<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to get UI Flow on to device?]]></title><description><![CDATA[<p dir="auto">I've been using a kit that I purchased from <a href="http://Amazon.com" target="_blank" rel="noopener noreferrer nofollow ugc">Amazon.com</a>. I've been programming with Arduino, but would like to use UI Flow. All of the tutorials show that UI Flow should show on booting up- but I haven't seen this. There are videos on how to get to "wifi" or "settings" on your device, but mine doesn't do this. I've tried using the Desktop app of UI Flow and tried to use the firmware burner tool, but whenever I try to click the download button, nothing happens, maybe my device is not connected.</p>
<p dir="auto">I can't find any tutorials on how to get UI flow working on the device without it coming with it already have the software.. any suggestions?</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/1975/how-to-get-ui-flow-on-to-device</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 10:37:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1975.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 21 May 2020 19:29:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to get UI Flow on to device? on Fri, 22 May 2020 18:23:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3649">@kgobes</a> Yes Visuino is block coding, I thought that what you were after wanting to use UiFlow. Of course the latter can display the dose as well. Cheers !</p>
]]></description><link>https://community.m5stack.com/post/8792</link><guid isPermaLink="true">https://community.m5stack.com/post/8792</guid><dc:creator><![CDATA[Pumpui]]></dc:creator><pubDate>Fri, 22 May 2020 18:23:15 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Fri, 22 May 2020 16:55:39 GMT]]></title><description><![CDATA[<p dir="auto">Ah, got it to work! thanks <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> I didn't know there was a separate M5 burner tool. For anyone seeing this post in the future with same confusion, here is the doc to follow for downloading m5 burner and flashing your device, these two steps got my device to pull up an API key once it was done, so now I am able to use UI flow- <a href="https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/quick_start/m5stickc/m5stickc_quick_start_with_uiflow</a></p>
]]></description><link>https://community.m5stack.com/post/8789</link><guid isPermaLink="true">https://community.m5stack.com/post/8789</guid><dc:creator><![CDATA[kgobes]]></dc:creator><pubDate>Fri, 22 May 2020 16:55:39 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Fri, 22 May 2020 15:46:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> I will try to find documentation on this and try it out... UI Flow though was not ever on my M5StickC- I also bought multiple kits and none had it on startup- they go right to the factory mode rotating through accelerometer/speaker, etc.  Maybe I have a different version of the stick?</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3625">@Pumpui</a> Thanks! This is a good suggestion for an alternative; I think Visuino is block coding. However, I'm really interested just in using Micropython on the device in the easiest way possible, but that doesn't seem to really exist. That's why I wanted to see if UI flow could do micropython. (have tried Thonny which crashes my computer and others that I couldn't find clear documentation on connecting to serial port)</p>
]]></description><link>https://community.m5stack.com/post/8788</link><guid isPermaLink="true">https://community.m5stack.com/post/8788</guid><dc:creator><![CDATA[kgobes]]></dc:creator><pubDate>Fri, 22 May 2020 15:46:23 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Fri, 22 May 2020 09:00:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3649">@kgobes</a>  I suggest that you take a look at the Visuino IDE (<a href="http://visuino.com" target="_blank" rel="noopener noreferrer nofollow ugc">http://visuino.com</a>. )The basic version is very reasonably priced(free trial period too) and there is a " PRO" version. The fact that is it not free provides support, you get an interlocutor , you are not given the run around and don't have to rely on forums so much. That's precious and saves a lot of frustration. Also this means that the software is continuously under development and they are prompt to react to issues. The developer makes money on the software, not the hardware modules. That makes a world of difference. Only my opinion anyway. Michael</p>
]]></description><link>https://community.m5stack.com/post/8782</link><guid isPermaLink="true">https://community.m5stack.com/post/8782</guid><dc:creator><![CDATA[Pumpui]]></dc:creator><pubDate>Fri, 22 May 2020 09:00:26 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Fri, 22 May 2020 04:51:12 GMT]]></title><description><![CDATA[<p dir="auto">If you have been using arduino then UIFLow will have been deleted from the M5Stack or stick.<br />
M5 Burner must be placed in a folder called M5Burner to work (folder has to be created manually) one this is done then the download will start working.</p>
