<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Uploading to M5 Atom in Arduino?]]></title><description><![CDATA[<p dir="auto">In Arduino, is there an add-on (via the Board Manager) to upload to the M5 Atom?</p>
]]></description><link>https://community.m5stack.com/topic/1961/uploading-to-m5-atom-in-arduino</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 05:22:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1961.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 May 2020 03:59:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Uploading to M5 Atom in Arduino? on Mon, 18 May 2020 03:24:40 GMT]]></title><description><![CDATA[<p dir="auto">Select esp 32 pico kit from the board list (both M5stickC and atom use this chip) and select 115200 as the baud rate. if your device doesn't show up in the listed ports you may need to install the cp210x serial com port driver</p>
]]></description><link>https://community.m5stack.com/post/8714</link><guid isPermaLink="true">https://community.m5stack.com/post/8714</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Mon, 18 May 2020 03:24:40 GMT</pubDate></item><item><title><![CDATA[Reply to Uploading to M5 Atom in Arduino? on Sat, 16 May 2020 13:48:18 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the feedback.  The M5-Atom utube tutorial breezes through the Arduino Tool tab Board Manager portion by setting it up for M5Stick-C, as there is no M5-Atom selection, but when I compile, I get “Error compiling for board M5Stick-C.”  I’m using an M5-ATOM “Button” example, and my Atom is plugged into my Windows PC USB Port.  Of course, I’ve added the M5-Atom library.  In Arduino under File tab Preferences I’ve included Board Manager <a href="https://dl.espressif.com/dl/package_esp32_index.json" target="_blank" rel="noopener noreferrer nofollow ugc">https://dl.espressif.com/dl/package_esp32_index.json</a>.  Not sure where to go from here…</p>
]]></description><link>https://community.m5stack.com/post/8710</link><guid isPermaLink="true">https://community.m5stack.com/post/8710</guid><dc:creator><![CDATA[MikeH]]></dc:creator><pubDate>Sat, 16 May 2020 13:48:18 GMT</pubDate></item><item><title><![CDATA[Reply to Uploading to M5 Atom in Arduino? on Sat, 16 May 2020 10:40:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3612">@mikeh</a> Yes you can. Please follow this tutorial by <a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/700">@lukasmaximus</a><br />
<a href="https://www.youtube.com/watch?v=2f4biAfvC_M" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=2f4biAfvC_M</a></p>
]]></description><link>https://community.m5stack.com/post/8709</link><guid isPermaLink="true">https://community.m5stack.com/post/8709</guid><dc:creator><![CDATA[liemph]]></dc:creator><pubDate>Sat, 16 May 2020 10:40:13 GMT</pubDate></item></channel></rss>
