<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5CAM board in Arduino]]></title><description><![CDATA[<p dir="auto">I am new to the electronic world and I am trying to run a demo code on a M5CAM with the Arduino IDE i just dont know how to manage the board. I guess there is something i need to install but i am really not sure. Any idea how ?</p>
]]></description><link>https://community.m5stack.com/topic/2142/m5cam-board-in-arduino</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 19:14:47 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2142.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jul 2020 11:00:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5CAM board in Arduino on Fri, 31 Jul 2020 23:11:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a></p>
<p dir="auto">With M5Cam is there a menu config example to make this work correctly. I have tried many configurations and it reboots on load .</p>
<p dir="auto">Any suggestions would be great, I have had it working with the firmware you supply but cannot get the menu config working.</p>
<p dir="auto">Thanks</p>
<pre><code>Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:4
load:0x3fff0034,len:7500
load:0x40078000,len:15364
load:0x40080400,len:4832
entry 0x400806a0
I (29) boot: ESP-IDF v4.3-dev-472-gcf056a7d0 2nd stage bootloader
I (29) boot: compile time 17:27:20
I (29) boot: chip revision: 1
I (33) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (40) qio_mode: Enabling default flash chip QIO
I (46) boot.esp32: SPI Speed      : 80MHz
I (50) boot.esp32: SPI Mode       : QIO
I (55) boot.esp32: SPI Flash Size : 4MB
I (59) boot: Enabling RNG early entropy source...
I (65) boot: Partition Table:
I (68) boot: ## Label            Usage          Type ST Offset   Length
I (76) boot:  0 factory          factory app      00 00 00010000 003c0000
I (83) boot:  1 nvs              WiFi data        01 02 003d0000 00004000
I (91) boot: End of partition table
I (95) boot_comm: chip revision: 1, min. application chip revision: 0
I (102) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1af514 (1766676) map
I (723) esp_image: segment 1: paddr=0x001bf53c vaddr=0x3ffb0000 size=0x00adc (  2780) load
I (724) esp_image: segment 2: paddr=0x001c0020 vaddr=0x400d0020 size=0x2ddd4 (187860) map
I (795) esp_image: segment 3: paddr=0x001eddfc vaddr=0x3ffb0adc size=0x02154 (  8532) load
I (798) esp_image: segment 4: paddr=0x001eff58 vaddr=0x40080000 size=0x00404 (  1028) load
I (802) esp_image: segment 5: paddr=0x001f0364 vaddr=0x40080404 size=0x10724 ( 67364) load
I (847) boot: Loaded app from partition at offset 0x10000
I (847) boot: Disabling RNG early entropy source...
I (859) psram: This chip is ESP32-D0WD
E (859) psram: PSRAM ID read error: 0xffffffff
E (859) spiram: SPI RAM enabled but initialization failed. Bailing out.
I (864) cpu_start: Failed to init external RAM; continuing without it.
I (871) cpu_start: Pro cpu up.
I (875) cpu_start: Starting app cpu, entry point is 0x40081740
I (867) cpu_start: App cpu up.
I (897) cpu_start: Pro cpu start user code
I (897) cpu_start: Application information:
I (897) cpu_start: Project name:     recognition_command_line
I (904) cpu_start: App version:      v0.9.3-46-g2470e47
I (910) cpu_start: Compile time:     Jul 25 2020 17:53:11
I (916) cpu_start: ELF file SHA256:  aabc8d81184a741d...
I (922) cpu_start: ESP-IDF:          v4.3-dev-472-gcf056a7d0
I (928) heap_init: Initializing. RAM available for dynamic allocation:
I (935) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (941) heap_init: At 3FFB45F0 len 0002BA10 (174 KiB): DRAM
I (948) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (954) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (960) heap_init: At 40090B28 len 0000F4D8 (61 KiB): IRAM
I (967) spi_flash: detected chip: gd
I (971) spi_flash: flash io: qio
I (976) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (986) sccb: pin_sda 25 pin_scl 23
I (1126) camera: Detected OV2640 camera
I (1126) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1126) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1136) gpio: GPIO[18]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1146) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1156) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1166) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1176) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1186) gpio: GPIO[17]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1196) gpio: GPIO[22]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1206) gpio: GPIO[26]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1216) gpio: GPIO[21]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (1226) camera: Allocating 1 frame buffers (15 KB total)
I (1226) camera: Allocating 15 KB frame buffer in OnBoard RAM
I (1366) app_process: Get one frame in 34 ms.
