<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow 1.4.5]]></title><description><![CDATA[<p dir="auto">Ver 1.4.5. time : 2020.02.26<br />
UpdateLog：</p>
<p dir="auto">firmware:</p>
<li>1.Add: Burner wifi set.</li>
<li>2.Add: ATOM support.</li>
<p dir="auto">web:</p>
<li>1.Add Atom-Lite, Atom-Matrix support.</li>
<li>2: Fixed some bugs.</li>
<p dir="auto">ps: The Windows 10 version is currently available. MacOS and Linux versions will be released later.</p>
<p dir="auto"><img src="https://m5stack.oss-cn-shenzhen.aliyuncs.com/image/Updates_log/UIFlow1.4.5_02.jpg" alt="1" class=" img-fluid img-markdown" /></p>
<p dir="auto">M5Burner, please click the settings button in the upper left, and then click the version update，then download UIFlow 1.4.5 .</p>
<p dir="auto">UIFlow 1.4.5 supports firmware configuration WIFI information.</p>
<p dir="auto"><img src="https://m5stack.oss-cn-shenzhen.aliyuncs.com/image/Updates_log/UIFlow1.4.5_01.jpg" alt="1" class=" img-fluid img-markdown" /></p>
<p dir="auto">ATOM API key can be seen through web configuration page or serial port tool</p>
<p dir="auto">ATOM UIFlow Tutorial:<a href="https://docs.m5stack.com/#/en/quick_start/atom/atom_quick_start" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/quick_start/atom/atom_quick_start</a></p>
<p dir="auto"><img src="https://docs.m5stack.com/assets/img/product_pics/core/minicore/atom/apikey.png" alt="替代文字" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://docs.m5stack.com/assets/img/product_pics/core/minicore/atom/serialtool.png" alt="替代文字" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/topic/1725/uiflow-1-4-5</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 11:37:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1725.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Feb 2020 11:45:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow 1.4.5 on Wed, 14 Oct 2020 02:19:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dpharris" aria-label="Profile: dpharris">@<bdi>dpharris</bdi></a></p>
<p dir="auto">in the FS root path has already had <code>main.py</code> file you could modify it. when you select the app mode(purple)  <code>main.py</code> will be exec.</p>
<p dir="auto">if you are use UIFlow, you need to download the program, not just exec it. then it will auto setting this program for auto-start running.</p>
<p dir="auto">if still not work,  pls check the serial log</p>
]]></description><link>https://community.m5stack.com/post/10271</link><guid isPermaLink="true">https://community.m5stack.com/post/10271</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 14 Oct 2020 02:19:01 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Tue, 13 Oct 2020 07:17:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robalstona" aria-label="Profile: robalstona">@<bdi>robalstona</bdi></a>    I cannot get a program to autostart in an Atom Matrix.  I tried naming it "main", and also "<a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a>", but after I switch modes with button/reset and release at purple, the screen turns black and stays black through reset and power on.</p>
<p dir="auto">What am I doing wrong?</p>
David</p>
]]></description><link>https://community.m5stack.com/post/10261</link><guid isPermaLink="true">https://community.m5stack.com/post/10261</guid><dc:creator><![CDATA[dpharris]]></dc:creator><pubDate>Tue, 13 Oct 2020 07:17:30 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Wed, 29 Apr 2020 07:57:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wegunterjr" aria-label="Profile: wegunterjr">@<bdi>wegunterjr</bdi></a> you could select to the beta version (UIFlow 1.5.1) , this bug we will fix it as soon as possible.</p>
]]></description><link>https://community.m5stack.com/post/8426</link><guid isPermaLink="true">https://community.m5stack.com/post/8426</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Wed, 29 Apr 2020 07:57:27 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Tue, 28 Apr 2020 19:59:11 GMT]]></title><description><![CDATA[<p dir="auto">I am not sure what happened, but the offline version 1.4.5 is confusing. At one point I could do PaHub but now with the current 1.4.5/1.0.9 I cannot select PaHub or PbHub.  Am I missing something?</p>
]]></description><link>https://community.m5stack.com/post/8416</link><guid isPermaLink="true">https://community.m5stack.com/post/8416</guid><dc:creator><![CDATA[wegunterjr]]></dc:creator><pubDate>Tue, 28 Apr 2020 19:59:11 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Tue, 31 Mar 2020 10:51:47 GMT]]></title><description><![CDATA[<p dir="auto">Since a few days an entry in a MAP of UIFlow is not entered in the MAP. In the Blockly view the entry is present, in the Python view it is missing. All other entries in this MAP are present.</p>
