screen is idle. This will significantly reduce overall power consumption.</p>
<p dir="auto">Optimize Code: Make sure your code is efficiently managing the display and other peripherals. Ensure that you are properly putting the ESP32 into deep sleep mode when it's not actively needed.</p>
<p dir="auto">Hardware Modifications: Depending on your specific use case, you might consider hardware modifications to further reduce power consumption. This could involve custom power management circuitry or using different power supplies.</p>
]]></description><link>https://community.m5stack.com/post/22327</link><guid isPermaLink="true">https://community.m5stack.com/post/22327</guid><dc:creator><![CDATA[LynneCosme]]></dc:creator><pubDate>Wed, 27 Sep 2023 17:34:59 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Tue, 16 May 2023 10:55:03 GMT]]></title><description><![CDATA[<p dir="auto">The power consumption you're observing on your M5Paper when the EPD (Electrophoretic Display) is idle is indeed higher than expected. It's unlikely that you have a defective unit, as the behavior you described is more likely related to software or driver optimization.</p>
<p dir="auto">EPD displays typically have low power consumption because they require power only during screen updates. Once the image is displayed, the EPD consumes very little power to maintain the image. However, it's possible that the EPD driver or the default app on your M5Paper is not optimized for low power consumption during idle periods.</p>
<p dir="auto">To optimize the EPD power consumption during idle periods, you could try the following steps:</p>
<p dir="auto">Check for firmware updates: Ensure that you have the latest firmware version for your M5Paper. Manufacturers often release firmware updates that include optimizations and bug fixes that can improve power efficiency.</p>
<p dir="auto">Look for power-saving options: Check if there are any power-saving options available in the EPD driver or the default app settings. Some devices offer options to reduce the refresh rate or enable power-saving modes for the EPD.</p>
<p dir="auto">Consider customizing the EPD driver: If you have experience with programming and access to the EPD driver source code<a href="https://www.elev8glassgallery.com/desktop-vaporizer-the-silver-surfer-vaporizer-diffuser-classic-design-ssv/" target="_blank" rel="noopener noreferrer nofollow ugc">,</a> you can explore the possibility of customizing the driver to optimize power consumption during idle periods. This might involve tweaking the refresh mechanism or implementing additional power-saving features.</p>
<p dir="auto">It's worth noting that while EPD displays are generally power-efficient, power consumption can vary depending on factors like display size, color depth, and the specific implementation of the EPD driver. Therefore, it's not uncommon to encounter variations in power consumption between different devices or even different firmware versions.</p>
]]></description><link>https://community.m5stack.com/post/20856</link><guid isPermaLink="true">https://community.m5stack.com/post/20856</guid><dc:creator><![CDATA[LynneCosme]]></dc:creator><pubDate>Tue, 16 May 2023 10:55:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Wed, 17 Mar 2021 21:36:21 GMT]]></title><description><![CDATA[<p dir="auto">Use :</p>
<pre><code>void GT911::updateB()						// as update but modify by Bricox ...
