<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[stepper motor]]></title><description><![CDATA[<p dir="auto">Hi all<br />
I am new to m5stack<br />
I am working on a project where I need to use 12 stepper motor, so what I need to know is, can I add four step motor modules(Stepmotor Module with MEGA328P (DRV8825)) to the m5stack core and control each motor individually</p>
]]></description><link>https://community.m5stack.com/topic/1756/stepper-motor</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 08:43:40 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1756.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Mar 2020 14:03:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to stepper motor on Wed, 01 Apr 2020 20:23:05 GMT]]></title><description><![CDATA[<p dir="auto">That did the trick. Thank you</p>
]]></description><link>https://community.m5stack.com/post/7981</link><guid isPermaLink="true">https://community.m5stack.com/post/7981</guid><dc:creator><![CDATA[Sledge]]></dc:creator><pubDate>Wed, 01 Apr 2020 20:23:05 GMT</pubDate></item><item><title><![CDATA[Reply to stepper motor on Wed, 01 Apr 2020 14:39:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3142">@Sledge</a>    <a href="https://www.youtube.com/watch?v=4ei1vsmkOK4" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=4ei1vsmkOK4</a></p>
]]></description><link>https://community.m5stack.com/post/7979</link><guid isPermaLink="true">https://community.m5stack.com/post/7979</guid><dc:creator><![CDATA[crami25]]></dc:creator><pubDate>Wed, 01 Apr 2020 14:39:56 GMT</pubDate></item><item><title><![CDATA[Reply to stepper motor on Wed, 01 Apr 2020 10:52:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">is any manual available how to flash those hex files to the stepmotor module? Can´t the Firmware be flashed over serial?</p>
]]></description><link>https://community.m5stack.com/post/7976</link><guid isPermaLink="true">https://community.m5stack.com/post/7976</guid><dc:creator><![CDATA[Sledge]]></dc:creator><pubDate>Wed, 01 Apr 2020 10:52:22 GMT</pubDate></item><item><title><![CDATA[Reply to stepper motor on Wed, 18 Mar 2020 04:50:29 GMT]]></title><description><![CDATA[<p dir="auto">You need to change the i2c address in this file and then flash this firmware to the stepper module using an avr-isp programmer or arduino. If you do that then technically you could program multiple stepper modules in UiFlow as it allows you to set the i2c address in the blocks. I cannot say for sure though as I don't have any stepper modules on me to test with</p>
<p dir="auto"><a href="https://github.com/m5stack/stepmotor_module/blob/master/Firmware%20for%20stepmotor%20module/GRBL-Arduino-Library/grblmain.cpp" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/stepmotor_module/blob/master/Firmware for stepmotor module/GRBL-Arduino-Library/grblmain.cpp</a></p>
]]></description><link>https://community.m5stack.com/post/7800</link><guid isPermaLink="true">https://community.m5stack.com/post/7800</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 18 Mar 2020 04:50:29 GMT</pubDate></item><item><title><![CDATA[Reply to stepper motor on Tue, 17 Mar 2020 00:17:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> can you please explain what should I do?.</p>
<p dir="auto">And after reprogram them in Arduino ide can I then use UIFlow to program the robot</p>
]]></description><link>https://community.m5stack.com/post/7777</link><guid isPermaLink="true">https://community.m5stack.com/post/7777</guid><dc:creator><![CDATA[zoabihamada]]></dc:creator><pubDate>Tue, 17 Mar 2020 00:17:16 GMT</pubDate></item><item><title><![CDATA[Reply to stepper motor on Sat, 14 Mar 2020 08:09:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3139">@zoabihamada</a> no, you need to use the arduino ide to reprogram them</p>
]]></description><link>https://community.m5stack.com/post/7737</link><guid isPermaLink="true">https://community.m5stack.com/post/7737</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 14 Mar 2020 08:09:39 GMT</pubDate></item><item><title><![CDATA[Reply to stepper motor on Fri, 13 Mar 2020 23:22:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/443">@ajb2k3</a> can i reprogram them using UIFlow?</p>
]]></description><link>https://community.m5stack.com/post/7736</link><guid isPermaLink="true">https://community.m5stack.com/post/7736</guid><dc:creator><![CDATA[zoabihamada]]></dc:creator><pubDate>Fri, 13 Mar 2020 23:22:26 GMT</pubDate></item><item><title><![CDATA[Reply to stepper motor on Fri, 13 Mar 2020 20:35:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3139">@zoabihamada</a> you can but you need to reprogram them to change the i2c address.</p>
]]></description><link>https://community.m5stack.com/post/7732</link><guid isPermaLink="true">https://community.m5stack.com/post/7732</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 13 Mar 2020 20:35:21 GMT</pubDate></item></channel></rss>