<p dir="auto">Peter</p>
]]></description><link>https://community.m5stack.com/post/7972</link><guid isPermaLink="true">https://community.m5stack.com/post/7972</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Tue, 31 Mar 2020 10:51:47 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Fri, 27 Mar 2020 16:08:27 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for both suggestions. I've tried uPyCraft on Linux and it works.</p>
<p dir="auto">But then I've remembered <a href="https://thonny.org/" target="_blank" rel="noopener noreferrer nofollow ugc">Thonny</a>. Tried it and it also works on Linux and has many features for MicroPython @ Atom Lite : View-&gt;File, edit file on microcontroller flash memory, etc.</p>
<p dir="auto">I also recommend <a href="https://github.com/wendlers/mpfshell" target="_blank" rel="noopener noreferrer nofollow ugc">mpfshell</a>, it works 100% on Linux to copy files with Atom Lite/Matrix &amp; UIFlow 1.4.5(.1).</p>
]]></description><link>https://community.m5stack.com/post/7927</link><guid isPermaLink="true">https://community.m5stack.com/post/7927</guid><dc:creator><![CDATA[rcolistete]]></dc:creator><pubDate>Fri, 27 Mar 2020 16:08:27 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 26 Mar 2020 23:45:37 GMT]]></title><description><![CDATA[<p dir="auto">upyloader is another good solution for transferring files to the flash. Ampy hasn't worked for me for a long while</p>
]]></description><link>https://community.m5stack.com/post/7919</link><guid isPermaLink="true">https://community.m5stack.com/post/7919</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 26 Mar 2020 23:45:37 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 26 Mar 2020 19:53:52 GMT]]></title><description><![CDATA[<p dir="auto">Could you try uPyCraft. I use them on windows system and i can transfer files to/from Atom Lite/Matrix with burned Uiflow firmware. Under linux where i use Linux Mint 19 uPyCraft i cannot run it (problem with installing proper libraries needed to run)</p>
]]></description><link>https://community.m5stack.com/post/7917</link><guid isPermaLink="true">https://community.m5stack.com/post/7917</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Thu, 26 Mar 2020 19:53:52 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 26 Mar 2020 15:41:17 GMT]]></title><description><![CDATA[<p dir="auto">Some issues about <strong>UIFlow 1.4.5/1.4.5.1 on Atom Lite/Matrix</strong> :</p>
<li>using CLI (Command-Line-Interface) tools (on Linux),  'screen /dev/ttyUSB0 115200' on Linux works, showing 'MicroPython v1.11-301-gd0880874d-dirty on 2020-03-13';</li>
<li>but <strong>'rshell' and 'ampy' don't work at all</strong> (these tools are useful to manage files on MicroPython microcontrollers). Exemple of error message : 'ampy.pyboard.PyboardError: could not enter raw repl';</li>
<li>so <strong>how to copy files to/from the internal flash memory of Atom Lite/Matrix ?</strong> I don't see webrepl, ftp server, etc, in the 1.4.5/1.4.5.1 firmware.</li>
<p dir="auto">While using :</p>
<li>Atom Lite/Matrix with pre-installed firmware (MicroPython v1.12-36-gf68fe753b-dirty on 2020-01-14), 'rshell' and 'ampy' work without problem;</li>
<li>M5StickC with UIFlow 1.4.5/1.4.5.1, 'rshell' and 'ampy' work too.</li>
]]></description><link>https://community.m5stack.com/post/7912</link><guid isPermaLink="true">https://community.m5stack.com/post/7912</guid><dc:creator><![CDATA[rcolistete]]></dc:creator><pubDate>Thu, 26 Mar 2020 15:41:17 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Wed, 04 Mar 2020 13:55:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/illusion" aria-label="Profile: illusion">@<bdi>illusion</bdi></a> said in <a href="/post/7649">UIFlow 1.4.5</a>:</p>
<p dir="auto">and btw what is  "app run mode"?</p>
<p dir="auto">When you start atom in app mode after boot a file <strong><a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a></strong> is running. In this file you can save your program which will be run. You can save your program from UiFlow by "Download" button/icon. Then your program should be saved as <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a> and after restart device should be run it. But i did not tested by this way on atom (on StickC works as i wrote up). I wrote this file by another software.</p>
