<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Micropython AWS IoT connect&#x2F;add files to UI Flow?]]></title><description><![CDATA[<p dir="auto">I'd like to connect my M5StickC to AWS IoT via the UIFlow web console. The MQTT broker block on UIFlow doesn't have the options to include a certificate file needed to connect, so the Micropython tab seems like the only option. However, I don't see a way to upload files to the IDE for the certificates- I could perhaps create them in the code but I'm not sure if that's the best option. Any suggestions? Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/2001/micropython-aws-iot-connect-add-files-to-ui-flow</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 08:38:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2001.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 May 2020 20:29:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Micropython AWS IoT connect&#x2F;add files to UI Flow? on Sat, 30 May 2020 13:59:35 GMT]]></title><description><![CDATA[<p dir="auto">I assume you'll want to put the certificate in the flash. there are various ways you can transfer files to the flash, check this video on how to do so<br />
<a href="https://www.youtube.com/watch?v=bdyZx2KC54Y" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=bdyZx2KC54Y</a></p>
]]></description><link>https://community.m5stack.com/post/8873</link><guid isPermaLink="true">https://community.m5stack.com/post/8873</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Sat, 30 May 2020 13:59:35 GMT</pubDate></item></channel></rss>