    r814E.reads = read(0x814E);				// "read struct" AND these 5 explicite bits fields
    if(r814E.status)
        if(r814E.touchPts != 0)
            _is_finger_up = false;
            _num = r814E.touchPts;			// "_num" could be definitively replaced by "r814E.touchPts"
            uint8_t data[num * 8];
            read(0x8150, data, _num * 8);	// read block of all fingers , up to 5*8 bytes
            for(int j = 0; j &lt; _num; j++)	// for each finger
                uint8_t *buf = data + j * 8;// address base of each finger
<p dir="auto">Sorry, comments that were aligned, in my notepad++ by multiple Tabs, are no longer aligned in the snippets viewer</p>
]]></description><link>https://community.m5stack.com/post/13065</link><guid isPermaLink="true">https://community.m5stack.com/post/13065</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Wed, 17 Mar 2021 21:36:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Mon, 22 Mar 2021 20:16:55 GMT]]></title><description><![CDATA[<p dir="auto">Structure</p>
<pre><code>typedef struct reg814E_s {		//
 union {						// same location of 2 fields of 1 byte
   uint8_t reads;				// this byte
   struct {					// field bits of this byte
     uint8_t touchPts  : 4;	// b0 to b3 : number of touch points
     uint8_t haveKey   : 1;	// b4 : HaveKey
     uint8_t proxi     : 1;	// b5 : Proximity Valid
     uint8_t largeDet  : 1;	// b6 : large detect
     uint8_t status    : 1;	// b7 : buffer status
} __attribute__((packed)) reg814E_t;	// minimize memory alignment
<p dir="auto">or simpler writing</p>
<pre><code>typedef struct {
    struct {           // field bits of this byte, starting with low weight
      uint8_t
        touchPts  : 4, // b0 to b3 : number of touch points
        haveKey   : 1, // b4 : HaveKey
        proxi     : 1, // b5 : Proximity Valid
        largeDet  : 1, // b6 : large detect
} reg814E_t;
<p dir="auto">Declarations</p>
<pre><code>private:
    bool _is_finger_up = false;
    uint8_t _num = 0;
    uint8_t _rotate = ROTATE_0;
    tp_finger_t _fingers[2];
    reg814E_t r814E;
    uint8_t _iic_addr = 0x14;
    uint8_t _pin_int = -1;
    bool _sleeping = false;
]]></description><link>https://community.m5stack.com/post/13064</link><guid isPermaLink="true">https://community.m5stack.com/post/13064</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Mon, 22 Mar 2021 20:16:55 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Wed, 17 Mar 2021 21:23:49 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a>,</p>
<p dir="auto">While I was commenting on the source code, I found un bug in the GT911 driver :<br />
<code>_fingers[]</code> can be indexed up to 5<br />
<img src="/assets/uploads/files/1615984072764-8f7e3c61-28a7-42c1-8623-ea7928136753-image.png" alt="0_1615984070738_8f7e3c61-28a7-42c1-8623-ea7928136753-image.png" class=" img-fluid img-markdown" /><br />
In declaration, <code>_fingers[]</code> can be indexed up to 2<br />
<img src="/assets/uploads/files/1615984225227-b83a9d9e-e32d-4ca9-905f-fc2a4eb6e57b-image.png" alt="0_1615984224513_b83a9d9e-e32d-4ca9-905f-fc2a4eb6e57b-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">In addition, it would be elegant to use bit fields for describing registers that have specific functions.<br />
An example : <img src="/assets/uploads/files/1615984404051-5b228515-423f-44aa-ad3a-d75715da83e9-image-resized.png" alt="0_1615984402868_5b228515-423f-44aa-ad3a-d75715da83e9-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/13063</link><guid isPermaLink="true">https://community.m5stack.com/post/13063</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Wed, 17 Mar 2021 21:23:49 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Wed, 17 Mar 2021 08:49:07 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5704">@bricox</a></p>
<p dir="auto">in M5Paper GPIO0 (together with ESP32_EN) already is connected to the boot / download mechanism which is controlled by CP_RTS and CP_DTR from the USB chip. ESP32_EN is also connected to the touch reset line which together with the touch INT line determine which I2C address the touch IC is going to use.</p>
<p dir="auto">If you also connect GPIO0 to the touch INT line, GPIO0 and ESP32_EN will not only determine the ESP32 boot mode but also the touch IC I2C address depending on what CP_RTS and CP_DTR are doing.</p>
<p dir="auto">On the other hand controlling GPIO0 from code to put the touch IC into sleep mode might have a negative effect on the automatic boot / download mechanism.</p>
<p dir="auto">I personally would leave GPIO0 alone, but in general it is correct that GPIO0 can be used as output if needed.</p>
