<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[solved] Can I use the USB-C Port ans seriall - Usb Converter to Communicate with an PC?]]></title><description><![CDATA[<p dir="auto">I want to exchange ESP-Now data with a M5Stick C via USB with a PC. Is there a way to do this?</p>
<p dir="auto">TNX<br />
Peter</p>
]]></description><link>https://community.m5stack.com/topic/2576/solved-can-i-use-the-usb-c-port-ans-seriall-usb-converter-to-communicate-with-an-pc</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 11:04:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2576.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Dec 2020 23:02:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [solved] Can I use the USB-C Port ans seriall - Usb Converter to Communicate with an PC? on Sat, 26 Dec 2020 16:04:35 GMT]]></title><description><![CDATA[<p dir="auto">Tnx sodoku.</p>
<p dir="auto">If found the Problem was only in my head. It works with TX-Pin 1 and RX-Pin 3!</p>
]]></description><link>https://community.m5stack.com/post/11378</link><guid isPermaLink="true">https://community.m5stack.com/post/11378</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Sat, 26 Dec 2020 16:04:35 GMT</pubDate></item><item><title><![CDATA[Reply to [solved] Can I use the USB-C Port ans seriall - Usb Converter to Communicate with an PC? on Fri, 11 Dec 2020 17:34:57 GMT]]></title><description><![CDATA[<p dir="auto">If you use the <code>print</code> block from the <code>Text</code> section in UIFlow, you can see the output in a serial monitor (if the device is connected to the PC via usb). The M5Burner comes included with a serial monitor. It is in the top right, named "COM Monitor".</p>
]]></description><link>https://community.m5stack.com/post/11161</link><guid isPermaLink="true">https://community.m5stack.com/post/11161</guid><dc:creator><![CDATA[sodoku]]></dc:creator><pubDate>Fri, 11 Dec 2020 17:34:57 GMT</pubDate></item></channel></rss>