]]></description><link>https://community.m5stack.com/post/7674</link><guid isPermaLink="true">https://community.m5stack.com/post/7674</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Wed, 04 Mar 2020 13:55:26 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Mon, 02 Mar 2020 22:28:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/illusion" aria-label="Profile: illusion">@<bdi>illusion</bdi></a> were you able to connect to wifi? offline wont work yet as the link for uiflow desktop hasn't been updated to 1.4.5 on the website, You cant upgrade it within the software either</p>
]]></description><link>https://community.m5stack.com/post/7652</link><guid isPermaLink="true">https://community.m5stack.com/post/7652</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Mon, 02 Mar 2020 22:28:56 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Mon, 02 Mar 2020 20:33:06 GMT]]></title><description><![CDATA[<p dir="auto">why would people above say that pink/purple is  the config mode? after flashing 1.4.5 for me the yellow mode is the config mode...</p>
<p dir="auto">after flashing 1.4.5 neither online (breathing green mode) nor offline ide works for me... absolutely not...</p>
<p dir="auto">usb mode (blue light) does nothing for me...</p>
<p dir="auto">i could only flash firmware and that's about it... pretty useless, no? still a facepalm for me at this point...</p>
]]></description><link>https://community.m5stack.com/post/7649</link><guid isPermaLink="true">https://community.m5stack.com/post/7649</guid><dc:creator><![CDATA[illusion]]></dc:creator><pubDate>Mon, 02 Mar 2020 20:33:06 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Sat, 29 Feb 2020 19:00:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a> Can you get the RGB LED blocks removed from the Hardware section of blocks and move the to the Base/Module section please?</p>
]]></description><link>https://community.m5stack.com/post/7626</link><guid isPermaLink="true">https://community.m5stack.com/post/7626</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 29 Feb 2020 19:00:43 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Fri, 28 Feb 2020 19:16:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robalstona" aria-label="Profile: robalstona">@<bdi>robalstona</bdi></a> said in <a href="/post/7591">UIFlow 1.4.5</a>:</p>
<p dir="auto">Connect the atom to the computer and connect to it with the terminal program, system information along with the API key are displayed during startup. The second option is to keep the matrix button pressed while starting until the colors change pulsatingly. And release it when it is pink / purple. then the atom will launch its access point. Connect to his network via 192.168.4.1 address and then in the browser you will see the API key and you will be able to choose the network to which you will connect.</p>
<p dir="auto">Thank you it works :-)</p>
<p dir="auto">Greetings skink</p>
]]></description><link>https://community.m5stack.com/post/7615</link><guid isPermaLink="true">https://community.m5stack.com/post/7615</guid><dc:creator><![CDATA[Skink]]></dc:creator><pubDate>Fri, 28 Feb 2020 19:16:56 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Fri, 28 Feb 2020 01:23:54 GMT]]></title><description><![CDATA[<p dir="auto">@mati thanks your feedback , we will fix it as soon as possible</p>
]]></description><link>https://community.m5stack.com/post/7611</link><guid isPermaLink="true">https://community.m5stack.com/post/7611</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 28 Feb 2020 01:23:54 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Fri, 28 Feb 2020 07:34:52 GMT]]></title><description><![CDATA[<p dir="auto">hmm small bug with Button ? At Atom Matrix<br />
<img src="/assets/uploads/files/1582835242879-4d24a24c-8db6-4d60-9bdd-685859588d26-image.png" alt="0_1582835335261_4d24a24c-8db6-4d60-9bdd-685859588d26-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1582835255691-5ab96e0b-3435-4824-ad59-629dec442d46-image.png" alt="0_1582835349305_5ab96e0b-3435-4824-ad59-629dec442d46-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">There is only one button :D</p>
]]></description><link>https://community.m5stack.com/post/7608</link><guid isPermaLink="true">https://community.m5stack.com/post/7608</guid><dc:creator><![CDATA[OyczE]]></dc:creator><pubDate>Fri, 28 Feb 2020 07:34:52 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 27 Feb 2020 19:47:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> said in <a href="/post/7606">UIFlow 1.4.5</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stickfreakler" aria-label="Profile: m5stickfreakler">@<bdi>m5stickfreakler</bdi></a> You mean offline version?</p>
<p dir="auto">Yes I mean offline version :-)</p>
