<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack FIre Wifi can not connect]]></title><description><![CDATA[<p dir="auto">Good evening.</p>
<p dir="auto">Today I got my M5Stack Fire, and I was trying to connect with my Wifi. Sadly this does not work yet. It's screens shows: "Problem. Not Connected to: SSIDName" after trying to connect.</p>
<li>I have tried baking in the SSID / Password when I update the firmware (1.4.5.1) and have also tried the method with using the M5Stack as a wifi accespoint + updating the credentials with my phone, but both methods fail.</li>
<li>I don't think I made a typo with the password, because I copy pasted that.</li>
<li>I do use the "_" symbol in my SSID name, could that be an issue?</li>
<p dir="auto">Is there some method to see why it's failing?</p>
<p dir="auto">For the time being I only used M5Flow to program with by the way.  Luckily connecting with USB works properly.</p>
]]></description><link>https://community.m5stack.com/topic/1967/m5stack-fire-wifi-can-not-connect</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 10:03:59 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1967.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 May 2020 21:39:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack FIre Wifi can not connect on Tue, 21 Jul 2020 16:01:49 GMT]]></title><description><![CDATA[<p dir="auto">I did a test with a Pycom WiPy 3.0 - it will also not connecting on the Vodafone Station :(</p>
<p dir="auto">It seems that some routers have issues, when connecting an ESP32.</p>
<p dir="auto">In the next days I am testing an Arduino sketch, instead of MicroPython.</p>
]]></description><link>https://community.m5stack.com/post/9391</link><guid isPermaLink="true">https://community.m5stack.com/post/9391</guid><dc:creator><![CDATA[stefanj9]]></dc:creator><pubDate>Tue, 21 Jul 2020 16:01:49 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack FIre Wifi can not connect on Sat, 18 Jul 2020 16:13:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3050">@plusulli</a> : This is good to know, but this is not the solution for this problem :)</p>
<p dir="auto">Anyway, I bought now a repeater "tp-link TL-WA854RE" from Aldi Süd. The repeater connects without problems on the Vodafone Station and the M5 devices works with firmware 1.6.0 on this repeater. So I have an workaround for now, but I hope for a real solution ...</p>
]]></description><link>https://community.m5stack.com/post/9375</link><guid isPermaLink="true">https://community.m5stack.com/post/9375</guid><dc:creator><![CDATA[stefanj9]]></dc:creator><pubDate>Sat, 18 Jul 2020 16:13:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack FIre Wifi can not connect on Fri, 17 Jul 2020 14:39:26 GMT]]></title><description><![CDATA[<p dir="auto">the problem with the Vodafone Station I also noticed the Vodafone Station is very bad also for smart home devices like Amazon Alexa, so I bought a Fritzbox 6591 and all problems are gone</p>
]]></description><link>https://community.m5stack.com/post/9362</link><guid isPermaLink="true">https://community.m5stack.com/post/9362</guid><dc:creator><![CDATA[plusulli]]></dc:creator><pubDate>Fri, 17 Jul 2020 14:39:26 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack FIre Wifi can not connect on Fri, 17 Jul 2020 13:43:52 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">this is a problem on all M5 Devices with firmware &gt;1.4.5.1! I have test it with M5Stack Gray and M5StickC.</p>
<p dir="auto">My tests:</p>
<li>firmware 1.6.0 on router Connect Box (Unitymedia / old router) - it works</li>
<li>firmware 1.4.5.1 on router Vodafone Station (new router) - it works</li>
<li>firmware 1.6.0 on router Vodafone Station (new router) - no connection</li>
<li>firmware 1.6.0 on iPhone (with "_" in SSID) - it works</li>
<p dir="auto">I get following message on the COM monitor on router Vodafone Station:<br />
[534537] MQTTException -&gt; [Errno 113] EHOSTUNREACH<br />
reconnect start ...</p>
]]></description><link>https://community.m5stack.com/post/9360</link><guid isPermaLink="true">https://community.m5stack.com/post/9360</guid><dc:creator><![CDATA[stefanj9]]></dc:creator><pubDate>Fri, 17 Jul 2020 13:43:52 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack FIre Wifi can not connect on Wed, 15 Jul 2020 06:02:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3631">@sjako</a> check out the last comment in this thread <a href="https://forum.m5stack.com/topic/1252/my-m5stack-can-t-connect-to-wifi-solved" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.m5stack.com/topic/1252/my-m5stack-can-t-connect-to-wifi-solved</a> you may be able to get around this issue by replacing the "_" in your url with "%5F"</p>
]]></description><link>https://community.m5stack.com/post/9340</link><guid isPermaLink="true">https://community.m5stack.com/post/9340</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 15 Jul 2020 06:02:40 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack FIre Wifi can not connect on Wed, 15 Jul 2020 01:13:41 GMT]]></title><description><![CDATA[<p dir="auto">SSID can use underscores.    but esp32 wifi only support 2.4G freq.  so maybe you could check the wifi freq.</p>
]]></description><link>https://community.m5stack.com/post/9337</link><guid isPermaLink="true">https://community.m5stack.com/post/9337</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 15 Jul 2020 01:13:41 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack FIre Wifi can not connect on Tue, 14 Jul 2020 21:19:25 GMT]]></title><description><![CDATA[<p dir="auto">I think the underscores are indeed the issue. I just did a test in which I used my pc as a WIFI hotspot, and the M5Stack connects properly now. It's a weird thing underscores can't be used in the SSID...</p>
<p dir="auto"><img src="/assets/uploads/files/1594761546711-86667f6b-46a7-4a8a-b83b-7735b2bc6a32-image.png" alt="0_1594761550447_86667f6b-46a7-4a8a-b83b-7735b2bc6a32-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/9335</link><guid isPermaLink="true">https://community.m5stack.com/post/9335</guid><dc:creator><![CDATA[sjako]]></dc:creator><pubDate>Tue, 14 Jul 2020 21:19:25 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack FIre Wifi can not connect on Tue, 30 Jun 2020 20:37:51 GMT]]></title><description><![CDATA[<p dir="auto">My WIFI has some underscores ("_") symbols, because I have opted out from google using my wifi signal using “_nomap”. These is the only special character symbol I'm using. Next to that it's a bit difficult to change the SSID, because we have like 20 different devices using it.</p>
<p dir="auto">Is there some way to see if the name of my WIFI SIDD is the actual problem?</p>
<p dir="auto">Thanks for the quick reply by the way!</p>
]]></description><link>https://community.m5stack.com/post/8764</link><guid isPermaLink="true">https://community.m5stack.com/post/8764</guid><dc:creator><![CDATA[sjako]]></dc:creator><pubDate>Tue, 30 Jun 2020 20:37:51 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack FIre Wifi can not connect on Wed, 20 May 2020 01:51:47 GMT]]></title><description><![CDATA[<ol>
<li>make sure your WiFi SSID not include "space" or other special symbol</li>
<li>remove the battery bottom then try again.</li>
]]></description><link>https://community.m5stack.com/post/8740</link><guid isPermaLink="true">https://community.m5stack.com/post/8740</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 20 May 2020 01:51:47 GMT</pubDate></item></channel></rss>
