<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[m5stack fire charging detection]]></title><description><![CDATA[<p dir="auto">I received my m5stack fire kit today, so I'm quite new to this. I wrote a program that shows whether or not the battery is charging (using <code>power.isCharging()</code>). If I run it with the USB connected to the Fire, it shows as charging. However, if I run it with the USB connected to the M5GO CHG Base, it does not show as charging. Is this expected?</p>
]]></description><link>https://community.m5stack.com/topic/2340/m5stack-fire-charging-detection</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 02:20:52 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2340.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Sep 2020 07:11:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to m5stack fire charging detection on Tue, 20 Oct 2020 20:13:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/michaelblight" aria-label="Profile: michaelblight">@<bdi>michaelblight</bdi></a></p>
<p dir="auto">yes, that is to be expected. The M5GO CHG Base has it's own charger IC which is used in this case.</p>
]]></description><link>https://community.m5stack.com/post/10407</link><guid isPermaLink="true">https://community.m5stack.com/post/10407</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 20 Oct 2020 20:13:22 GMT</pubDate></item></channel></rss>
