<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow 1.5.1]]></title><description><![CDATA[<p dir="auto">Ver 1.5.1. time : 2020.04.23<br />
UpdateLog：</p>
<li>1: Fixed: SD card error.</li>
<li>2: Fixed: Remote Error.</li>
<li>3: Update: Mqtt can run in exec mode.</li>
<li>4: Add: Mqtt add last will support (must be ahead in mqtt start).</li>
<li>5: Add: ENV-II unit support.</li>
<li>6: Add: I2C add data different format.</li>
<li>7: Support Remote.</li>
]]></description><link>https://community.m5stack.com/topic/1904/uiflow-1-5-1</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 12:44:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1904.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Apr 2020 10:21:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow 1.5.1 on Mon, 25 May 2020 02:09:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guors" aria-label="Profile: guors">@<bdi>guors</bdi></a> thank you feedback. we will fix this bug as soon as possible</p>
]]></description><link>https://community.m5stack.com/post/8819</link><guid isPermaLink="true">https://community.m5stack.com/post/8819</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Mon, 25 May 2020 02:09:51 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Sat, 23 May 2020 17:08:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> FYI! I receive the error "DAC object has no attribute 'waveform' " in UIFlow when using the "dac0 waveform with..." block. Is this due to the last firmware? Thanks!</p>
]]></description><link>https://community.m5stack.com/post/8807</link><guid isPermaLink="true">https://community.m5stack.com/post/8807</guid><dc:creator><![CDATA[Guors]]></dc:creator><pubDate>Sat, 23 May 2020 17:08:35 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Fri, 08 May 2020 19:19:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> DCMotor and fan can not be controlled using PWM.</p>
]]></description><link>https://community.m5stack.com/post/8579</link><guid isPermaLink="true">https://community.m5stack.com/post/8579</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 08 May 2020 19:19:18 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Fri, 08 May 2020 10:22:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> ok......we will tracking this issues</p>
]]></description><link>https://community.m5stack.com/post/8572</link><guid isPermaLink="true">https://community.m5stack.com/post/8572</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 08 May 2020 10:22:43 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Fri, 08 May 2020 08:19:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> Sorry should have said.<br />
Trying to use the NCIR unit on port A</p>
]]></description><link>https://community.m5stack.com/post/8567</link><guid isPermaLink="true">https://community.m5stack.com/post/8567</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 08 May 2020 08:19:56 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Fri, 08 May 2020 02:37:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> after what operation it return this error?</p>
]]></description><link>https://community.m5stack.com/post/8563</link><guid isPermaLink="true">https://community.m5stack.com/post/8563</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 08 May 2020 02:37:20 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Thu, 07 May 2020 17:28:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> AttributeError 'i2c' object has no attribute 'begin'</p>
]]></description><link>https://community.m5stack.com/post/8557</link><guid isPermaLink="true">https://community.m5stack.com/post/8557</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 07 May 2020 17:28:02 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Thu, 07 May 2020 10:34:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plusulli" aria-label="Profile: plusulli">@<bdi>plusulli</bdi></a> for the time being, M5StickC don't have 1.5.1 FW.  pls patient wait.</p>
]]></description><link>https://community.m5stack.com/post/8543</link><guid isPermaLink="true">https://community.m5stack.com/post/8543</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 07 May 2020 10:34:45 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Thu, 07 May 2020 10:25:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> OK, Thank you feedback. we will fix this bug as soon as possible</p>
]]></description><link>https://community.m5stack.com/post/8541</link><guid isPermaLink="true">https://community.m5stack.com/post/8541</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Thu, 07 May 2020 10:25:36 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Wed, 06 May 2020 18:21:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> FW1.5.1 and UIFLow web 1.5.1</p>
<p dir="auto">When trying to use the earth sensor (2 prong moisture sensor) firmware respond with Unit ADC and no function getRawValue.</p>
]]></description><link>https://community.m5stack.com/post/8533</link><guid isPermaLink="true">https://community.m5stack.com/post/8533</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 06 May 2020 18:21:18 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Tue, 05 May 2020 17:51:41 GMT]]></title><description><![CDATA[<p dir="auto">I'm getting issues with using the earth unit on fw 1.5.1<br />
uiflow is calling adc instead of earth</p>
]]></description><link>https://community.m5stack.com/post/8519</link><guid isPermaLink="true">https://community.m5stack.com/post/8519</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 05 May 2020 17:51:41 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Sat, 02 May 2020 01:21:26 GMT]]></title><description><![CDATA[<p dir="auto">Where is the Demo for M5stickC ?</p>
]]></description><link>https://community.m5stack.com/post/8477</link><guid isPermaLink="true">https://community.m5stack.com/post/8477</guid><dc:creator><![CDATA[plusulli]]></dc:creator><pubDate>Sat, 02 May 2020 01:21:26 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.5.1 on Fri, 01 May 2020 14:45:56 GMT]]></title><description><![CDATA[<p dir="auto">Sorry since Update 1.5.x it is not possible, that I connect my devices via Usb.<br />
Upload fails.<br />
I use Desktop M5Flow 1.0.9</p>
<p dir="auto">I got this UIFlow-Error:</p>
<pre><code>[Window Title]
Error
[Main Instruction]
A JavaScript error occurred in the main process
[Content]
Uncaught Exception:
Error: Port is not open
    at SerialPort.close (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\node_modules\@serialport\stream\stream.js:425:29)
    at SerialPort.&lt;anonymous&gt; (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\src\libs\serialport.js:217:34)
    at SerialPort._error (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\node_modules\@serialport\stream\stream.js:197:14)
    at binding.open.then.err (C:\Development\M5Stack\IDE\UIFlow-Desktop-IDE\bin\resources\app.asar\node_modules\@serialport\stream\stream.js:241:12)
[OK]
<p dir="auto">I can Reset the device and then reconnect it.<br />
Then I see a green "connected" in left bottom corner.<br />
After I try to upload some code, I get ever and ever again an error and device is disconnected.</p>
<p dir="auto">Sometimes I can "run" my code.<br />
But if I upoload the code to the device I get an Error:</p>
<pre><code>File "&lt;string&gt;", line 1
SyntaxError: invalid syntax
<p dir="auto">First line in code is:</p>
<p dir="auto">It is really unusable since some few weeks.</p>
<p dir="auto">Before it was working well (but not perfect)</p>
]]></description><link>https://community.m5stack.com/post/8463</link><guid isPermaLink="true">https://community.m5stack.com/post/8463</guid><dc:creator><![CDATA[M5StickFreakler]]></dc:creator><pubDate>Fri, 01 May 2020 14:45:56 GMT</pubDate></item></channel></rss>