]]></description><link>https://community.m5stack.com/post/7607</link><guid isPermaLink="true">https://community.m5stack.com/post/7607</guid><dc:creator><![CDATA[M5StickFreakler]]></dc:creator><pubDate>Thu, 27 Feb 2020 19:47:36 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 27 Feb 2020 19:15:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stickfreakler" aria-label="Profile: m5stickfreakler">@<bdi>m5stickfreakler</bdi></a> You mean offline version?</p>
]]></description><link>https://community.m5stack.com/post/7606</link><guid isPermaLink="true">https://community.m5stack.com/post/7606</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 27 Feb 2020 19:15:05 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 27 Feb 2020 17:38:53 GMT]]></title><description><![CDATA[<p dir="auto">Is there also a ne UiFlow Version that support ATOM? My Version is 1.0.7 and does not allow to program ATOM</p>
]]></description><link>https://community.m5stack.com/post/7603</link><guid isPermaLink="true">https://community.m5stack.com/post/7603</guid><dc:creator><![CDATA[M5StickFreakler]]></dc:creator><pubDate>Thu, 27 Feb 2020 17:38:53 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 27 Feb 2020 11:15:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jpilarski" aria-label="Profile: jpilarski">@<bdi>jpilarski</bdi></a> agreed. I asked about something like this for the neoflash and NeoFlashC</p>
]]></description><link>https://community.m5stack.com/post/7602</link><guid isPermaLink="true">https://community.m5stack.com/post/7602</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 27 Feb 2020 11:15:38 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 27 Feb 2020 08:00:11 GMT]]></title><description><![CDATA[<p dir="auto">I love seeing the graphic icons of the two new boards they look really cool in the simulator. I am sure you are already working on this but there needs to be a way, after selecting the leds in the simulator, to save a page of the toggled leds for the atom and then play back or trigger those pages. I picture something like the emoji interface you had in previous releases would be helpful to bring back since it had multipage options for crerating animations. <img src="https://pp.userapi.com/c851320/v851320311/a2388/i-WdriJtbds.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
I imagine much of the code used used on the 5x5 microbit screen would be helpful if ported to UIflow. Things like the various 5x5 fonts they have avaiable as well as the various scrolling routines <a href="https://makecode.microbit.org/#editor" target="_blank" rel="noopener noreferrer nofollow ugc">https://makecode.microbit.org/#editor FONTS</a>. I know this is just the beginning and it already looks great but I thought I would state the obvious benefit of adding in some of this capability in future releases. thanks for the new release it's always fun to see what new tools you've made for us.</p>
]]></description><link>https://community.m5stack.com/post/7600</link><guid isPermaLink="true">https://community.m5stack.com/post/7600</guid><dc:creator><![CDATA[jpilarski]]></dc:creator><pubDate>Thu, 27 Feb 2020 08:00:11 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 27 Feb 2020 06:55:33 GMT]]></title><description><![CDATA[<p dir="auto">there are other modes depending on with color you relase button while booting. App mode (run <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow ugc">main.py</a>), uiflow web, uiflow usb, and web config. You can see colors and modes in <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a></p>
]]></description><link>https://community.m5stack.com/post/7598</link><guid isPermaLink="true">https://community.m5stack.com/post/7598</guid><dc:creator><![CDATA[robalstona]]></dc:creator><pubDate>Thu, 27 Feb 2020 06:55:33 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 27 Feb 2020 06:10:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robalstona" aria-label="Profile: robalstona">@<bdi>robalstona</bdi></a> beat me to it, nice tip on the button hold</p>
]]></description><link>https://community.m5stack.com/post/7594</link><guid isPermaLink="true">https://community.m5stack.com/post/7594</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 27 Feb 2020 06:10:03 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.4.5 on Thu, 27 Feb 2020 06:09:18 GMT]]></title><description><![CDATA[<p dir="auto">Start a terminal session with your Atom I usually use<br />
<code>screen "device port" 115200 </code><br />
reboot your stick and the API key will appear in the boot message</p>
]]></description><link>https://community.m5stack.com/post/7593</link><guid isPermaLink="true">https://community.m5stack.com/post/7593</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 27 Feb 2020 06:09:18 GMT</pubDate></item></channel></rss>