]]></description><link>https://community.m5stack.com/post/13060</link><guid isPermaLink="true">https://community.m5stack.com/post/13060</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 17 Mar 2021 08:49:07 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Tue, 16 Mar 2021 20:03:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a></p>
<p dir="auto">Find 1 output, to put low the INT signal of GT911, have another way possible ....<br />
In the ESP pdf, I found this :<br />
<img src="/assets/uploads/files/1615924513776-1f8661ba-bd5a-4d76-a558-18ffea82d6d8-image-resized.png" alt="0_1615924512661_1f8661ba-bd5a-4d76-a558-18ffea82d6d8-image.png" class=" img-fluid img-markdown" /><br />
For reuse these pins, an article  : <a href="https://www.instructables.com/ESP8266-Using-GPIO0-GPIO2-as-inputs/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.instructables.com/ESP8266-Using-GPIO0-GPIO2-as-inputs/</a><br />
I think that, in the M5paper, we can use GPIO0 as output.<br />
What you think about ?</p>
]]></description><link>https://community.m5stack.com/post/13050</link><guid isPermaLink="true">https://community.m5stack.com/post/13050</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Tue, 16 Mar 2021 20:03:04 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Tue, 16 Mar 2021 15:20:06 GMT]]></title><description><![CDATA[<p dir="auto">hello,</p>
<p dir="auto">a little bit of electronics (because no present in official doc) :</p>
<p dir="auto"><img src="/assets/uploads/files/1615907598462-012bf0da-f9ae-4cb6-90e6-45a8efbcad81-image.png" alt="0_1615907585552_012bf0da-f9ae-4cb6-90e6-45a8efbcad81-image.png" class=" img-fluid img-markdown" /><br />
The PFL with C1, C2, C3, C4 R1 and C5:<br />
<img src="/assets/uploads/files/1615907935848-16b48c7b-d348-47ab-860e-a68f73c0f68e-image-resized.png" alt="0_1615907925252_16b48c7b-d348-47ab-860e-a68f73c0f68e-image.png" class=" img-fluid img-markdown" /><br />
Remark : pin 7&amp;8 are "shield"</p>
]]></description><link>https://community.m5stack.com/post/13047</link><guid isPermaLink="true">https://community.m5stack.com/post/13047</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Tue, 16 Mar 2021 15:20:06 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Mon, 15 Mar 2021 20:48:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys .... <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a>, <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/226">@fonix232</a>, <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5452">@tatar-andrei</a>... and other enthusiasts ....</p>
<p dir="auto">I have others links for the GT911 driver in cpp<br />
With interrupt : <a href="https://github.com/nik-sharky/arduino-goodix/blob/master/Goodix.cpp" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/nik-sharky/arduino-goodix/blob/master/Goodix.cpp</a><br />
No interrupt but handles 5 fingers : <a href="https://github.com/caiannello/ER-TFTM0784-1/blob/master/src/touch.cpp" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/caiannello/ER-TFTM0784-1/blob/master/src/touch.cpp</a></p>
<p dir="auto">We’ll have to adapt these source codes.</p>
<p dir="auto">Sorry, i'm not a specialist for interrupts of Arduino framework....I am more familiar with the HAL framework of the STM32.</p>
<p dir="auto">Thank you for these sustained sharing</p>
]]></description><link>https://community.m5stack.com/post/13036</link><guid isPermaLink="true">https://community.m5stack.com/post/13036</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Mon, 15 Mar 2021 20:48:28 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Mon, 15 Mar 2021 11:02:55 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5704">@bricox</a> - thank you for the links. I appreciate it. I already had the programming guide, but not the datasheet.</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/226">@fonix232</a> - so far I have not tried the gesture mode.</p>
<p dir="auto">I am curious about what you guys are going to find regarding other modes.</p>
]]></description><link>https://community.m5stack.com/post/13019</link><guid isPermaLink="true">https://community.m5stack.com/post/13019</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 15 Mar 2021 11:02:55 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Mon, 15 Mar 2021 10:48:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5704">@bricox</a> based on the documentation, it should be possible to set the touch panel in a gesture recognising mode - would be nice to be able to offload that from the ESP32, alongside the interrupt-instead-of-poll change. This would certainly improve battery life.</p>
