<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[External power to header ?]]></title><description><![CDATA[<p dir="auto">Need to connect 5V power direct to header and remove battery. No clear what header pin to connect to - 5V ?, BAT ? or the mysterious HPWR pins ? Anybody tried this yet ? Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/172/external-power-to-header</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 08:06:24 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/172.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Apr 2018 11:39:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to External power to header ? on Fri, 13 Apr 2018 17:13:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/drwino" aria-label="Profile: drwino">@<bdi>drwino</bdi></a><br />
:-)<br />
Good luck.</p>
]]></description><link>https://community.m5stack.com/post/839</link><guid isPermaLink="true">https://community.m5stack.com/post/839</guid><dc:creator><![CDATA[X-Dron]]></dc:creator><pubDate>Fri, 13 Apr 2018 17:13:44 GMT</pubDate></item><item><title><![CDATA[Reply to External power to header ? on Fri, 13 Apr 2018 15:38:15 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the detailed reply. I will try some of the options but first I will order a few M5Stacks so life can continue if we get blue smoke !</p>
]]></description><link>https://community.m5stack.com/post/838</link><guid isPermaLink="true">https://community.m5stack.com/post/838</guid><dc:creator><![CDATA[DrWino]]></dc:creator><pubDate>Fri, 13 Apr 2018 15:38:15 GMT</pubDate></item><item><title><![CDATA[Reply to External power to header ? on Fri, 13 Apr 2018 13:20:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/drwino" aria-label="Profile: drwino">@<bdi>drwino</bdi></a><br />
I'm sorry for missprint. Of course pin "5V". :)<br />
I said the best and most problemless way is to use the usb connector of M5Stack. You could make a special USB cable only with 5V.<br />
All other methods have nuances.<br />
See M5-Core-Schematic.<br />
The simplified power scheme looks like this.<br />
<img src="/assets/uploads/files/1523617642651-m5stack2.png" alt="0_1523617639632_M5Stack2.png" class=" img-fluid img-markdown" /><br />
VCC_5V, VCC_3V3, Vbat are connected to the bus, V_USB is not.<br />
if you connect external power to VCC_5V then</p>
<li>A special USB programming cable with the USB 5V disconnected 'll not work. Course CP2104 is not powered.</li>
<li>If you want to program simply turn off the external power supply 5V. For example to use a jumper.</li>
<li>You can try to use a diode. But I do not have confidence.</li>
<li>The battery is not charged.<br />
<img src="/assets/uploads/files/1523617652345-m5stack2_2-resized.png" alt="0_1523617649260_M5Stack2_2.png" class=" img-fluid img-markdown" /><br />
I want to connect external 5V power to the V_USB wire and remove the USB-fuse.<br />
In this case all will powered and 5V from the USB is disconnected. Battery works too.<br />
All must have a common GND.</li>
]]></description><link>https://community.m5stack.com/post/837</link><guid isPermaLink="true">https://community.m5stack.com/post/837</guid><dc:creator><![CDATA[X-Dron]]></dc:creator><pubDate>Fri, 13 Apr 2018 13:20:05 GMT</pubDate></item><item><title><![CDATA[Reply to External power to header ? on Fri, 13 Apr 2018 04:31:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/x-dron" aria-label="Profile: x-dron">@<bdi>x-dron</bdi></a> I guess you mean connect to the 5V not pin 5. Pin 5 is GND. What happens if power is supplied to 5V pin and then you connect USB at same time for programming - I suppose you could make a special USB programming cable with the USB 5V disconnected.</p>
]]></description><link>https://community.m5stack.com/post/832</link><guid isPermaLink="true">https://community.m5stack.com/post/832</guid><dc:creator><![CDATA[DrWino]]></dc:creator><pubDate>Fri, 13 Apr 2018 04:31:05 GMT</pubDate></item><item><title><![CDATA[Reply to External power to header ? on Thu, 12 Apr 2018 19:54:39 GMT]]></title><description><![CDATA[<ol>
<li>The easiest is to use the USB cable and connect the 5V to it.<br />
2.If you do not need a battery, you can connect to pin 5 on the bus.<br />
3.I'm going to use such a power scheme. Red lines are new wires.<br />
HPWR is not used in M5Stack now. it is presented only on the bus.<br />
<img src="/assets/uploads/files/1523562874278-m5stack2-resized.png" alt="0_1523562875175_M5Stack2.png" class=" img-fluid img-markdown" /></li>
]]></description><link>https://community.m5stack.com/post/826</link><guid isPermaLink="true">https://community.m5stack.com/post/826</guid><dc:creator><![CDATA[X-Dron]]></dc:creator><pubDate>Thu, 12 Apr 2018 19:54:39 GMT</pubDate></item></channel></rss>
