<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to change the I2C adress of a module ?]]></title><description><![CDATA[<p dir="auto">I want to use 2 COPLUS motor driver moduls for 4 DC motors.<br />
I read in the forum that I have to change to I2C adress via a modification of the firmeware. (change the default adress and burn a new firmware.)<br />
How can I do that ? is there a special software ?<br />
Is there a list of used I2C adresses inside the M5Stack system - so I canfind a "free" I2C adress ?</p>
<p dir="auto">OR .... is there an easy way to controll 4 DC motors ?</p>
<p dir="auto">K.D.</p>
]]></description><link>https://community.m5stack.com/topic/2574/how-to-change-the-i2c-adress-of-a-module</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 09:38:54 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2574.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Dec 2020 14:47:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to change the I2C adress of a module ? on Fri, 11 Dec 2020 11:20:33 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Oh - I made a mistake !</strong><br />
It is not the software "M5burner" - this is clear for me - excuse me.</p>
<p dir="auto"><strong>I do not understand "EasyLoader".</strong><br />
This software is mentioned on the top of every documentation and there are different versions for every unit.<br />
But what is the software flashing ?  -<br />
I know that EasyLoader flashing "a firmware" - but were is it from and what firmware ?</p>
<p dir="auto">Is it a kind of update service ?</p>
<p dir="auto">In one topic of this forum it is said, that I can cange the I2C adress with this software. I have only change a line value inside a file or script ??? no more info.</p>
<p dir="auto">Do you know more about that software and how it is working ?</p>
<p dir="auto">Thank you again for your helpful answers.<br />
regards<br />
K.D.</p>
<p dir="auto">p.s. I'm exited too about M5Stack and I want to use it in a autonomous vehicle. That's why I'm asking for the use of multiple sensors and motors.</p>
]]></description><link>https://community.m5stack.com/post/11155</link><guid isPermaLink="true">https://community.m5stack.com/post/11155</guid><dc:creator><![CDATA[ramaker]]></dc:creator><pubDate>Fri, 11 Dec 2020 11:20:33 GMT</pubDate></item><item><title><![CDATA[Reply to How to change the I2C adress of a module ? on Fri, 11 Dec 2020 10:12:04 GMT]]></title><description><![CDATA[<p dir="auto">There is are quick start guides that also explain how to use M5Burner. Here is one <a href="https://docs.m5stack.com/#/en/quick_start/m5core/m5stack_core_get_started_MicroPython?id=m5burner" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/quick_start/m5core/m5stack_core_get_started_MicroPython?id=m5burner</a></p>
]]></description><link>https://community.m5stack.com/post/11153</link><guid isPermaLink="true">https://community.m5stack.com/post/11153</guid><dc:creator><![CDATA[sodoku]]></dc:creator><pubDate>Fri, 11 Dec 2020 10:12:04 GMT</pubDate></item><item><title><![CDATA[Reply to How to change the I2C adress of a module ? on Fri, 11 Dec 2020 10:09:55 GMT]]></title><description><![CDATA[<p dir="auto">I am just very excited about M5Stack stuff at the moment and I am poking around everywhere. :)</p>
<p dir="auto">I found that table at <a href="https://docs.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">docs.m5stack.com</a> in the top navigation:</p>
<p dir="auto"><img src="/assets/uploads/files/1607681384848-screenshot-2020-12-11-110742-resized.jpg" alt="0_1607681378871_Screenshot 2020-12-11 110742.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/11152</link><guid isPermaLink="true">https://community.m5stack.com/post/11152</guid><dc:creator><![CDATA[sodoku]]></dc:creator><pubDate>Fri, 11 Dec 2020 10:09:55 GMT</pubDate></item><item><title><![CDATA[Reply to How to change the I2C adress of a module ? on Fri, 11 Dec 2020 09:01:07 GMT]]></title><description><![CDATA[<p dir="auto">Thank you - thats helpfull !!<br />
Just a little question - maybe a Dummy question:<br />
How do you know that ?<br />
How do you know that there is an adress like you send me ?</p>
<p dir="auto">Is there any documentatio I have to go thru - to know all that things ??</p>
<hr />
<p dir="auto">Next thing concerning I2C change:<br />
I read, that I should use a software called "M5burner"., It is the same that I find in every documentation in the beginning.<br />
There you should have the possibility to download firmware and flash it.<br />
I tried the software, but I can not find any possibility for download a firmware or a piece of software.<br />
Is there a documentation for "M5burner" ?<br />
regards<br />
K.D.</p>
]]></description><link>https://community.m5stack.com/post/11148</link><guid isPermaLink="true">https://community.m5stack.com/post/11148</guid><dc:creator><![CDATA[ramaker]]></dc:creator><pubDate>Fri, 11 Dec 2020 09:01:07 GMT</pubDate></item><item><title><![CDATA[Reply to How to change the I2C adress of a module ? on Thu, 10 Dec 2020 21:09:07 GMT]]></title><description><![CDATA[<p dir="auto">The documentation page has a list of i2c addresses:<br />
<a href="https://static-cdn.m5stack.com/image/m5-docs_table/I2C_Address.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">https://static-cdn.m5stack.com/image/m5-docs_table/I2C_Address.pdf</a></p>
]]></description><link>https://community.m5stack.com/post/11138</link><guid isPermaLink="true">https://community.m5stack.com/post/11138</guid><dc:creator><![CDATA[sodoku]]></dc:creator><pubDate>Thu, 10 Dec 2020 21:09:07 GMT</pubDate></item></channel></rss>