]]></description><link>https://community.m5stack.com/post/13018</link><guid isPermaLink="true">https://community.m5stack.com/post/13018</guid><dc:creator><![CDATA[fonix232]]></dc:creator><pubDate>Mon, 15 Mar 2021 10:48:17 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Mon, 15 Mar 2021 10:23:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a><br />
To fully understand the GT911 controller, download these 2 pdf<br />
<img src="/assets/uploads/files/1615801739776-a92c71b1-cc76-49b8-9bef-90da8225880d-image-resized.png" alt="0_1615801735370_a92c71b1-cc76-49b8-9bef-90da8225880d-image.png" class=" img-fluid img-markdown" /><br />
<a href="https://www.crystalfontz.com/controllers/GOODIX/GT911/464/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.crystalfontz.com/controllers/GOODIX/GT911/464/</a><br />
<a href="https://www.crystalfontz.com/controllers/GOODIX/GT911ProgrammingGuide/478/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.crystalfontz.com/controllers/GOODIX/GT911ProgrammingGuide/478/</a></p>
<p dir="auto">Several developments are desirable :</p>
<li>read position under interrupt and not in polling mode [GT911::update()]</li>
<li>Exploit more all modes</li>
<li>Check if the "green mode" (3.3mA) automatically change after 1 second of inactivity</li>
<li>Generate a sound when you touch it</li>
<p dir="auto">List of 21 other GT911 drivers :<br />
<a href="https://github.com/search?q=gt911" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/search?q=gt911</a><br />
including one in cpp:<br />
<a href="https://github.com/blackketter/GT911/blob/master/src/GT911.cpp" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/blackketter/GT911/blob/master/src/GT911.cpp</a></p>
]]></description><link>https://community.m5stack.com/post/13017</link><guid isPermaLink="true">https://community.m5stack.com/post/13017</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Mon, 15 Mar 2021 10:23:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Thu, 11 Mar 2021 19:24:53 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5704">@bricox</a></p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5704">@bricox</a> said in <a href="/post/12928">M5Paper EPD power consumption</a>:</p>
<p dir="auto">Do you share your source code?</p>
<p dir="auto">Sure, you can find my touch sleep mode test sketch <a href="https://github.com/felmue/M5EPD/tree/fm-touch-sleep-mode-test-1" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
<p dir="auto">It's a extended version of the TOUCH example which uses the left/up button to set touch into normal mode and right/down button to set into sleep mode.</p>
<p dir="auto">Cheers<br />
]]></description><link>https://community.m5stack.com/post/12937</link><guid isPermaLink="true">https://community.m5stack.com/post/12937</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 11 Mar 2021 19:24:53 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Thu, 11 Mar 2021 16:35:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a><br />
I did a summary of the 3 ports A, B and C<br />
<img src="/assets/uploads/files/1615480307556-c98a3e9f-53d3-4dda-989f-1548a6530bac-image.png" alt="0_1615480305762_c98a3e9f-53d3-4dda-989f-1548a6530bac-image.png" class=" img-fluid img-markdown" /><br />
You made a good choice using GPIO19.<br />
Indeed, welding work is simplified.<br />
]]></description><link>https://community.m5stack.com/post/12928</link><guid isPermaLink="true">https://community.m5stack.com/post/12928</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Thu, 11 Mar 2021 16:35:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Thu, 11 Mar 2021 15:45:44 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5704">@bricox</a></p>
<p dir="auto">very elegant solution. Thank you for sharing.</p>
<p dir="auto">I opted to leave GPIO36 as is and connected GPIO19 (from port C) in parallel which I can then set to output if I want to use touch sleep mode. (Yes, I loose port C, but it made the soldering a bit easier. Only one additional wire from a pin on port C to the unpopulated R87 pad.)</p>
]]></description><link>https://community.m5stack.com/post/12925</link><guid isPermaLink="true">https://community.m5stack.com/post/12925</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 11 Mar 2021 15:45:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Thu, 11 Mar 2021 15:24:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5704">@bricox</a><br />
