<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Gray &amp; Batteries...]]></title><description><![CDATA[<p dir="auto">Bought M5Stack Gray.   Works fine.<br />
Wanted more battery so bought Battery 700ma module. Works fine.</p>
<p dir="auto">Wanted Grove B &amp; C ports so bought Base26. Kind of big...<br />
Ordered Module Plus which has  Grove B &amp; C and a 500ma battery.</p>
<p dir="auto">Do I need to remove Module Battery 700ma to use the Module Plus?<br />
Should I remove the 500ma battery and use both Module Battery 700ma + Module Plus (with 500ma removed)?</p>
<p dir="auto">Cheers,<br />
Ric</p>
]]></description><link>https://community.m5stack.com/topic/1752/m5stack-gray-batteries</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 23:39:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1752.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Mar 2020 04:11:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Gray &amp; Batteries... on Wed, 05 Aug 2020 10:19:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4076">@ardo</a>  Yes, you could connect they together.</p>
]]></description><link>https://community.m5stack.com/post/9594</link><guid isPermaLink="true">https://community.m5stack.com/post/9594</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 05 Aug 2020 10:19:54 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray &amp; Batteries... on Wed, 05 Aug 2020 08:54:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a></p>
<p dir="auto">I have a similar question,</p>
<p dir="auto">Is it ok (safe) to put a plus module between a grey and a faces(I) bottom ?</p>
]]></description><link>https://community.m5stack.com/post/9592</link><guid isPermaLink="true">https://community.m5stack.com/post/9592</guid><dc:creator><![CDATA[ardo]]></dc:creator><pubDate>Wed, 05 Aug 2020 08:54:05 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray &amp; Batteries... on Sun, 15 Mar 2020 02:42:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a></p>
<p dir="auto">Thank you. I will try it when it arrives.</p>
]]></description><link>https://community.m5stack.com/post/7753</link><guid isPermaLink="true">https://community.m5stack.com/post/7753</guid><dc:creator><![CDATA[Kyklist]]></dc:creator><pubDate>Sun, 15 Mar 2020 02:42:19 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Gray &amp; Batteries... on Fri, 13 Mar 2020 02:27:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/3108">@kyklist</a> You can actually stack them together. However, due to different battery capacity combinations, there will be a certain loss of total capacity due to mutual charging.</p>
]]></description><link>https://community.m5stack.com/post/7727</link><guid isPermaLink="true">https://community.m5stack.com/post/7727</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 13 Mar 2020 02:27:30 GMT</pubDate></item></channel></rss>