]]></description><link>https://community.m5stack.com/post/8779</link><guid isPermaLink="true">https://community.m5stack.com/post/8779</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 22 May 2020 04:51:12 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Fri, 22 May 2020 03:04:43 GMT]]></title><description><![CDATA[<p dir="auto">I have the Silicon Labs driver downloaded. I should also add I'm using the M5StickC- I see some posts that maybe it isn't compatible with the Desktop unless it's in USB mode, but my device doesn't go into USB mode because it doesn't have UI flow on it to begin with...</p>
]]></description><link>https://community.m5stack.com/post/8776</link><guid isPermaLink="true">https://community.m5stack.com/post/8776</guid><dc:creator><![CDATA[kgobes]]></dc:creator><pubDate>Fri, 22 May 2020 03:04:43 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Fri, 22 May 2020 00:21:28 GMT]]></title><description><![CDATA[<p dir="auto">The green bar is just for downloading the firmware to your PC, the burn step is for getting the firmware from your PC to your device. Did you install that usb driver? I did read somewhere people were having difficulties with that part.</p>
]]></description><link>https://community.m5stack.com/post/8773</link><guid isPermaLink="true">https://community.m5stack.com/post/8773</guid><dc:creator><![CDATA[sjako]]></dc:creator><pubDate>Fri, 22 May 2020 00:21:28 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Thu, 21 May 2020 23:16:21 GMT]]></title><description><![CDATA[<p dir="auto">Ok, thanks. So mine doesn't show up with the green bar. It also shows my device is "disconnected" even right after I try to connect, so maybe that is why it is unable to download.. but I don't know why it doesn't stay connected.. I know it is the right port, as it is the same one I used on Arduino</p>
]]></description><link>https://community.m5stack.com/post/8772</link><guid isPermaLink="true">https://community.m5stack.com/post/8772</guid><dc:creator><![CDATA[kgobes]]></dc:creator><pubDate>Thu, 21 May 2020 23:16:21 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Thu, 21 May 2020 23:06:15 GMT]]></title><description><![CDATA[<p dir="auto">A green bar was displayed while it downloaded:</p>
<p dir="auto"><img src="/assets/uploads/files/1590102217639-f7722e1e-9b77-402c-8aeb-0ca84aa12af7-image.png" alt="0_1590102215956_f7722e1e-9b77-402c-8aeb-0ca84aa12af7-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Next step was indeed pressing the burn button on the right side of m5burner. A log was shown with lines counting to 100% for two times. (I might have pressed that erase button first). After that it worked properly</p>
]]></description><link>https://community.m5stack.com/post/8771</link><guid isPermaLink="true">https://community.m5stack.com/post/8771</guid><dc:creator><![CDATA[sjako]]></dc:creator><pubDate>Thu, 21 May 2020 23:06:15 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Thu, 21 May 2020 23:00:49 GMT]]></title><description><![CDATA[<p dir="auto">Thanks- this screenshot shows what I've been trying to do- when I click that download icon, nothing seems to happen- what happens for you? And then when I try to "Burn" it says you must download firmware before burning it.</p>
]]></description><link>https://community.m5stack.com/post/8770</link><guid isPermaLink="true">https://community.m5stack.com/post/8770</guid><dc:creator><![CDATA[kgobes]]></dc:creator><pubDate>Thu, 21 May 2020 23:00:49 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Thu, 21 May 2020 22:22:36 GMT]]></title><description><![CDATA[<p dir="auto">I don't know if this helps you, but I think there was an update to the M5Flow to include the firmware browser (previously called M5Burner). I update my firmware using these options/buttons (see screenshot, the arrow next to the firmware was moved from the top bar to be next to the firmware texts). I picked 1.4.5.1 because that would be most stable.</p>
<p dir="auto"><img src="/assets/uploads/files/1590099476189-49a23ba3-4d67-4ee8-b164-f803fcdd10d5-image.png" alt="0_1590099474767_49a23ba3-4d67-4ee8-b164-f803fcdd10d5-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">PS I used a downloaded IDE, not the online version</p>
]]></description><link>https://community.m5stack.com/post/8769</link><guid isPermaLink="true">https://community.m5stack.com/post/8769</guid><dc:creator><![CDATA[sjako]]></dc:creator><pubDate>Thu, 21 May 2020 22:22:36 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Thu, 21 May 2020 22:03:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3631">@sjako</a> Thanks for the reply! I don't get the UI Flow splash screen on start up.</p>
]]></description><link>https://community.m5stack.com/post/8768</link><guid isPermaLink="true">https://community.m5stack.com/post/8768</guid><dc:creator><![CDATA[kgobes]]></dc:creator><pubDate>Thu, 21 May 2020 22:03:42 GMT</pubDate></item><item><title><![CDATA[Reply to How to get UI Flow on to device? on Thu, 21 May 2020 21:59:08 GMT]]></title><description><![CDATA[<p dir="auto">When I boot up my m5stack (just got mine a few days ago), it really briefly shows a startup splash. In the splash screen an UIFlow icon and an option per button is shown. In this brief moment I have to press the third button quite fast and select usb connection (my WIFI connection does not yet work).</p>
]]></description><link>https://community.m5stack.com/post/8767</link><guid isPermaLink="true">https://community.m5stack.com/post/8767</guid><dc:creator><![CDATA[sjako]]></dc:creator><pubDate>Thu, 21 May 2020 21:59:08 GMT</pubDate></item></channel></rss>