<img src="/assets/uploads/files/1615476234701-7ba0fa7a-2234-4eb5-bf2b-40ca8229e42a-image.png" alt="0_1615476228608_7ba0fa7a-2234-4eb5-bf2b-40ca8229e42a-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/12924</link><guid isPermaLink="true">https://community.m5stack.com/post/12924</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Thu, 11 Mar 2021 15:24:02 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Thu, 11 Mar 2021 15:58:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a><br />
Indeed GPIO36 is only input.<br />
So I looked for another GPIO used only as input to reverse the 2 GPIO on the pcb.<br />
I found the GPIO27 which tells ESP32 that the IT8951 is ready for a SPI dialogue</p>
<p dir="auto">IT_SPI_HRDY (schema)<br />
#define M5EPD_BUSY_PIN 27 (M5EPD.h)<br />
EPD.begin(M5EPD_SCK_PIN, M5EPD_MOSI_PIN, M5EPD_MISO_PIN, M5EPD_CS_PIN, M5EPD_BUSY_PIN); (M5EPD.cpp)<br />
m5epd_err_t M5EPD_Driver::begin(int8_t sck, int8_t mosi, int8_t miso, int8_t cs, int8_t busy, int8_t rst)<br />
_pin_busy = busy;<br />
pinMode(_pin_busy, INPUT);</p>
<p dir="auto"><img src="/assets/uploads/files/1615456720749-50c5a8ea-8079-4817-a856-10c82417613c-image.png" alt="0_1615456717810_50c5a8ea-8079-4817-a856-10c82417613c-image.png" class=" img-fluid img-markdown" /><br />
On my pcb, the resistance R87 is absent (unwelded)<br />
All you have to do is reverse the 5 and 16 tabs on the ESP32.<br />
I scraped the varnish and then scanned the pcb.<br />
You have to cut the 2 tracks between the 2 pins of the esp32 and the 2 vias.<br />
then solder 2 thin wires.</p>
]]></description><link>https://community.m5stack.com/post/12923</link><guid isPermaLink="true">https://community.m5stack.com/post/12923</guid><dc:creator><![CDATA[bricox]]></dc:creator><pubDate>Thu, 11 Mar 2021 15:58:32 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Mon, 08 Mar 2021 12:06:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">I went ahead and modified my M5Paper so it can put the touch IC (GT911) into sleep mode. By doing so the current (measured at the battery) drops about 7.6 mA.</p>
<p dir="auto">With WiFi off, EDP power off, ESP32 in deep sleep and touch in sleep mode the overall current is about 1.6 mA.</p>
<p dir="auto">Note: since putting touch into sleep mode requires touch INT to be driven low by ESP32, touching the screen can no longer be used to wake up M5Paper.</p>
]]></description><link>https://community.m5stack.com/post/12879</link><guid isPermaLink="true">https://community.m5stack.com/post/12879</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 08 Mar 2021 12:06:47 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Fri, 05 Mar 2021 10:25:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5452">@tatar-andrei</a></p>
<p dir="auto">You mention that you got the touch wakeup working. Could you share how you managed to do this?</p>
<p dir="auto">I have searched and tried everything. I have had no luck with the touch wakeup. Currently my Homekit panel runs for about 5 hours without any sleep setup. This is just too low. I only need to use it couple of times a day and most of the time it should be on sleep.</p>
]]></description><link>https://community.m5stack.com/post/12840</link><guid isPermaLink="true">https://community.m5stack.com/post/12840</guid><dc:creator><![CDATA[Joonas]]></dc:creator><pubDate>Fri, 05 Mar 2021 10:25:55 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Mon, 08 Feb 2021 14:08:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4037">@felmue</a> that definitely sounds like a massive design issue - I wonder, maybe that's why the M5EPD library doesn't have any touchscreen power-off calls?</p>
<p dir="auto">There was also a post on the M5Stack twitter recently, showing a blurred out image of upcoming devices, with a device eerily similar to the M5Paper taking up a large chunk of the photo: <a href="https://twitter.com/M5Stack/status/1357559621389479940/photo/1" target="_blank" rel="noopener noreferrer nofollow ugc">https://twitter.com/M5Stack/status/1357559621389479940/photo/1</a></p>
<p dir="auto">I wonder if the design team realised these small issues and made a new board that is more fit for general usage purposes. It happened with the M5Cores (the Basic model had no PSRAM and the first units only had 4MB storage, which later got expanded to 16MB, then the Grey kit came with an MPU, then the Fire kit also included a microphone and PSRAM, among other changes), though the speed is much faster - I think there was almost a year between the Basic and Grey M5Cores, whereas the M5Paper was only recently released.</p>