Item psram alloc failed. Size: 230400 x 1
matrix3du item alloc failed.
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x400d8d45  PS      : 0x00060330  A0      : 0x8008a43c  A1      : 0x3ffc08d0
A2      : 0x3ffb8288  A3      : 0x00000003  A4      : 0x00000000  A5      : 0x00000140
A6      : 0x000623d6  A7      : 0x000000f0  A8      : 0x800d8d24  A9      : 0x3ffc08b0
A10     : 0x3ffb83cc  A11     : 0x00000001  A12     : 0x00000000  A13     : 0x00038404
A14     : 0x00000000  A15     : 0x00000001  SAR     : 0x00000004  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000014  LBEG    : 0x400885f9  LEND    : 0x40088609  LCOUNT  : 0xfffffff8
Backtrace:0x400d8d42:0x3ffc08d0 0x4008a439:0x3ffc0950
]]></description><link>https://community.m5stack.com/post/9549</link><guid isPermaLink="true">https://community.m5stack.com/post/9549</guid><dc:creator><![CDATA[kylebuttress]]></dc:creator><pubDate>Fri, 31 Jul 2020 23:11:50 GMT</pubDate></item><item><title><![CDATA[Reply to M5CAM board in Arduino on Fri, 31 Jul 2020 06:40:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4009">@carol-villegas</a> oh,  i forget some detail.   you need setup the partition scheme to "No OTA"    <code>Tool</code>---&gt; <code>partition scheme</code>-----<code>No OTA</code></p>
]]></description><link>https://community.m5stack.com/post/9528</link><guid isPermaLink="true">https://community.m5stack.com/post/9528</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 31 Jul 2020 06:40:29 GMT</pubDate></item><item><title><![CDATA[Reply to M5CAM board in Arduino on Fri, 31 Jul 2020 06:08:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> i just recently had a problem using the code you provided me, it appears that the sketch is too big. It says "Sketch uses 2053855 bytes (156%) of program storage space. Maximum is 1310720 bytes."<br />
Is this a problem with my computer ? it is 8 ram and 1tb memory, core i7 7th generation intel processor</p>
]]></description><link>https://community.m5stack.com/post/9527</link><guid isPermaLink="true">https://community.m5stack.com/post/9527</guid><dc:creator><![CDATA[Carol Villegas]]></dc:creator><pubDate>Fri, 31 Jul 2020 06:08:29 GMT</pubDate></item><item><title><![CDATA[Reply to M5CAM board in Arduino on Fri, 31 Jul 2020 06:03:44 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much it was really helpful !</p>
]]></description><link>https://community.m5stack.com/post/9526</link><guid isPermaLink="true">https://community.m5stack.com/post/9526</guid><dc:creator><![CDATA[Carol Villegas]]></dc:creator><pubDate>Fri, 31 Jul 2020 06:03:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5CAM board in Arduino on Tue, 21 Jul 2020 01:26:23 GMT]]></title><description><![CDATA[<ol>
<li>
<p dir="auto">install esp32 board in the board manager(before install you need add board url to the perferences.  detail you could refer this tutorial :<a href="https://docs.m5stack.com/#/en/arduino/arduino_development" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/arduino/arduino_development</a>).</p>
</li>
<li>
<p dir="auto">use the esp32 official example for esp32 cam.<br />
github link:<br />
<a href="https://github.com/espressif/arduino-esp32/tree/master/libraries/ESP32/examples/Camera/CameraWebServer" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/espressif/arduino-esp32/tree/master/libraries/ESP32/examples/Camera/CameraWebServer</a></p>
</li>
]]></description><link>https://community.m5stack.com/post/9388</link><guid isPermaLink="true">https://community.m5stack.com/post/9388</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 21 Jul 2020 01:26:23 GMT</pubDate></item></channel></rss>
