<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How does one use Block Maker?]]></title><description><![CDATA[<p dir="auto">So I went to <a href="http://block-maker.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">http://block-maker.m5stack.com/</a>, put in my code. Now what? There's no save/download/whatever, and cutting and pasting into a .m5b file doesn't work.</p>
<p dir="auto">If I use the Beta create m5b file in the tool, when I hit download, I get an empty file:</p>
<p dir="auto">{"category":"RGB2","color":"#8000ff","blocks":["__RGB2_setScreenColorRGB"],"jscode":""}</p>
<p dir="auto">So, what's the secret? I've tried to copy the butterfly.m5b file in terms of escaping quotes and such, but when I try to load it, the UI just ignores it. No message, no error, it just leaves up the "open *.m5b" menu.</p>
<p dir="auto">It's not like I'm doing anything complicated: I just want to be able to set the background to an arbitrary RGB value, rather than a pre-defined color.</p>
]]></description><link>https://community.m5stack.com/topic/1859/how-does-one-use-block-maker</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 13:56:58 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1859.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Apr 2020 20:17:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How does one use Block Maker? on Sat, 18 Apr 2020 00:18:30 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! Yeah, one can't scroll down to it: You have to have a display that is big enough (or a resolution high enough) to see it.</p>
]]></description><link>https://community.m5stack.com/post/8202</link><guid isPermaLink="true">https://community.m5stack.com/post/8202</guid><dc:creator><![CDATA[dclaar]]></dc:creator><pubDate>Sat, 18 Apr 2020 00:18:30 GMT</pubDate></item><item><title><![CDATA[Reply to How does one use Block Maker? on Sat, 18 Apr 2020 00:02:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dclaar" aria-label="Profile: dclaar">@<bdi>dclaar</bdi></a></p>
<p dir="auto">There is a Download button. You might need to adjust your browser resolution or if on mobile device turn it landscape.</p>
<p dir="auto"><img src="/assets/uploads/files/1587168155261-3347be67-65a0-44cc-b94e-98efcc1c001e-resized.jpeg" alt="0_1587168153064_3347BE67-65A0-44CC-B94E-98EFCC1C001E.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Save the file and open it in uiFlow.</p>
]]></description><link>https://community.m5stack.com/post/8201</link><guid isPermaLink="true">https://community.m5stack.com/post/8201</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sat, 18 Apr 2020 00:02:42 GMT</pubDate></item></channel></rss>