<p dir="auto">It does feel like a slap in the face for us who already bought multiple M5Paper units though - we've received a device that has a handful of obvious faulty design choices, and now we have to buy the new, updated model to get functionality that should've been working in the first iteration. Don't get me wrong, I'm happy for the updated design, I just hope there will be some discount for those who've already got units on their hands.</p>
]]></description><link>https://community.m5stack.com/post/12359</link><guid isPermaLink="true">https://community.m5stack.com/post/12359</guid><dc:creator><![CDATA[fonix232]]></dc:creator><pubDate>Mon, 08 Feb 2021 14:08:30 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Sun, 07 Feb 2021 09:22:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">I think I found the reason for why the touch IC (GT911) did not react when I tried to put it into sleep mode. The procedure asks for the ESP32 GPIO used for the touch interrupt to change to an output and then be driven low by the ESP32. Unfortunately GPIO36 is used for the touch interrupt and that is one of the few GPIOs which can only be used as input. So without hardware modification I don't see a way to put the touch IC into sleep mode. Or am I missing something?</p>
]]></description><link>https://community.m5stack.com/post/12349</link><guid isPermaLink="true">https://community.m5stack.com/post/12349</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 07 Feb 2021 09:22:59 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Sat, 06 Feb 2021 15:25:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">I just discovered that the voltage divider used to feed the battery voltage into the ADC uses different values from what's listed in the M5Paper schematic.</p>
<li>M5Paper schematics: 3 kOhm and 11 kOhm  -&gt; factor: 0.78571428571</li>
<li>found in my M5Paper: 10 kOhm and 10 kOhm -&gt; factor: 0.5</li>
<p dir="auto">With the actual values the modified SCALE factor (0.785.. -&gt; 0.5) found in the library also makes more sense. It compensates the voltage divider.</p>
<p dir="auto">BTW: when you feed 4.2 V into the original 3 kOhm / 11 kOhm voltage divider you get exactly 3.3 V. So I guess initially M5Paper was designed / planned to use a 4.2 V battery.</p>
]]></description><link>https://community.m5stack.com/post/12343</link><guid isPermaLink="true">https://community.m5stack.com/post/12343</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 06 Feb 2021 15:25:02 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Fri, 05 Feb 2021 10:01:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5452">@tatar-andrei</a> said in <a href="/post/11154">M5Paper EPD power consumption</a>:</p>
<p dir="auto">months on a battery charge"</p>
<p dir="auto">registered a new account for replying this.. not currently a M5Paper owner but will buy one soon!<br />
I happened to be involved in a ESP + 8951 epaper project months ago, the target is months on battery charge (3xAAA battery).<br />
Main env is done using arduino, and scriptable via Lua. UI is rendered on server, send down to the device during idle &amp; stitched with Lua (it's a calendar kind of device).</p>
<p dir="auto">repo is @ <a href="https://github.com/luan007/em_playbook" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/luan007/em_playbook</a><br />
hope some code / impl provides some reference ..</p>
]]></description><link>https://community.m5stack.com/post/12332</link><guid isPermaLink="true">https://community.m5stack.com/post/12332</guid><dc:creator><![CDATA[mikeluan]]></dc:creator><pubDate>Fri, 05 Feb 2021 10:01:18 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper EPD power consumption on Fri, 05 Feb 2021 08:23:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5452">@tatar-andrei</a> said in <a href="/post/11367">M5Paper EPD power consumption</a>:</p>
<p dir="auto">I did play around more with power down states and I managed to get a light sleep mode with fast wakeup from touch at around ~9mA.</p>
<p dir="auto">Hello <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/5452">@tatar-andrei</a></p>
<p dir="auto">I tried to get the touch into sleep mode by applying the steps outlined in the GT911 programming guide but I don't see any reduction in power consumption.<br />
The steps are:</p>
<li>switch ESP32 interrupt GPIO from input to output and set it low</li>
<li>issue command 0x05 to address 0x8040</li>
<p dir="auto">is there anything else that needs to be done? I'd appreciate your insight on that.</p>
<p dir="auto">Thank you very much in advance.</p>
]]></description><link>https://community.m5stack.com/post/12303</link><guid isPermaLink="true">https://community.m5stack.com/post/12303</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 05 Feb 2021 08:23:25 GMT</pubDate></item></channel></rss>
